Author Topic: Alchemy: Video Pinball Shmup Table  (Read 136076 times)
Gamester
Re: Identity Crisis! : Morphing Pinball Shmup Table
« Reply #320 on: March 27, 2013, 01:53:59 pm »
The entire front end should be working out of memory.  Game loads, maaaybe, but I'm thinking that disc speed isn't your issue here.   This is more of a "how fast can you process the paperwork" sort of thing and not "how fast can you read the paperwork".
Not sure I agree here CT.  Yes, maybe the base program code is always in memory, but it doesn't seem likely that every theme -- each usually consisting of video and backglass graphics -- and every table could possibly be resident in memory at all times.
Based on everything I've seen/heard over on the pin forums, SSDs can make a pretty substantial improvement in not only load/exit times for the tables, but also the performance when browsing tables.
Performance aside, I think an SSD is just smart in pincabs, as they are usually getting jolted around during play, by design.  Mechanical drives don't generally take to that kind of treatment well over time...  :)
« Last Edit: March 27, 2013, 01:56:30 pm by Gamester »
« Reply #321 on: March 27, 2013, 02:08:19 pm »
No, not all of them, but there is no way it should be so slow on disc io that it's taking multiple seconds to load a backglass image.
If so many people are saying it I'll believe it.  I don't think the issue is the machine, though.  Design logic here would say it's the application.  We're talking about a physical device local to a 64 bit bus that can push out over a hundred meg a second.  How big are these backglass images?
That's probably a point but I bet the contents/software will outgrow the drive before the drive dies.
Gamester
« Reply #322 on: March 27, 2013, 03:08:49 pm »
It's not just backglass images. Each table usually also has an associated preview video which can range anywhere from 3-25MB in size.  A full compliment of tables can easily consist of a 2-3GB of videos and backglass images.
That being said, I think some of it really may just be a matter of faster hardware covering up code/design inefficiencies.  This is glaringly evident with the pinball emulators themselves.  There is no valid reason it should take the kind of horsepower that people are having to throw at these pin applications to get smooth game play.  But for those apps it really just boils down to antiquated engines that have had years of hacks, band-aids, scripts and add-ins tacked on to get all of the functionality that we have today.  The problem is it's all woefully inefficient, and the only easy way to overcome those issues is to simply throw more horsepower at the problem.
There are some new projects under way that aim to address these issues, but who knows how long it will take for those to come to fruition.
Well, it's not like heat or some other factor that would cause gradual degradation.  All it takes is one jolt that's just a little too hard to do instantaneous (and often catastrophic) damage.  :)
« Last Edit: March 27, 2013, 03:18:34 pm by Gamester »
Drnick
  • Plodding Through Life
« Reply #323 on: March 27, 2013, 03:13:36 pm »
I can vouch for this,  Take 1 wife hoovering with cables where they should not have been, 1 x 1TB Hdd,  1 x 2" Drop and you have 1 x very unhappy hubby.  I can laugh now but I lost sooooo much data that day.
« Reply #324 on: March 27, 2013, 03:37:10 pm »
It's pretty hard to jolt one small device reasonably mounted inside a 400lb cabinet.  Put the drive on some sort of cushioning and you'll have to flip the cabinet over to for it to matter.
« Reply #325 on: March 27, 2013, 03:43:49 pm »
OMG let the dude do his thing!  Where's your VPIN build?
« Reply #326 on: March 27, 2013, 03:48:37 pm »
Nobody is criticizing griffindodd.  We've been doing this since the thread started.  Notice nobody has said "SSD isn't faster".  It is, clearly.  We're debating why it's faster and the software itself.  This is positive discussion.
  • Online Online
  • Last login:Today at 10:39:31 pm
« Reply #327 on: March 27, 2013, 06:28:04 pm »
Anyone else got any super clever names for something that constantly morphs?
Schizopinia -- From schizophrenia.
** Before anyone asks: Yes, I do know that schizophrenia is not the same as DID or MPD.
Transmogrifier -- From the root word transmogrify which means to change into a different shape or form, especially one that is fantastic or bizarre.
