Author Topic: Links to Driving Cab projects  (Read 76327 times)
« on: February 24, 2013, 04:55:34 pm »
Build threads go in the Project Announcements forum, but we'll keep a directory here.  :)
Post a picture and a link to your driving cab project here.
--OTHER REPLIES OR COMMENTS WILL BE DELETED--
Please post praise or questions in the related build threads.
Here is the old list from the Driving Cab Info thread to get us started.
theCoder's Xcellerator - Xbox based cab
leapinlew's Prepare to Qualify - classic 360 degree standup
Uncle T's rotating 6 panel monster RIP
thagerty's convertible driving/flying cockpit
BadMouth's Redline Virtual On conversion
thesharkfactor's Initial D conversion w/working arcade FFB
gbeef's Outrun Paradise w/G27 & 32" Widscreen LCD
redketchup's Outrun III xbox cab w/32" widescreen LCD
« Last Edit: November 12, 2015, 11:37:51 am by BadMouth »
Re: Links to Driving Cab projects
« Reply #1 on: February 24, 2013, 05:09:29 pm »
retrorepair
  • Last login:July 06, 2025, 06:47:43 pm
« Reply #2 on: February 27, 2013, 12:21:37 am »
My old cabinet:
Also on my channel are videos of the new cab (which I still have to finish so I can upload a video).
Thanks for the heads up on the sub forum too badmouth, hadn't noticed it pop up! :)
« Last Edit: February 27, 2013, 12:23:18 am by retrorepair »
My arcade racing setup:
My Youtube Channel: http://www.youtube.com/user/RetroRepair
My Twitter: http://twitter.com/retrorepair
Jollywest
  • Last login:Yesterday at 02:00:22 am
« Reply #3 on: February 27, 2013, 04:11:50 pm »
My Sega Model 2 & 3 (PC Emulated) Racing cab converted from a non-working Midway Cruis'n USA machine;
It uses the original Happ FFB wheel with an Immersion Touchsense FFB PCB.
Check out the blog link in my sig for info on it's journey.
« Reply #4 on: February 27, 2013, 06:57:23 pm »
brad808's Emergency Call Ambulance conversion with Sega Rally E-brake
http://forum.arcadecontrols.com/index.php/topic,115186.0.html
« Reply #5 on: February 27, 2013, 10:14:34 pm »
vandale's twin Road Racer 2 conversion:
« Reply #6 on: February 28, 2013, 10:41:30 pm »
aganyte's scratch built Sega Rally
http://forum.arcadecontrols.com/index.php/topic,122462.msg1299962.html#msg1299962
aganyte has created his own interfaces for Happ and Sega wheels.
http://www.gamoover.net/Forums/index.php?topic=20417.0
http://www.gamoover.net/tuto/l2m2-interfacer-un-ffb-et-volant-sega-model-12-avec-un-pc-ou-une-playstation-23
I'd like to see how the happ one compares to a servo amp at some point.
isamu
  • Last login:February 19, 2026, 01:09:24 pm
« Reply #7 on: March 01, 2013, 05:55:48 am »
Here is my "Arcade Racing" setup I posted a couple years ago showcasing my ECCI 7000 wheel.
« Reply #8 on: April 12, 2013, 09:16:55 am »
« Reply #9 on: May 21, 2013, 10:54:29 am »
ScottoKong's Cruisin' USA conversion
This thread has just about all the information on the Happ/Servo Amp hack combined in one place. (and he did not experience the wobbling issue)
See reply #38 for a summary.
http://forum.arcadecontrols.com/index.php/topic,115133.msg1220257.html#msg1220257
Andypc
  • Last login:November 18, 2024, 01:45:58 pm
« Reply #10 on: August 04, 2013, 03:20:50 pm »
Here is a couple of videos of my set-up. I did the driving cab a few years ago. The metal work was all stripped and powder coated. The plastic sides were painted and new artwork applied. I fitted new Sanwa PFX monitor's with new surround and dashboard plastics purchased direct from Sega.  They have modified Logitech G25 wheels working with the cabs original pedals.
rockyrocket
« Reply #11 on: December 27, 2013, 04:59:41 am »
I will throw my Cabaret on here as something different.
arcadepcnut
  • Last login:August 15, 2019, 12:03:07 pm
  • Warhammer 40K, you should try it.
    • BREAKTIME
« Reply #12 on: March 02, 2014, 02:14:34 pm »
Hello. Godaddy stole my domain a year or so ago. So I got a new domain name. My driving cabinet has been updated quite a bit in the 10 years since I built this website. This website is a picture of my old cabinet. However it has been modified quite a bit! im using all REAL arcade controls now. arcade steering wheel with force feedback motor. arcade shifter and pedals. I will update this site with some more current pictures of my build if anyone is interested and move this site to archive. I just wanted to get my site back visible.
