Author Topic: CP-1 Command Pod: The VR Space exploration project  (Read 76977 times)
SpaceHedgehog
  • Last login:March 14, 2026, 10:40:09 am
  • Almost done ...
Re: CP-1 Command Pod: The VR Space exploration project
« Reply #120 on: November 30, 2014, 01:02:33 pm »
Finished beveling all the edges and routing out the insets for the materials to sit in:
Beveling:
Inlays:
The depth of the inlay for the wire mesh is about 2mmm whilst that for the rubber and artwork is around 7mm.
Edit: That's it for today ...
« Last Edit: November 30, 2014, 01:08:53 pm by SpaceHedgehog »
Click a pic for a video tour
markc74
  • Last login:March 17, 2026, 05:17:16 pm
  • Flipping out
« Reply #121 on: November 30, 2014, 02:20:45 pm »
Really nice work mate. I really like that you're following the same theme as your other cab so they go together. I'll be doing the same when I build my pinball cabinet (called "Flip" obviously!).
Sucks having a cold and working with MDF though...
Edited for grammar. Because my mum told me to.
« Last Edit: November 30, 2014, 02:35:01 pm by markc74 »
ChanceKJ
« Reply #122 on: November 30, 2014, 02:52:55 pm »
...my pinball cabinet (called "Flip" obviously!).
 :D  :applaud:
SpaceHedgehog
  • Almost done ...
« Reply #123 on: November 30, 2014, 03:47:28 pm »
Thanks for that  :cheers: I'll look forward to your pinball cab; if it's anything like your Blip cab, it will be most excellent. I'm not just saying this when I consider your machine to be the best traditional style cab I've seen on here. My kind of colour scheme with something 2001'esque about it. Understated, meticulously detailed and frankly, a veritable classic. A great name for the new project, but you know that already ;)
Just a simple pic to show the position of the throttle for this build. The bottom of the case will be about level with the top of my knee when attached:
SpaceHedgehog
  • Almost done ...
« Reply #124 on: December 01, 2014, 06:40:00 am »
First fine ribbed rubber insert complete. Backing board cut:
Rubber cut:
Glued together using this:
In-place:
SpaceHedgehog
  • Almost done ...
« Reply #125 on: December 01, 2014, 07:48:21 am »
I've completed the second rubber inlay and cut the first section of mesh:
BorgDog
« Reply #126 on: December 01, 2014, 08:32:48 am »
Very nice work!  :notworthy:
Out of curiosity, how did you do the large bevel around the edge?  It is very smooth and consistent.
My Projects:
SpaceHedgehog
  • Almost done ...
« Reply #127 on: December 01, 2014, 08:45:07 am »
Thanks BorgDog  :cheers: It's done with a router/chamfer bit. Very easy to do really provided you have a nice straight perimeter/edge to work with. All this has been done with a hand held router rather than a router table.
Mesh done for both sides:
Upright with throttle:
It's starting to look like something now.
Edit: Ejection seat stickers turned up in the post:
These will be embedded into the build behind some acrylic - not sure where yet.
« Last Edit: December 01, 2014, 08:57:48 am by SpaceHedgehog »
SpaceHedgehog
  • Almost done ...
« Reply #128 on: December 01, 2014, 09:46:05 am »
Artwork/logo will be simple. I may resize the font a fraction smaller:
It will be black rather than gray, naturally.
Edit: Font is Neuropol X if anyone's interested.
« Last Edit: December 01, 2014, 09:49:51 am by SpaceHedgehog »
jackiabu
  • Last login:May 18, 2025, 02:29:49 pm
    • http://jackiabu.blogspot.com/
« Reply #129 on: December 01, 2014, 10:31:26 am »
I am so enjoying follow your projects.
You are doing an amazing job. :applaud:
By the way i see where you put the position of the throttle for this build...You do not have a problem with the USB cable length? i ask this , because I built something similar in the past  to my arcade machine.
But in the end I found a solution ...http://jackiabu.blogspot.co.il/search?updated-min=2012-01-01T00:00:00-08:00&updated-max=2013-01-01T00:00:00-08:00&max-results=2
anyway keep the amazing job you doing  ;D
SpaceHedgehog
  • Almost done ...
