Author Topic: FLYNN'S ARCADE (Project Code Name: Overambitious) - FINISHED  (Read 585518 times)
vertexguy
  • ...but this one goes to 11.
Re: FLYNN'S ARCADE (Project Code Name: Overambitious) - FINISHED
« Reply #920 on: May 27, 2020, 04:39:30 pm »
I would also appreciate a lot if I could get the the files for the controls in particular
Im starting to make my own arcade, and its really hard to find any good control layout like you have on your arcade
I will also say that the result is quite impressive, I will be quite pleased if I can achieve at least half of it
I would highly recommend you research other 4 player control panels on this forum before you decide.  I too was inspired by this build, but when you do your homework, you may opt for a revised layout.  You should also consider who you are building for.  As Chance pointed out, he revised his button layouts to specifically match his hand.  You might want to do the same, or go with something more universal.  Some food for thought...
skyshadow
  • Last login:June 25, 2020, 01:47:47 am
  • Old games are the best
« Reply #921 on: May 27, 2020, 11:36:38 pm »
True, I have actually visited many other projects and read many comments about positioning
But seems quite hard to get a full layout so you can at least get a decent initial buttons and joysticks positions
I may try to use one layout, edit it a little and then try to make it on cardboard to see how it ends up
bperkins01
« Reply #922 on: May 28, 2020, 08:25:30 am »
If you are going to put any time and effort into actually building a machine - its going to cost you at least $1K  (mine was over $2K and its not nearly the scale of this one) - if you have no tools to build one its even more except the tools are reusable.
Make a mock up of the CP in particle board.  Its inexpensive.  How do you "play" a game on cardboard with it flexing, etc..?  My mock-up was set up on a bench for 2 weeks while I tweaked the height, angle and button layouts..  The only right answer is the one that fits you ..  I worked on screen angle too - but I was starting from the beginning.
Finally - what's the goal?  building a cabinet or having a cabinet?  If building one isn't first.. you may have a tough time finishing (that been my observation over time)
Good luck!
skyshadow
« Reply #923 on: May 28, 2020, 03:46:54 pm »
Good luck!
I heard about people that started projects, but once they had a functioning arcade, they didnt continued doing the rest
Actually, my idea is to just do the controls, not the rest of the cabinet, and i will put it whenever I want to play. I know its not exactly light weight, but its possible to move without major problems I think
Also, I dont have space to put a big cabinet, not even one without the monitor for now
My idea is just a fast project, not spending much. I have all the buttons, joysticks and boards. All the woods too. Im just doing the designs for the 4 players. I also read that the 3rd and 4th player usually have a wrong aligment on most projects, as they are too close to the player 1 and 2, and their elbows may collide
I do hope in the future that I have enough space to build a full arcade cabinet, maybe a new one or one for using the controls that I want to make
Thanks for the advices, I will make that mockup to see if it looks good
vertexguy
« Reply #924 on: May 28, 2020, 04:01:06 pm »
Sounds like you should consider starting a project thread. ;)
DeLFus
  • Last login:October 12, 2021, 10:58:25 am
« Reply #925 on: June 04, 2020, 04:57:18 pm »
It is an amazing job. I want to mount something like that but I don't have plans to do it. There is a possibility that you could send me the plans. Where I live there is nothing similar to be able to develop it. Thank you
ChanceKJ
« Reply #926 on: June 05, 2020, 09:59:38 am »
« Last Edit: March 19, 2021, 02:01:44 am by ChanceKJ »
Ithilien
  • Last login:August 20, 2025, 12:08:38 am
« Reply #927 on: June 08, 2020, 10:37:39 am »
Great build thread Chance! Awesome detail and pictures.
Would you happen to have a list of everything you ordered over the course of the build? I’ve seen a few partial lists throughout this thread. I’ll soon be placing my orders for my own build and am doing my best to make sure I’m not missing anything (extra shipping costs for missed items = sadness).
Cheers!
uptown47
  • Last login:December 01, 2025, 09:34:57 am
  • Just takin' life one game of Frogger at a time...
« Reply #928 on: June 09, 2020, 03:19:44 am »
Really love your cabinet mate. You've done an amazing job. The finish on it is incredible. It oozes the hard work that you've poured into it. Well done :-)
ChanceKJ
« Reply #929 on: June 09, 2020, 05:24:01 am »
« Last Edit: March 19, 2021, 02:01:48 am by ChanceKJ »
hursty_4
  • Last login:September 01, 2024, 10:56:39 pm
« Reply #930 on: June 12, 2020, 11:37:10 pm »
PM sent. :)
Could I also get a copy of those?  I'm totally jealous of your build and I'd love to try it myself.
