Author Topic: DemulShooter (Dual light gun on DEMUL, Model2, Dolphin, Silent Hill, etc...)  (Read 1922650 times)
0 Members and 28 Guests are viewing this topic.
argonlefou
  • Last login:Yesterday at 12:40:25 pm
dgrace, I have a question.
If I have a 3D display, can I see real 3D in LGI 3D version? Does graphic appear side by side way?
No it's not side-by-side 3D, the original cabinet is using a special 3D screen and users don't need to wear any glasses to see 3D (almost like nintendo 3DS maybe ?)
argonlefou
And I forgot to put a link to the no-crosshair patch for LGI3D : https://mega.nz/#!BJwjSQDT!5k7ArK2VnVyeq94Dp6VonR7Al_SoWijnjc1jzogaKZg
As for LGI, copy the file to /data/acroarts/2D/ subdirectory
hyo2012
  • Last login:May 26, 2024, 11:15:33 pm
By the way, I found way playing Crisis zone(ps2) without annoying fog effect.
It does not need Guncon 2 usb plugin. It just connect mouse input directly to pad input.
First, you need Europe version of Crisis Zone. Easily founded on internet. USA version is not working.
Second, download ps2 mouse patcher
https://mega.nz/#!x8pVDS7B!8ulM8zHQGxC7Oi7a9Psmckl6wKVGa7-xZMJsEMd6Wb8
Third, settings for pcsx2
Go pad plugin setting. In general tab, check windows messaging at keyboard API and check disable at mouse API.
Go pad 1 tab, set D-Pad direction to left right up down of keyboard. And set start to B, R1 to V, Cross to X, square to S, circle to Z, triangle to A of keyboard.
Forth, playing
Execute downloaded ps2mp.exe.  If there is antivirus program warning, set this program exception.
Small UI appear, two check boxes are unlimited bullet and life hack. Uncheck boxes. Don't close program.
Execute pcsx2 and load Crisis Zone Eur version. Trigger is left click of mouse, guard is right click, start is mid click. Of course you can use Aimtrak lightgun.
Because of don't using guncon plugin, there is no fog effect.
But it has limitation. Moving crosshair is visible always, and Eur version does not have widescreen hack.
Argon, can you add this function to Demulshooter?
If possible, US version of Crisis zone is better which has existing widescreen hack. And removing crosshair would be awesome.
My English is not good, but I hope you understand what I'm saying. :cheers: Thank you.
« Last Edit: May 31, 2018, 11:32:24 pm by hyo2012 »
phasermaniac
  • Last login:June 10, 2025, 09:39:41 am
Wow it works!
Hyo2012, do you have more info about this patch? is it only for Crisis Zone or for any game where you aim with Dpad?
I tested with Police 24-7 Eu, but don't work, maybe because this game doesn't allow to use the Dpad to aim.
hyo2012
Wow it works!
As I know, this ps2 mouse patch is made by Chinese developer. I downloaded it on baidu(Chinese web portal) by chance.
I modified above pcsx2 setting.
this is correct setting.
PS2MP.exe works on Crisis Zone (Europe), Time Crisis 2 (USA), Ninja Assault (JPN), Virtua Cop Rebirth(JPN), Vampire Night (USA). You must match rom region.
When using widescreen hack, bullet direction is not correspond with crosshair. So must turn off widescreen hack in pcsx2 setting.
Except crisis zone, other games are work well using Nuvee plugin. But PS2mp.exe is useful who feel difficult in using Nuvee plugin.
« Last Edit: May 31, 2018, 11:48:18 pm by hyo2012 »
phasermaniac
Gaia attack 4 seems playable with jconfig, ill test later
argonlefou
Forth, playing
I'll have a look at it later, but it's quite sure I won't do anything with it....Hacking a hack already hacking a plugin.....well  :P :D
DemulShooter v7.6 :
- Added support (well, not hidden support) for LGI 3D
- Added support for Gaia Attack 4
- Updated user guide
For Gaia Attack, all 4 players can be controled by DemulShooter, but for now only P1 & P2 will be available as the program itself does not support more than 2 devices.
So untill further update....
