Author Topic: Scratch Slim Marvel vs Capcom [14 Nov - Finished]  (Read 148812 times)
Martijn
  • Akira!
    • ModMyBox
Re: Scratch Slim Marvel vs Capcom [23 Sep - Artwork Arrived & Inside Peek]
« Reply #120 on: September 24, 2011, 04:55:24 am »
Recieved a new volume pot for the creative speaker set, i bought the set second hand and the main pot could turn and turn, and some volume balance problems. Gonna replace it this weekend.
Drilling template, i went with the generic version of the Vewlix shifted layout. Got it from http://www.slagcoin.com/joystick/layout.html
Why did i choose this design, well i placed my fingers on the cabinet and printed some layouts, this one felt best for my use.
Ready for drilling
I have to note, i bought the Sanwa JLF sticks from arcadeshop.de and used their mounting plate details http://www.arcadeshop.de/images/specs/arcade-jlftp8yt-mounting.gif
Its not correct
The size is correct
but the drilling holes arent
Just have to make sure i dont make a mistake here.
BobA
  • What Me Worry?
« Reply #121 on: September 24, 2011, 03:13:28 pm »
You are a tease but great looking cab.   Neatness is next to Godliness, or so says my Wife.
Martijn
  • Akira!
    • ModMyBox
« Reply #122 on: September 24, 2011, 04:53:17 pm »
Thnx, ill post some artwork pictures when i got some good pictures.
I added m5 bolts to the joystick plates and made them flush
And started drilling the cp
Placed the cab on its side and cleaned with amonia and then apply the artwork
I also replaced the old volume pot with the new one, its perfect. audio is ballanced 100% at low volume and i can now finaly mute it.
Pretty happy with that, pretty happy  :applaud:
« Reply #123 on: September 24, 2011, 05:07:03 pm »
Really awesome work, man!  :applaud:
Martijn
  • Akira!
    • ModMyBox
« Reply #124 on: September 25, 2011, 07:01:51 am »
Finished drilling the holes for the control panel  :applaud:
SNAAKE
  • Trade Count: (+29)
« Reply #125 on: September 25, 2011, 07:05:08 am »
jayska01
  • Last login:December 14, 2011, 05:38:46 pm
« Reply #126 on: September 27, 2011, 08:49:05 pm »
Sweet i love this machine so far your kids must love it!!! >:D
http://forum.arcadecontrols.com/index.php?topic=114821.0
DONT NOT CLICK THIS WARNING DO NOT CLICK THIS!!!!!
Martijn
  • Akira!
    • ModMyBox
« Reply #127 on: September 28, 2011, 02:13:24 pm »
My kids only play nintendo ds  ;)
As long as the cab is not working properly they have no real interest. (more cab time for me right )  :cheers:
Martijn
  • Akira!
    • ModMyBox
« Reply #128 on: October 05, 2011, 01:43:56 pm »
Not much of an update but i wanted faster dedicated network connection on my cab , plus the xbox has xlink for online play and i needed  faster ftp transfer.
Got a cheap chrome utp connector
Painted it black
And installed it on the backside near the power socket
Started to work on the Madcats fightpad pcb. I removed the cable and added a pin socket to the board
And added a female connector to the madcats usb cable
Cute  :angel:
mmonden
  • Last login:March 05, 2014, 12:17:57 pm
Re: Scratch Slim Marvel vs Capcom [5 Okt - Pcb Pets]
« Reply #129 on: October 05, 2011, 07:18:27 pm »
Very Nice Martijn :applaud:. That cabinet looks great. Ill be watching for some more great ideas.
dandare
« Reply #130 on: October 05, 2011, 08:48:50 pm »
Those feet do make pcb's look cute. they look hilarious on a minipac!
cant wait to see the artwork!
Martijn
  • Akira!
    • ModMyBox
« Reply #131 on: October 06, 2011, 04:12:15 am »
I worked on my control panel some more  :D
I never thought i would have had so little space for all the buttons joysticks & pcb on the panel. I had to move stuff around a lot to get it to fit.
In the end i got it right.  :applaud:
First i had to cut the little pcb pets up once more  :-[
With the pcb moved all the way to to top it could fit just right.
Mounted the JLF plates
laminated both sides and opened the holes up
The nicest way was to place the lpt socket like this
But then the cp wont fit anymore plus i couldn't get the lpt connector in the socket
WONT FIT :(
So i had to move the lpt more around. I centered it vertical. That way it would fit and i could get the lpt cable in.
And i started wiring
Pcb soldering
Result  :applaud:
amendonz
Re: Scratch Slim Marvel vs Capcom [6 Okt - Control Panel Wiring Done]
« Reply #132 on: October 06, 2011, 04:19:43 am »
 :applaud: great wiring
Martijn
  • Akira!