ChanceKJ
« Reply #931 on: June 13, 2020, 10:47:39 am »
« Last Edit: March 19, 2021, 02:01:52 am by ChanceKJ »
pucci
  • Last login:Today at 12:17:27 pm
« Reply #932 on: June 14, 2020, 05:29:18 pm »
For sure! I sent you a PM!
can you send also to me?
thanks!
ChanceKJ
« Reply #933 on: June 15, 2020, 01:10:47 am »
« Last Edit: March 19, 2021, 02:01:57 am by ChanceKJ »
Ithilien
« Reply #934 on: June 19, 2020, 08:35:49 am »
I was also wondering if you had the plans for the control panel. Want to try to make this but cannot seem to find anything on the actual dimensions for it.
Could I please also get a copy?
ChanceKJ
« Reply #935 on: June 20, 2020, 02:27:22 pm »
« Last Edit: March 19, 2021, 02:02:01 am by ChanceKJ »
TyrantDawg
  • Last login:November 03, 2020, 08:55:10 am
« Reply #936 on: June 22, 2020, 08:33:29 am »
I'm really impressed with what you did with this project. I'm trying to do something similar between what you did and aspirex did with his Pathway Cabinet build. Do you think you could send me you're plans so I have a starting point? I'm trying to build it in CAD right now from scratch.
« Reply #937 on: June 22, 2020, 11:38:46 am »
I hope all you people coming with your hands out are at least subscribing to his YouTube channel or something like that....
Drnick
  • Plodding Through Life
« Reply #938 on: June 22, 2020, 02:04:52 pm »
Its a take take take, Instant gratification world out there,  Over 50% of the people who have asked for plans have all of 1 or 2 posts total here :) We need new blood building stuff, don't just hit and run with the plans, stay, show, share :)
  • Last login:Today at 07:47:22 am
« Reply #939 on: June 22, 2020, 02:52:04 pm »
A large percentage of the people that ask for plans never do anything with them. Those that do manage to start on a cab very seldom finish the project.
« Reply #940 on: June 22, 2020, 02:59:27 pm »
Chance is a nice guy. You guys should at least offer to throw a few bucks his way via PayPal.
« Reply #941 on: June 22, 2020, 03:06:26 pm »
The problem is that his YouTube channel is all in Canadian.
There are no subtitles for that.
ChanceKJ
« Reply #942 on: June 22, 2020, 03:08:45 pm »
« Last Edit: March 19, 2021, 02:02:07 am by ChanceKJ »
  • Last login:January 22, 2026, 12:55:00 pm
« Reply #943 on: June 22, 2020, 04:34:48 pm »
I dunno, I'm fine with these hit and run members.  Last thing we need is more perpetuation of bad design choices being propogated throughout the forum, and us having to constantly course-correct people on why that CP design isn't ideal.
These fly-bye'rs are not here to learn, or join a community of like-minded gamers and builders, they're here to clone and show their friends a nerd trophy.  Let them come and go, we'll keep the members who are looking to stay and contribute.
« Last Edit: June 22, 2020, 05:56:34 pm by opt2not »
jennifer
« Reply #944 on: June 22, 2020, 04:56:44 pm »
Perhaps this is true...However my house reeks of epoxy today, and Jenn has bits of carbon fiber stuck to her hair, Finish this...Or die trying.
rhinojwb
  • Last login:July 06, 2020, 04:45:42 pm
« Reply #945 on: June 24, 2020, 06:25:32 pm »
Chance, great looking build, both cabinet and CP.  Was thinking of upgrading the hardware and software in the cocktail table I built 15 years ago, but since it still works great decided to build all new and add a stand up machine to the game room.  After much searching, basing my build on your machine will hit all the marks for why I want to build a new one.  Would love to get copies of your cabinet and CP plans if possible. Thanks!
Picture of the cocktail table just for fun:
jdbailey1206
« Reply #946 on: June 25, 2020, 09:34:52 am »
I'm pretty sure every single post member in this thread is just Chance creating new accounts on different computers to get his post count up for this thread.   ;D
...Uh I mean Great build Chance!  I am building a Star Wars cab and I come here for inspiration.
Tragically Geek
  • Last login:June 13, 2021, 07:02:25 pm
  • http://discord.me/mame
« Reply #947 on: July 31, 2020, 02:12:07 pm »
Hey Chance,
Fellow Canadian here who would love to get a copy of the designs as well, if possible, please. :)
I have followed your build, and many of the ones inspired by it over the past few years with the intention of starting my own soon.
« Last Edit: July 31, 2020, 05:08:56 pm by Tragically Geek »
Questions? Want to chat? Arcade Related Discord:   http://discord.me/mame or http://discord.gg/xubHuua
ChanceKJ
« Reply #948 on: August 04, 2020, 12:14:18 pm »
« Last Edit: March 19, 2021, 02:02:15 am by ChanceKJ »
specialist168
  • Last login:July 19, 2021, 02:28:50 pm
« Reply #949 on: August 05, 2020, 01:10:58 am »
It is an amazing job. There is a possibility that you could send me the plans. If you could do this again would you put a bigger tv other then the 32 inch?  if so what do you think is good would saying this is too much? Thank you
ChanceKJ
« Reply #950 on: August 05, 2020, 02:23:07 am »
« Last Edit: March 19, 2021, 02:02:19 am by ChanceKJ »
GTchr1s
  • Last login:August 31, 2020, 02:10:30 pm
  • I'm going to build it
« Reply #951 on: August 05, 2020, 07:47:30 pm »
I made an account on this forum, to say that this build is awesome, and I am inspired.
I purchased a used cabinet on Craigslist and it is very lacking... I popped it open and was thinking, this would be really easy to build my own, the way I want. I have been pouring over builds on various sites for the last 2 weeks looking for ideas, hardware recommendations and plans. I figured the toughest part would be the PC software and games. I have already set up and old PC with Launchbox and several MAME emulators to get the games, I HAVE TO HAVE already up and running.
I am looking forward to starting a project and would be willing to PAY for the plans that you have been sharing.
Regards to the comments others have said about people that don't follow through with projects, rest assured I follow through with projects and will document my progress, as I did on this car that I restored
 :D :D :D
The build thread on the car is in the link below.
https://www.stangfix.com/threads/67-gt-390-fastback.3917/
This should be pretty easy, (and less expensive) compared to that.
ChanceKJ
« Reply #952 on: August 06, 2020, 11:27:06 am »
« Last Edit: March 19, 2021, 02:02:24 am by ChanceKJ »
GTchr1s
« Reply #953 on: August 06, 2020, 01:32:16 pm »
I did, as well as sent him a few bucks. Thanks for the super fast reply Chance!
« Reply #954 on: August 06, 2020, 01:33:15 pm »
You’re a good dude!
LTC
  • Last login:January 21, 2026, 10:53:45 am
« Reply #955 on: August 06, 2020, 06:45:10 pm »
You should start your own build thread, but if you want a head start on the project, here's your chance to get a pre-made control panel
http://forum.arcadecontrols.com/index.php/topic,163252.0.html
Nice Mustang BTW
GTchr1s
« Reply #956 on: August 06, 2020, 11:58:14 pm »
Nice Mustang BTW
Thanks for the heads up on the panel, sent PM's!!
That Mustang was a fun / frustrating / bucket list project. I'll get a lot more enjoyment / use with an arcade cabinet rather than riding around in an old, loud, no AC, no power steering, no modern safety features car..
Actually the loud part was pretty cool..
DMF
  • Last login:December 23, 2021, 06:40:10 pm
« Reply #957 on: September 03, 2020, 09:24:47 pm »
Sorry for the duplicate post if my original one ever comes through, but I'll join the piling on as well....Chance, love the design, amazing job.  A friend of my built a cabinet recently (until then I didn't even know it was a thing), and gave me all of the plans, but I ended loving the look of this one so much that I ended up just trying to replicate it instead.  I was going to "guestimate" on the control panel dimensions, but I'd love to grab the plans from you as well if you still don't mind.  Happy to contribute and share as well...almost done with the cabinet myself!
https://photos.app.goo.gl/Prz124qy5nXJ4vm77
ChanceKJ
« Reply #958 on: September 05, 2020, 10:04:59 pm »
« Last Edit: March 19, 2021, 02:02:30 am by ChanceKJ »
Doops82
  • Last login:September 22, 2020, 12:12:52 pm
« Reply #959 on: September 20, 2020, 03:30:04 pm »
Truly awesome build.  I’ve never built anything above 24” yet, but would love to have a go at something similar to this build.  Would it also be possible to send me your plans chance.