« Reply #130 on: December 01, 2014, 10:44:57 am »
Thanks jackiabu  :cheers: The USB cables for both the throttle and the stick (they have 1 each) will be fed into a Neutrik USB adapter located on the top of the side pods.
I have only made the sides for these pods so far. There will be a section 4cm in width between these which gives me space to attach the Neutrik connector to. The USB cables from these adapters will be fed through the underside of the seat into a USB hub located in the back of the seat - I'll be making an access hatch so I can get inside easily. The USB hub will connect to a USB repeater so I don't run into any issues with overall USB cable lengths:
There's plenty of space inside the cases to accommodate any 'excess' cabling from the HOTAS so it won't look untidy.
SpaceHedgehog
  • Almost done ...
« Reply #131 on: December 01, 2014, 06:09:12 pm »
Trying to come up with a logo that's not over-stylized but simple and effective. This is what I've come up with:
Thoughts?
Slippyblade
« Reply #132 on: December 01, 2014, 06:10:47 pm »
Feels like the letters need depth to them.  Like a bit of extrusion or something.
SpaceHedgehog
  • Almost done ...
« Reply #133 on: December 01, 2014, 06:12:50 pm »
Interesting idea, like an inverted drop shadow or something?
ChanceKJ
« Reply #134 on: December 01, 2014, 08:59:50 pm »
I'd say flat. sans serif,  Just a slightly thicker than medium weigh Helvetica variant. maybe add some gaps in the P and break up it's Counter.  More of a futuristic military font. Something you'd see on Space:Above and Beyond, but before going the full rustic future dystopian spray paint feel.
SpaceHedgehog
  • Almost done ...
« Reply #135 on: December 02, 2014, 05:16:34 am »
Cheers Chance, I'll look at that font. I did find another good one - AR DESTINE. Still trying to make the the logo pop a bit but my Photoshop skills are somewhat lacking. I think this is much better than the first:
Improvement?
njay
  • To Nudge or Not to Nudge !
« Reply #136 on: December 02, 2014, 07:08:53 am »
Do you have a ingame name yet?
so i can shoot you from the sky?  :lol
SpaceHedgehog
  • Almost done ...
« Reply #137 on: December 02, 2014, 09:05:48 am »
Yes, it's Commander Marcus Antonius (connection with Cleopatra with the asp and all that - tenuous link with snake ship names in the game, I know). Feel free to engage  :cheers:
More work on the artwork. More complex than originally envisaged but getting to the point where I'm happy with it. I've taken the window shape into consideration when putting this together:
Edit: Frontier are the developers for Elite Dangerous btw.
« Last Edit: December 02, 2014, 09:17:45 am by SpaceHedgehog »
SpaceHedgehog
  • Almost done ...
« Reply #138 on: December 02, 2014, 02:52:37 pm »
Hmmm ... nearly there I guess ... for now. Added a couple of lines to make it look more like corporate branding:
Anyone who's good at Photoshop, it this any good or are there any other simple effects I could be looking at?
Slippyblade
« Reply #139 on: December 02, 2014, 03:03:43 pm »
I like it, it has the depth I was thinking about.  Though the '1' looks a little off.  How's it look as a single piece?
SpaceHedgehog
  • Almost done ...
« Reply #140 on: December 03, 2014, 05:44:59 am »
Thanks for that Slippy. Your idea about the depth has definitely made a difference. I wish you hadn't mentioned the '1'; I'll have a look at that now ...
SpaceHedgehog
  • Almost done ...
« Reply #141 on: December 03, 2014, 06:55:03 am »
Still experimenting on the '1' ... Artwork printed out in draft. I will shrink this by a few percent for a better fit - it's too close to the edge at present:
AzureKnight
« Reply #142 on: December 03, 2014, 09:31:38 am »
On the "1", to me it is the font.  I've never been a fan of fonts that round the top right corner of a 1.  I like the the Robotech font personally  :dunno
If you keep this font I'm not sure what you can do, if you square off that top corner then it might look really odd compared to the CP.
SpaceHedgehog
  • Almost done ...
« Reply #143 on: December 03, 2014, 11:59:47 am »
Ok, after checking out the Robotech font, I decided it was an option. It doesn't lend itself to using the inner stroke approach so I used it on the outside instead. This is what I cam up with:
Looking for some feedback/critique from you guys on this as I like both:
Generic Eric
« Reply #144 on: December 03, 2014, 12:11:26 pm »
Send it to the printer!