    • ModMyBox
« Reply #133 on: October 06, 2011, 04:22:19 am »
Just to add the LPT is used for
- Player 1 turbo on off (2 wires)
- Player 2 turbo on off (2 wires)
- Player 1 turbo LED (2 wires)
- Player 2 turbo LED (2 wires)
- Player 1 Left analog stick / Right Analog stick / D-Pad Switch  (4 wires)
- Player 2 Left analog stick / Right Analog stick / D-Pad Switch  (4 wires)
- Player 1  Select Button (Xbox 360 Back button) (2 wires) (Going to the coin Box)
- Player 2  Select Button (Xbox 360 Back button) (2 wires) (Going to the coin Box)
« Last Edit: October 06, 2011, 04:23:52 am by Martijn »
« Reply #134 on: October 06, 2011, 04:48:31 am »
Looks very neat. How are you liking the JLF sticks so far?
« Reply #135 on: October 06, 2011, 08:34:56 am »
Beautiful job on cable management! :applaud:
Martijn
  • Akira!
    • ModMyBox
« Reply #136 on: October 06, 2011, 09:00:03 am »
I tried them for the first time today and feel ok. the cp isnt locked down yet so i cant really go at it.
Thanx Nephast, i knew your kind of a wire nut  :P So i did my best to please you  ;D
TopJimmyCooks
« Reply #137 on: October 06, 2011, 02:32:38 pm »
High praise indeed from the Czar of Crimp City!
+1 from me - I've never seen controller hacks handled so well.  those JLW's with the header connection make for such a nice clean setup.
« Reply #138 on: October 06, 2011, 08:55:37 pm »
Awesome job of wiring!  Your CP should be plexi so it can be seen.
dandare
« Reply #139 on: October 07, 2011, 09:29:58 pm »
Amazing!
I'm rewiring my cp as we speak! Two questions,
Did you solder directly onto the micro switch terminals? (rather than crimps)
and did you bend the JLF pins 90º? if so that's a great idea as they can be quite awkward to get at flat.
Martijn
  • Akira!
    • ModMyBox
« Reply #140 on: October 08, 2011, 04:52:30 am »
Yes soldered every connection. I am a soldering freak  :laugh: and yes bended the JLF 90 degree, i used a dremmel and a bit like this
and dremmeled the top white plastic of untill the coper pins started showing, and i took a plier and bend all the pins up in one move
Re: Scratch Slim Marvel vs Capcom [4 July - Inside Laminated]
« Reply #141 on: October 09, 2011, 11:47:26 pm »
Today a lot of hard work and little progres..
i made the template for the laminate, measured a lot of times for the pine holders
Then router out the space on the inside laminated parts
It was really hard because i didnt have the correct bit, mine was to long for 18mm mdf template..
I debating doing something similar to what you did to route out the inside laminate.  I'm just having a little trouble visualizing exactly what I need to do.  What type of bit did you use?
I'm thinking I need something like this -
http://www.rockler.com/product.cfm?page=25160
Martijn
  • Akira!
    • ModMyBox
« Reply #142 on: October 10, 2011, 03:57:35 am »
Yes thats the correct bit, you dont really need to make the template perfect, make the gaps a bit wider so you have some working space.
Or just dump the whole idea of removing the laminate, and just glue pine holders with screw from outside to inside (and inside to outside if you want), if you gonna laminate the outside it wont show a mark..
« Reply #143 on: October 10, 2011, 09:30:56 am »
Thanks for the confirmation.  I may go with with your second recommendation since I will be laminating the outside.
Woodshop Flunky
« Reply #144 on: October 18, 2011, 01:02:32 pm »
I removed the laminate from my build with a router.  However, I didn't use a bit with a bearing.  Instead I used router bushings... http://www.rockler.com/product.cfm?page=10671  Using these, I was able to adjust a straight bit to take just a little more material than the thickness of the laminate.  It seemed pricey, but it's nice to have if you do any other woodworking.
I also agree that you would be fine (strength wise) by gluing, and screwing the battens from the outside.  Aside from strength, one of the other advantages to removing the laminate on my build was that doing so gave me identical reference edges on each side panel.  This came in VERY handy when mounting my monitor and CP.
Jdurg
« Reply #145 on: November 03, 2011, 01:23:26 am »
Not having space in my own house to place a cab, it's always fun living through the exploits of others in their cab builds.  :)  Your SF cab was beautiful, and this one appears to be coming along nicely as well.
Not sure if the builds for the 360 include it, or if the 360 is able to handle it, but have you checked out the HLSL function of MAME?  I didn't think my 4 year old laptop would be able to handle this supposedly power intensive feature of MAME, but was surprised to find out that it can indeed handle it, and the results are incredible.  It VERY accurately recreates the scanlines, bleedover, curvature, etc. of old school CRT monitors on an LCD screen.  I have connected my laptop up to my 42" LCD HDTV using S-Video and when running MAME using the HLSL feature in it, my jaw just dropped.  Hence why I have recently started compiling ideas for a second arcade joystick.  (Can't build a cabinet, but can build a joystick using the control panel parts from my halted cab-build).  Just currently delayed by a broken right medial maleolus in my ankle that has me on crutches and a walking boot.  Until that heals, and until I'm off of the pain killing medication, I can't be working with power tools or even going around Home Depot to pick up the MDF I need.
Anyway, cab is looking great and if you can get a build of MAME to run on the 360 that handles the HLSL feature, give it a try.  It's stunning.
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
JoeyJoeJo
  • Last login:February 27, 2013, 09:34:56 pm
    • PS4 Hacks
« Reply #146 on: November 03, 2011, 09:19:46 am »
OP, where did you get the RJ-45, USB and power connectors? Those really make your cab look professional and I want to do something similar.
gbeef
    • arcadepix.com
« Reply #147 on: November 03, 2011, 12:55:47 pm »
love this build and attention to detail.
I may have to build a slim in the future. Very nice work so far.
My cabs
4 Player Arcade
X-men Arcade Remixed
Martijn
  • Akira!
    • ModMyBox
« Reply #148 on: November 14, 2011, 08:10:06 am »
Finnaly completed my cabinet. Here are the pictures. Pictures where taken with a Nikon D3000, i have to say the pictures came out a little to bright  :dunno
I would like to thank Scott from gameongrafix.com for his excellent support.  :cheers:
Cabinet is 99% done (there is no 100% in cabinets  ;) ) just waiting for the xbopx 360 scene to come up with new mame and fbanext
OverRide
  • Last login:January 11, 2026, 04:25:09 pm
Re: Scratch Slim Marvel vs Capcom [14 Nov - Finished]
« Reply #149 on: November 14, 2011, 08:58:00 am »
Congrats on finishing, You did an amazing job!
njay
  • To Nudge or Not to Nudge !
« Reply #150 on: November 14, 2011, 09:20:40 am »
Nice work  :applaud:
« Reply #151 on: November 14, 2011, 09:35:57 am »
So clean! :drool
« Reply #152 on: November 14, 2011, 09:45:28 am »
It's looking amazing. The artwork and overall look looks way better than any factory produced arcade cabinet (wood) that I've seen. The JLF's looks like they aren't properly mounted though.
Sanwa
Joystick mounting height: 23mm-24mm between the bottom of the ball top and the top of the control panel (reference: Paik)
Joystick top panel hole: 24mm diameter circle (plus or minus a few millimeters will work too)
Standard button hole: 30mm diameter circle
Small button hole: 24mm diameter circle
Snap-in button depth (standard and small): 2mm-4mm panel thickness
Screw-in button depth: 0mm-8mm panel thickness
Screw-in standard button nut diameter: 36mm
Screw-in small button nut diameter: 29.5mm
http://slagcoin.com/joystick/mounting_layering.html
Martijn
  • Akira!
    • ModMyBox
« Reply #153 on: November 14, 2011, 09:54:09 am »
Thanks you all, could you explain this Emphatic? I mounted the plates as high as possible with flush screws
« Reply #154 on: November 14, 2011, 12:18:33 pm »
The shafts are about 1-2 cm taller (from plexi surface to balltop) than they're supposed to be. Hard to say exactly from your pics.
Some proper height examples:
Martijn
  • Akira!
    • ModMyBox
« Reply #155 on: November 14, 2011, 02:03:25 pm »
Ah thats no problem, short just looks silly to me on a cab, maybe on a fightstick
« Reply #156 on: November 14, 2011, 02:58:25 pm »
Lookin' fresh!  :applaud:
I do agree that the joys look a bit too high. Take a look at any of the candy cabinets, or Vewlix control panels. You'll notice Emph's height example is the same. There should be enough space for two fingers right under the balltop, while holding it with your thumb, index, and middle fingers in a comfortable rest position while the side of your hand is resting on the CP surface (that is, without straining upwards to hold the balltop).
It might be too late to change it, but if you're happy with it, then all-the-power-to-ya. Maybe you have big paws though...  ;)
gbeef
    • arcadepix.com
« Reply #157 on: November 14, 2011, 04:15:24 pm »
Wow this is really nice. Awesome work
My cabs
4 Player Arcade
« Reply #158 on: November 14, 2011, 04:47:35 pm »
Yes, it's all about the comfort really. For longer sessions, I think this can actually do damage to your wrists.
Martijn
  • Akira!
    • ModMyBox
« Reply #159 on: November 15, 2011, 04:07:46 am »
heres a shot of "a" hand