The cabinet looks basically the same as it did but now all the buttons that normally would be on the wheel are on the console because the wheel turns! the buttons moved when I turned the wheel so I made it hard on me to hit the boost since the boost moved. I kinda like the buttons being on the dash. But some may disagree. this also has a 32" TV in it now. the power outage a couple years ago blew the 27" and I replaced with a sony 32" that I decased and wedged into the cabinet. I will tell you more about it later if there is any interest.
http://www.biontek.com/breaktime/index.htm
« Last Edit: March 02, 2014, 02:33:46 pm by arcadepcnut »
jackiabu
  • Last login:May 18, 2025, 02:29:49 pm
    • http://jackiabu.blogspot.com/
« Reply #13 on: March 03, 2014, 10:56:51 am »
« Last Edit: March 04, 2014, 02:21:13 pm by BadMouth »
« Reply #14 on: July 08, 2014, 04:08:05 pm »
flash951
  • Last login:May 18, 2016, 04:22:39 pm
  • You should use CRT display
    • remimedia
« Reply #15 on: August 17, 2014, 05:30:30 pm »
« Last Edit: August 17, 2014, 07:01:09 pm by flash951 »
R083RT0
  • Last login:March 11, 2026, 10:43:44 am
    • my videos
« Reply #16 on: August 30, 2014, 08:23:08 am »
my Racing Cab build from scratch...
from 2011 till 2013 I played xbox360 racing games with my cabinet, since 2013 I use my pc to play racing games  :)
« Last Edit: August 30, 2014, 08:36:43 am by R083RT0 »
Sp3c7r3
  • Last login:March 09, 2016, 02:09:52 am
« Reply #17 on: November 26, 2014, 06:53:18 am »
I made a pretty simple, but effective and clean looking, setup. The wheelstand is secured to the floor using strip wires. Seat has all the regular adjustment functions, but in it's "neutral" position it fits me perfect.
It consists of:
wallmountet 32" Samsung LCD
Wheelstand Pro
Logitech G27
i3 HTPC
Racing Seat
build process:
and the finished result:
terminator2k2
  • Last login:February 10, 2025, 05:35:27 pm
« Reply #18 on: November 12, 2015, 03:31:45 pm »
Heres a link to my Daytona USA 2 Cab conversion :
Daytona 2 Cab conversion
Still work in progress 95% complete
« Last Edit: May 30, 2016, 02:07:03 pm by terminator2k2 »
ant2
  • Last login:June 02, 2024, 07:05:47 am
« Reply #19 on: March 01, 2016, 06:19:52 am »
ant2
« Reply #20 on: March 01, 2016, 06:21:03 am »
MTPPC
« Reply #21 on: August 05, 2016, 12:04:27 am »
Crazy Taxi M2/MAME A-PAC P4-3.4 29" LCD 1360x768
http://forum.arcadecontrols.com/index.php/topic,151448.0.html
« Last Edit: February 02, 2017, 09:45:49 pm by MTPPC »
http://pinballmd.com/
segaturbo
  • Last login:June 04, 2023, 12:31:01 pm
  • SEGA FOREVER
« Reply #22 on: February 18, 2017, 06:14:44 pm »
heres my daytona 2 cab on you tube running mala frontend and l2m2
mike5im5
  • Last login:December 23, 2021, 03:22:21 pm
« Reply #23 on: March 09, 2017, 01:10:40 pm »
gstav
  • Last login:December 19, 2025, 05:53:11 am
"One coin to rule em' all"
Marcoqwerty
  • Last login:January 04, 2026, 06:20:39 pm
« Reply #25 on: November 16, 2017, 10:31:34 am »
SPEEDrive is a Marcoqwerty Project, based on a Jamma coin-op with inside a pc.
FEATURES:
- Original 25" CRT Monitor (emudriver)
- 360° Wheel - Shifter UP/DOWN with NOS
- Rumble
- CPO Light Button
- 2xLed stripes on the back (output controlled)
- Pedal with micro and pot
- 2.1 audio system + 100w Subwoofer
EMULATORS:
- Mame
- Demul (MODEL 2)
- Supermodel (MODEL 3)
- PC Custom Games
« Last Edit: November 16, 2017, 11:37:06 am by BadMouth »
smokey133
  • Last login:December 19, 2018, 08:21:45 am
« Reply #26 on: February 14, 2018, 05:37:00 am »
My driving cab
marcux
  • Last login:September 08, 2020, 12:45:17 am
« Reply #27 on: December 18, 2018, 09:39:23 am »
My newly Finished driving cabinet. All I have is youtube video at the moment.
smokey133
« Reply #28 on: December 18, 2018, 04:06:13 pm »
Nice!!Awesome work!
fiatbravodriver
  • Last login:January 08, 2021, 09:22:44 am
« Reply #29 on: July 17, 2020, 02:09:17 pm »
Hi,
Inspired by the great people of this site I had a go.
I made a Video Showing the whole process.
The link is here if anyone wants to see it.
Take Care.
J
CboneCapone
  • Last login:April 12, 2023, 02:29:43 pm
« Reply #30 on: January 16, 2021, 08:44:36 pm »
Here is what I'm calling my old racing cab - I'm about to get rid of it to make room for a few more.  Nothing crazy here - I've had a few different monitors / TVs over the years, had the g27 since 2010, got the seat out of a junkyard, has some lights underneath but nothing too blingy.
Aurelien
  • Last login:March 10, 2023, 11:00:02 am
« Reply #31 on: March 05, 2023, 02:27:25 am »
Does this count if it does not look like a classic arcade cabinet?
Features:
- 2 directions
- 1 accelerator / brake lever
- 1 start button
- also works on snow