Alchemy -- Alchemy (2nd definition) A seemingly magical power or process of transmuting.
Some other variant of transfigure or transmute.   :dunno
Tim Conway: "In canis corpore transmuto"   :lol
If you want more of a Native American vibe, you could try Pin-walker (Skin-walker)
griffindodd
  • Builds Stuff
« Reply #328 on: March 27, 2013, 06:32:02 pm »
Scott, I'm sure you have embedded some kind of brain-scanning probe in my ear via these forums with your wizardry and spells. My original concept for the cab was 'Addams Family: Schizophrenia' as I thought it was originally going to take a TAF clone look and transform between games.
PL1 IS IN MA HID!!!!!!!!!!!!!! GET OUT  :banghead: GET OUT  :banghead:
I drink and I know things.
  • Online Online
« Reply #329 on: March 27, 2013, 07:34:56 pm »
Careful . . . those implants are expensive!
Don't make us re-abduct you.
« Reply #330 on: March 27, 2013, 07:40:40 pm »
You can only call it a transmogrifier if you make it look like a cardboard box and have Calvin coming out of it.
« Reply #331 on: March 27, 2013, 08:28:19 pm »
I really like Alchemy.  It's begging for a custom set of art and a custom table to go with it.
Felsir
  • Last login:July 09, 2025, 03:34:33 am
  • Creating cab artwork
    • Felsir's World
« Reply #332 on: March 28, 2013, 04:23:18 am »
This.
« Reply #333 on: March 28, 2013, 04:22:46 pm »
*Unless it's a clever pun, like Shoryukade.
griffindodd
  • Builds Stuff
« Reply #334 on: April 01, 2013, 10:31:11 pm »
Everything has ground to a bit of a halt of late with family vacations and such. Last few bits still dribbling in.
Thanks Zeb for all the power and force feedback gear, can't wait to electrocute myself trying to wire this up
Magstik plus (thanks Jason) and a tilt Bob for modding into a three way switch
And last but not least some speedy solid state Corsair goodness
griffindodd
  • Builds Stuff
« Reply #335 on: April 02, 2013, 06:59:53 pm »
I like this name a lot and it does ring of pinball nostalgia a little, but it is the name of a DIY pinball machine that someone made, found that on the Googlez. Something along those lines though....
Sorcery
Occamy (an alloy imitating silver)
Voodoo
Incantation
Wizardry
Mutant
Shifter
(Pinball) Wizardry is a nice play on an old theme, what do you think? I also like Voodoo
« Last Edit: April 02, 2013, 07:04:36 pm by griffindodd »
  • Online Online
« Reply #336 on: April 02, 2013, 09:07:23 pm »
As long as Wizardry doesn't get abbreviated into The Wiz:laugh2:
Of course, you could just throw TheRedOpusBXL a hat-tip and a link and steal the Alchemy name anyways.  >:D
I don't see any activity on it in the last 4 years.
« Reply #337 on: April 02, 2013, 11:41:49 pm »
I like "Voodoo" if "Alchemy" is off the table.
What about "Pinball de los Muertos", give it a Day of the Dead theme based very loosely on the art deco style seen in Lucas Art's Grim Fandango.  Custom table be representative of the 4 year journey fallen Aztec warriors must take through the nine levels of the underworld.
« Reply #338 on: April 03, 2013, 09:48:47 am »
Voodoo should be reserved for Jimi Hendrix themes.
dandro
  • Last login:July 20, 2014, 12:32:46 am
    • Link To project
« Reply #339 on: April 03, 2013, 10:22:56 am »
or simply just call it:
"The VooDoo, Incantation, Mutant - Shifting Wizard of Occamy"  :dizzy: LOL
griffindodd
  • Builds Stuff
« Reply #340 on: April 03, 2013, 11:31:37 am »
Lol, the V.I.M.S.W.O.
« Reply #341 on: April 03, 2013, 10:31:31 pm »
Somewhere a CoreyBee customer is having a horrible idea.....