Gaia Attack 4 - No Crosshair Patch : https://mega.nz/#!INBXCAaA!A6VV6TPsD20HmERyPbQ0ZW1WxA08qdPd2pSrL9ul6a8
phasermaniac
So fast! It works nice, many thanks for this! its one of the best lg games recently dumped and adapted in my opinion.
In minigun.ini seems also important to set render_flag to 0, else the x axis gets inverted.
bryhud
  • Last login:January 14, 2025, 06:36:57 pm
Anyone else have issue with GAIA ATTACK 4
When I set JVSENABLE and GUNENABLE to 0 the game crashes when I hit the start button
I am on Windows 7, have the game exe set to run as admin and xp sp2 compatibility mode.
dgrace
  • Last login:February 03, 2026, 10:06:19 pm
Gaia Attack 4 two player worked great.  Thanks Argon! So many sweet dual light games  to choose from now.  We are so spoiled.  That's awesome that up to 4 players is possible.  I have a 3rd Aimtrak gun so that would be sweet.
dgrace
I have Win7 and it worked fine for me.  I also didn't even need to use the jconfig file, run as admin or xp sp2 compatibility mode.  There were a few broken dumps before I found a working one.
However, I can't figure out a way to exit the game other than holding alt & F4.  Anyone have any suggestions?
dgrace
I noticed in Gaia, only player one will have the red dot in the center of the crosshair (depending on the level) but player 2 won't have the blue dot.  Is this something you can fix/add? If not, it's not a big deal.  Just curious if it's an easy fix.  I think I noticed the same problem in Panic Museum as well with player 2's crosshair.  Thanks
argonlefou
As usual, AHK script with some "Process, Close, game.exe" command in it
Crosshair is a texture file, and it's the same colorless texture used for all players.
I didn't notice any differences as I'm removing them  :D
But the file beiing the same for all, if there are differences it's the game's engine fault so I won't be able to to anything
dgrace
Thanks Argon! I'll try that script out for GAIA.
Test menu now saves in Let's Go Island3D which is nice because you can now save the calibration (it's always been a tad bit off), you can select which level/path you want to start with (before it always forced you to start with the first boat level) and you can just set it to always load as 2D.
You just have to launch demulshooter first, launch test menu in lgi3D, calibrate p1 & p2 guns, save & exit and retart game out of test menu, and you're golden.  Such a fun game!
phasermaniac
looks like the solution is to set GUN_NUM_FAKE to 1, but this way p1 lifes gets to the center of the bottom of the screen and cant see p2 lifes.
If I set GUNENABLE   to 1, lifes seems correctly positioned, but Argon specifies to set it to 0 in Demulshooter guide, I can't test it now, but maybe necessary for Demulshooter
« Last Edit: June 02, 2018, 05:26:44 am by phasermaniac »
argonlefou
It's not really needed by DemulShooter but it's what the game needs to run standalone in debug mode (with mouse + keyboard controls and 4 players) without Jconfig
There was no Jconfig when I had the game.
Jconfig emulates IO board (but they don't know how to enable players 3 and 4)
So make suee you have not put Jconfig files in the game's folder
To mke it quick,  if you can run the game with mouse controls and 4 players,  then you're goood for DemulShooter :)
« Last Edit: June 02, 2018, 06:02:21 am by argonlefou »
phasermaniac
sorry, I reinstalled the game without jconfig, but I'm still having to set GUN_NUM_FAKE to 1, else, on pressing any start button, it crashes for me. And setting GUN_NUM_FAKE to 1, causes the p1 lifes to be at center and p2 lifes doesn't show. So do you have this problem too?
Also I replaced the nocrosshair files and set GUN_CURSOR to 0, but in Area 4 Mission 16 I can see one, maybe I did something wrong in replacing files
argonlefou
I don't know what's happening for your INI files and the game :( Naver had any issue it worked directly out of the box (just needed to install the video drivers and register another dll driver)
As for the crosshairs,  I didn't play the full game to the end so somz levels may use different crosshair files.
I noticed some levels were already wirhout crosshairs,  and some with.
I removed the ones you normally see in stage select screen and at least in the level where you shoot rocks in right order
gstav
  • Last login:December 19, 2025, 05:53:11 am
    • forum.arcadecontrols.com/index.php/topic,157861.0.html
Hi man!
I have the exact same issue. Had to use the GUN_NUM_FAKE set to 1 which centers the P1 Life and hides P2's.
Witghout this I can't play it without the game crashing upon start. So if you get around this in any way, please let me know.
I'm using the "Gaia attack 4 1.02 JPN" dump.
Also @argonlefou , why is the volume maxed when I play with demulshooter? I have set my main volume to like 10% but it's 100 when this games starts *eardrums gone*  :laugh:
Any way of fix this?
"One coin to rule em' all"
phasermaniac
Hi gstav, are you using ati graphics card? I'm using with crtemudriver and a 640x480. With this, I can't get OperationGhost to run, and Music gungun2 ran, but now I'm getting the3d error again. Elevator action crashes too
gstav
Hi pal!
No, I having and older Nvidia GTX650 in my cab. Operation G.H.O.S.T. works for me though.
(Side Q: Do you rotate your screen for Elevator Madness? Just got really big black bars on the side here)
Pretty strange however with the GA4 crashing for us.
Which version do you have?
phasermaniac
same as you, are there any onther?
dgrace
Should there be a button to throw grenades in Operation GHOST? I feel like it prompts you at times to throw grenades but not sure how.  The default settings are right click action and reload and middle button to change weapons.  Just curious.  Thanks
« Last Edit: June 04, 2018, 01:20:35 am by dgrace »
argonlefou
You can check the user manual (http://www.segaarcade.com/__assets__/GamePDFs/Games/00125/operation-ghost-5522-manual.pdf) or the TEST menu, there are only 3 buttons : Shoot, Action and shooting-mode-selection
Hmmm...never had this issue  :o
Really weird between the non-working game and this  :-\
« Last Edit: June 04, 2018, 05:32:12 pm by argonlefou »
tony.silveira
  • Last login:September 27, 2024, 03:04:35 pm
    • my baby
hi there, anxious to try out DS, curious if it works with old timey actlab guns?  i tried real quick with HOTD on model 2 but the cursors were planted dead center, no matter where i shot on screen.
thanks!
argonlefou
thanks!
I don't know...I don't have those to test  :(
You can run the DsDiag.exe utility and try with each device on the dropdown list if something move on the screen
phasermaniac
Ok I think the p1 lifes cetered and other players not showing problem seems to be resolved killing the GUN_NUM_FAKE 0/1 line from the config file.
Also, I have some problem with the resize to 640x480. If I set:
SCREEN_WIDTH 640
SCREEN_HEIGHT 480
RENDER_WIDTH 640
RENDER_HEIGHT 480
RENDER_WIDTH3D 640
RENDER_HEIGHT3D 480
some graphics get missaligned and not resized.
If I use dxwind it resizes right but with Demulshooter the aiming only reaches the middle of x and y.
Without demulshooter the aiming its right, but you know only 1p.
Any thought on this? I tested the different mouse options in dxwnd, and didn't notice any signicative change in the coords.
« Last Edit: June 05, 2018, 05:41:45 pm by phasermaniac »
speedracer50
  • Last login:February 03, 2019, 11:01:37 am
first let me say DemulShooter is great and now that it is supported with RL it is even better. i am only using it for 2 games HOTD2 and sport shooting usa. when i run the DS_Diag i can see both guns as separate with separate triggers however when playing the games both guns act as player one. i am launching the games through RL. am i missing something here? i have tried calibrating the guns in both games and in the games calibration menu they are both appearing as one. any help would be greatly appreciated.
argonlefou
It seems like RL is no running things correctly and DemulShooter either is not runnig or didn't hook the game correctly
Did you try alone, without the frontend ?
You can add a -v at the end of the command to create a debug file if it does not work. We may have information in it
This might be true, I never had this line in mt config file.
Here's mine :
Code: [Select]
CNFNAME        .\sv\
RANKFILE    .\sv\
REGION        E
REDEMPTION    0
PRJENABLE       1
FULLSCREEN      1
JVSENABLE    0
GUNENABLE    0
GUN_CURSOR        1
FORCE_EXIT_KEY        1
SCREEN_WIDTH        1920
SCREEN_HEIGHT        1080
DEBUG_VRAM        0
RENDER_WIDTH3D        1920
RENDER_HEIGHT3D        1080
RENDER_WIDTH        1920
RENDER_HEIGHT        1080
SCREEN_WIDTH 640
SCREEN_HEIGHT 480
RENDER_WIDTH 640
RENDER_HEIGHT 480
RENDER_WIDTH3D 640
RENDER_HEIGHT3D 480
Just keep in mind that shooting games, and even more with demushooter, are highly dependant of the windows location and size
So messing with some of the windows settings with DxWnd may have consequences
speedracer50
i finaly got a chance to run demulshooter outside of RL same results both guns acting as one here is the debug hope yo can spot something
21:48:20.472681 :
21:48:20.478672 : -------------------- Program Start ----------------------
21:48:20.482682 : P1 device =
21:48:20.486672 : P1 device handle = 0
21:48:20.490672 : P2 device  =
21:48:20.494672 : P2 device handle = 0
21:48:20.497673 : Cmdline arg 1 : -target=demul07a
21:48:20.501673 : Cmdline arg 2 : -rom=sprtshot
21:48:20.505673 : Cmdline arg 3 : -noresize
21:48:20.508673 : Cmdline arg 4 : -widescreen
21:48:20.512673 : Cmdline arg 5 : -v
21:48:20.541685 : File not found : C:\Users\John\Desktop\\MemoryData\demul\07a\atomiswave.cfg
21:48:20.547675 : Waiting for atomiswavegame to hook.....
21:48:20.552685 : File not found : C:\Users\John\Desktop\\MemoryData\demul\07a\atomiswave.cfg
21:49:08.590287 : LowLevelMouseHook installed !
21:49:08.597287 : Attached to Process demul.exe, ProcessHandle = 1176
21:49:08.601290 : Demul.exe = 0x00400000, padDemul.dll = 0x0ECD0000
21:49:08.611288 : Adding CodeCave at : 0x17F10000
21:49:08.617289 : Atomiswave Memory Hack complete !
21:49:08.622289 : -
21:51:55.095665 : demul.exe closed
thanks,
argonlefou
Two issues :
1: There is no device saved (my guess: demulshooter config fild not found)
2: It can't find the memory files
I'd say you have some directory issue,  demulshooter is not finding it's config and the memory files that are all in demulshooter's folder
Look at the "file not found" lines and try to see what's wrong with the path
« Last Edit: June 08, 2018, 12:36:07 am by argonlefou »
speedracer50
ok that was my bad i moved the exe out to my desktop for this demonstration. i moved it back into the demul shooter folder and got a lot more information in debug file. still same results both guns have separate cursors in this mode but still shoot as one and it even locked my pc to where the left mouse wouldn't work at all when i was trying to close the game. i have attached the debug.txt for your consideration. looks to me like maybe a issue with the mouse? 19:18:47.153669 : MouseButton (Hex) = 0x0000
argonlefou
No the mouse button is normal,  it stays at 0 until a click event appears.
So far everything is normal in the file (sadly),  so I can't really say what's happening
So usual things to look :
- checking the demul version is the good one
- checking you use demulshooter with admin privilege
Zeratul
  • Last login:January 31, 2026, 01:36:12 pm
You can calibrate your aim in Touchmote very well, but there is no wizard. You need to edit the config file manually and test.
After going through all the pages and reading a lot, I realized the issue is similar to what was being discussed earlier.
After testing with XInputReporter, it seems that "Touchmote" only picks up the left/right axis at a .530, and -.530, but then it gets higher whenever I go further but it becomes very inaccurate (I'm using a 21" screen in my cabinet, and for the aim to reach 1 or -1 I have to aim way way off the screen)
@Tomkun, do you think you can guide me on how to set up touchmote so that I can calibrate it? I tried the settings.json and the other settings file in the keymapper folder, but couldn't fix the issue with the boundaries of the screen/distance or whether this is related to the position smoothing or dead zone.
I tried then WiinUSoft, and I could get the values to 1,-1 without that much hassle, and was able to get it working with Demulshooter finally, but it has an issue if the bar is at the bottom and have to place it on top, which I might end up modding my cabinet to get it working this way.
speedracer50
so i upgraded to the latest version of Demul and re-named the folder demul07a and success i know have two separate guns with separate triggers, however now when i click off the screen to re-load it works but i get the dreaded windows sound and when i die i can't continue, start and coin buttons disabled, i am running windows 10 v1709 if that helps anyone with how i can solve this. i turned off the bezel and i can see that if i pull the trigger off the screen it acts like i am right clicking on the task bar. any suggestions? i fixed this in mame by reprogramming the guns to trigger off-screen and on screen  to gun button one instead of right and left mouse click mouse click but this wont work with HOTD2. any help would be greatly appreciated.
argonlefou
Great  ;) ! For information, you don't need to rename the folder "demul07a", what's important is the version of demul and the corresponding command in demulshooter
You have to use the right button to reload, not gun button.
Do you play demul in fullscreen ? If so, you should not lose the demul's window focus and it should work
You can try to add the -noresize option in demulshooter's command
ghotik
  • Last login:June 13, 2018, 02:47:15 am
Hi. I'm trying to explain my problem in few words (not easy!).
I'm gho (a.k.a. ghotik or ghotik2002) the author of the open-source DxWnd tool hosted on SourceForge
Recently my tool was used to remap several high-red 3D shooter to a low-res monitor. For instance, Gaiaattack4 at 1280x768 was "shrinked" to 640x480 pixels to run in a low-performance computer.
In this situation, DxWnd scales down the D3D rendering and scales up the mouse coordinate values so that, for instance, a y=480 coordinate would become y=768 and the mouse would cover the whole screen area.
So far so good, controlling the mouse/lightgun directly by the game emulator. The troubles come when using DemulShooter that, apparently, sends dual inputs in such a way that DxWnd can't manage to scale the values properly.
Trying to support my "customers", I'm trying to figure out a way to intercept the coordinate values injected by DemulShooter and scale them properly: some technical information and advice may allow me to do the trick.
As an alternative solution, it would be possible to make the trick directly inside DemulShooter: making your tool to "scale" the mouse coordinates so that they would fit to the shrinked D3D image altred by DxWnd.
If you want to know the whole story, you can peek here: https://sourceforge.net/p/dxwnd/discussion/general/thread/9295cffb/#e56f (I hope a link to another board is allowed here....)
speedracer50
[/quote]
the latest build gives you a folder DEmul v0.7 111117 and if you try to run Demul Shooter with that argument it says it is not recognized....i wouldn't put it past me to be putting in something wrong though  ;D
[/quote]
[/quote]
right now i have trigger set up for left mouse on screen and right mouse off screen. i know it works fine with full screen i was just trying to leave it 4:3 with a bezel instead of stretching it out to 16:9 but oh well i am just glad it works thanks for all your help.
p.s. it now works when launched from RL as well.
argonlefou
Hmmm on my computer Demul doesn't stretch games in fullscreen, I have black borders on each side and the game is in 4:3 format
There is an aspect ration option for this in demul menu I think
Anyway, glad to hear you settled this  :cheers:
Hello ! Nice to have you here...your software is a genius thing !
I totally get the issue, I posted some explanation on your Sourceforge thread  ;)
« Last Edit: June 13, 2018, 02:28:33 am by argonlefou »
ghotik
First of all, thank you very much for giving such a clear explaination. It corresponds pretty much to what I feared it could be going on.
Given that DxWnd seems to grow in popularity to manage weird situations, I hope you could consider a possible (and I believe cheap) extension to your tool where the desktop resolution is not (by default) determined by direct measure, but rather configured as additional (and optional) parameters.
That would manage this situation perfectly: on a 640x480 desktop, DxWnd would run the emulator at 1280x768 and resizing its video output, while DemulShooter would get the device input and mapping it to the configured 1280x768 coordinate range before injecting it to the emulator.
In addition (I don't know if you ever considered this possibility) this feature would be useful when you would extend your tool for networked interface, where the input could be read from a host whose resolution doesn't correspond to the desktop size of the target networked host where the emulator is running. But it's only a weird idea.
P.s. I found no trace of source code and I got the impression that DemulShooter is NOT open source. If I was mistaken, my apologies and if sources are available I could consider to make the patch by myself.