Your diligence is noted Commander, your Freagle awaits!
Slippyblade
« Reply #145 on: December 03, 2014, 12:40:42 pm »
Yep, I think we have a winner.
ChanceKJ
« Reply #146 on: December 03, 2014, 01:15:29 pm »
Yep. This for sure. I like it minus the amount of gradient. I'd tweak it a bit and give it less (or none at all). Maybe a version where there's no "3D" effects and it's just a flat looking image? Simple and subtle.
AzureKnight
« Reply #147 on: December 03, 2014, 01:18:53 pm »
I think it looks great (although I'm biased as I already admitted to liking that font).  I like the 3D depth on it due to the fact that you have beveled edges everywhere on the project so it seems to blend well.
SpaceHedgehog
  • Almost done ...
« Reply #148 on: December 03, 2014, 02:21:21 pm »
Thanks for the input and feedback guys  :cheers:  It looks like the newer version is the clear winner. I think Chance has a point - maybe a slightly less gradient. Going to get the proportions for this right now and send off to have it printed on some nice card.
dkersten
« Reply #149 on: December 03, 2014, 04:48:48 pm »
I was thinking that would look fantastic printed on vinyl with a glossy laminate, then adhered to a board you mount behind like the other panels...
SpaceHedgehog
  • Almost done ...
« Reply #150 on: December 03, 2014, 04:57:33 pm »
Right with you there on the glossy finish dkersten. I'm going to sandwich the card between some 3mm acrylic (waiting for that to arrive) and some backing board :)
I'll use the same approach as the R-Pod:
SpaceHedgehog
  • Almost done ...
« Reply #151 on: December 05, 2014, 05:27:43 am »
I have cut out the frames for the inside sections of the outer panels. The perimeter pieces will be glued into place:
SpaceHedgehog
  • Almost done ...
« Reply #152 on: December 05, 2014, 08:19:31 am »
I started work on the inner sections of the left pod:
These will not be supporting structures. This is to be the full width of each of the side pods (89mm total):
SpaceHedgehog
  • Almost done ...
« Reply #153 on: December 05, 2014, 09:08:42 am »
I started on the LED cluster for the downward sloping side on the rear of the side pod. Just trying to get the spacing how I want it; it just needs to be reasonably subtle and unfussy:
These are held in with Blu Tac at the moment. The bezels will eventually be epoxy'd in place and the LEDs hot glued into those:
SpaceHedgehog
  • Almost done ...
« Reply #154 on: December 06, 2014, 06:04:13 am »
The dark red vinyl (which will sit behind the black wire mesh) arrived today. The picture doesn't accurately portray the colour at all unfortunately. It's a couple of shades darker:
The 3mm acrylic also arrived.
I also ordered the artwork so hopefully that will be here in the next few days.
Currently cutting the supporting pieces for the side pods ...
SpaceHedgehog
  • Almost done ...
« Reply #155 on: December 06, 2014, 08:28:06 am »
Still working on the support structures and perimeter pieces but a bit of a diversion with the vinyl:
SpaceHedgehog
  • Almost done ...
« Reply #156 on: December 06, 2014, 09:50:35 am »
I've cut enough perimeter pieces and supporting blocks to start gluing things together. The remaining blocks will be straight cuts rather than angled ones so are much simpler. I will will need to apply the glue to the pieces in 2 passes. I will complete the left pod first and then start on the right pod.
The screws have been countersunk to enable them to be screwed (and glued) into the outward face once everything is ready. There will be more pieces to accept the HOTAS poles and also an additional brace running across the centre.
I have also cut the hole for the Neutrik USB connector in the top panel:
  • Last login:March 17, 2026, 10:06:06 am
« Reply #157 on: December 06, 2014, 05:09:58 pm »
Really like the logo! :cheers:
Superfrog
    • My YouTube Channel
« Reply #158 on: December 06, 2014, 05:30:45 pm »
+2
Great to see this one coming together
jaharr01
« Reply #159 on: December 06, 2014, 11:47:59 pm »
Damn I look at your $hit and it just makes me feel completely inadequate.Totally awesome build. You got some mad skills Bro.