CoryBee
  • Bopity Boopy
« Reply #342 on: April 04, 2013, 01:22:02 am »
Ugh.....
mcseforsale
  • Last login:August 14, 2025, 10:40:54 am
  • Creepy Mario Dude
« Reply #343 on: April 04, 2013, 12:06:16 pm »
Did you make them promise not to tell anyone who built that for them?   :laugh2:
AJ
Ugh.....
griffindodd
  • Builds Stuff
Re: Alchemy: Video Pinball Shmup Table
« Reply #344 on: April 04, 2013, 06:01:34 pm »
Well Alchemy was too good not to use, well done Le Chuck PL1! As for that other guy's machine.....  :cheers:
« Last Edit: April 04, 2013, 06:32:37 pm by griffindodd »
« Reply #345 on: April 04, 2013, 06:04:08 pm »
Grr.  Stop changing the beginning of the thread title!  Makes it hard to follow if you don't thread subscribe.
« Reply #346 on: April 04, 2013, 06:26:17 pm »
Well Alchemy was too good not to use, well done Le Chuck! As for that other guys machine.....  :cheers:
I'll take the assist, PL1 is Teh Bigu WINNAH!  What brand of pat on the back are we getting?!
griffindodd
  • Builds Stuff
« Reply #347 on: April 04, 2013, 06:28:36 pm »
Oops yeah sorry Scott, man Le Chuck is always trying to take the credit for your ideas, who let that guy in here?
griffindodd
  • Builds Stuff
« Reply #348 on: April 04, 2013, 06:29:25 pm »
How do you like your tea bag?
« Reply #349 on: April 04, 2013, 06:57:58 pm »
Harry and tattoo'd. Whaddya take me for, some kinda weirdo?
griffindodd
  • Builds Stuff
Re: Re: Alchemy: Video Pinball Shmup Table
« Reply #350 on: April 04, 2013, 07:22:42 pm »
Harry and tattoo'd.
I thought you and Harry broke up?
  • Online Online
« Reply #351 on: April 04, 2013, 08:55:52 pm »
I figure that if you tried, his response would be reminiscent of Daggett from the Angry Beavers.
 :laugh2:
Sshado
  • Last login:October 04, 2024, 06:10:57 pm
  • Sshado's Club
    • Sshado's Club
« Reply #352 on: April 21, 2013, 11:20:29 pm »
Another awesome build, how is this one coming along ?
Maximus
  • Last login:May 26, 2017, 05:32:05 pm
  • Plans are for fools!!!!
    • Arcade Icons
« Reply #353 on: April 21, 2013, 11:44:31 pm »
This is on hold while I try and clear all the less complex stuff out of the garage
Sshado
  • Sshado's Club
    • Sshado's Club
« Reply #354 on: April 22, 2013, 09:08:46 am »
Where do you live, I will help you move it  ;)
Maximus
    • Arcade Icons
« Reply #355 on: April 22, 2013, 09:26:59 am »
Lol by clear I mean finish the projects
dandro
    • Link To project
« Reply #356 on: April 22, 2013, 09:32:48 am »
He is south of us, let's go! we'll def give him more room!  ;)
Maximus
    • Arcade Icons
« Reply #357 on: April 22, 2013, 09:40:21 am »
Lil yeah no problem I'm sure the dog will be happy to eat you
Maximus
    • Arcade Icons
« Reply #358 on: April 29, 2013, 05:57:46 pm »
Still on hold, but the other projects are starting to move out of the Garage, I hope to have Donkey Kong and Paperboy complete, fully operational and in the house by next weekend. Then I want to finish up Barrel of Kong before I return to this... assuming we don't move house first
Yvan256
    • Yvan256
« Reply #359 on: April 29, 2013, 08:23:14 pm »
Thanks Zeb for all the power and force feedback gear, can't wait to electrocute myself trying to wire this up.
I know my reply is late, but frankly that's one of the funniest thing I've ever read.  :laugh:
