Author Topic: Pinball Cab - MultiBall Madness [Upd 14 March. - Finished]  (Read 71606 times)
Re: Pinball Cab - MultiBall Madness II [Upd 1 Oct. - One Shot]
« Reply #80 on: October 01, 2013, 09:42:39 am »
Epic quality once again.  :notworthy:
I've come to accept that I get nothing done when holding myself to those kind of standards.  :lol
swaffar
« Reply #81 on: October 01, 2013, 12:08:36 pm »
Stop making me look bad.
My projects:
Martijn
  • Akira!
    • ModMyBox
« Reply #82 on: October 01, 2013, 01:44:56 pm »
I just don't show my mistakes  :P And swaffer, your build wanted me to make mine  :cheers:
p.s. Any progress on yours?
a1pharm
« Reply #83 on: October 01, 2013, 01:50:34 pm »
Martijn
  • Akira!
    • ModMyBox
« Reply #84 on: October 02, 2013, 07:04:42 am »
Ok, here is a mistake i made, but i dealt with it.
Started working on the flasher panel, it will have 5 rgb high power leds. The ledwiz has a 500mA limit so they will be locked at a save 450mA with some resistors and fuses to protect the wiz.
Draw out the hole markers
Drilled 5 holes with t bit
But as you can see the last hole is ruined, because i didn't lock the bar hard enough, it warped and the bit went crazy. Also very dangerous..
I could remake the panel , but i thought to solve this differently.
I cut out a piece of laminate.
I placed the panel on top and cut out a correct hole
All smooth
Then glued the correct hole over the bad one
All good  :applaud:
goodbye bad hole  :angel:
swaffar
« Reply #85 on: October 02, 2013, 12:24:01 pm »
All your cabinets look very professional, but I wasn't talking about quality...  I'm teaching myself as I go along.  This was the first time I ever used a router, so I'm very happy with my build, especially the DMD/speaker grill.
I meant that your progress is making me look bad.  :applaud: I started mine March 2012, and I probably won't be finished until March 2014.  :angry:
My projects:
TopJimmyCooks
Re: Pinball Cab - MultiBall Madness II [Upd 2 Oct. - Flasher Panel done]
« Reply #86 on: October 02, 2013, 01:17:05 pm »
it looks like your power switch is on the back.  typically on pinball machines it's recessed on the bottom near the front.  The back is hard to get to.  something to consider.
Looks awesome and looks even more awesome considering the tough workshop conditions.  What do you do when it snows?
sabreerbasAlpha
  • Remember those big 10ps?
« Reply #87 on: October 02, 2013, 02:46:24 pm »
Some stunning work here. Looks excellent. Looking forward to seeing this finished.  :applaud:
Martijn
  • Akira!
    • ModMyBox
« Reply #88 on: October 03, 2013, 02:51:04 am »
yes, you should be happy and proud with your build, its looking great. If you seen my builds you can see i always make them in 3-4 months.
Powers witch on the back is no problem, i like the connectors and buttons in the back, its not a full size pinball cab and standing on its on, getting back there is the same as my arcade cabs, no problems.
Snow is a problem, ill probably finish woodworking end of Oct. Beating the cold
Martijn
  • Akira!
    • ModMyBox
« Reply #89 on: October 03, 2013, 10:06:13 am »
Some daily news update
Forgot to mention it can stand now, so this pic is a small roll back
Finished the bottom grills
This one is for the woofer
and this one is for the air intake
Now for the weather  :cheers:
rablack97
Re: Pinball Cab - MultiBall Madness II [Upd 3 Oct. - I can stand]
« Reply #90 on: October 03, 2013, 10:16:49 am »
Highlight of my day to see your updates   :applaud: :applaud: :applaud:
stinkyrob
  • Last login:January 17, 2023, 02:52:21 pm
« Reply #91 on: October 03, 2013, 11:16:52 am »
I'm new to ArcadeControls, and watching build threads like these have been absolutely great!  Thank you for sharing  :)
swaffar
« Reply #92 on: October 03, 2013, 02:32:25 pm »
Welcome to the site.  When can we expect a mini-pinball cab thread?
My projects:
Martijn
  • Akira!
    • ModMyBox
« Reply #93 on: October 07, 2013, 10:51:02 am »
Small update
I mounted the flasher panel with glue and screws
And started laminating the top and visible inside part of the cab. I just cut out a straight piece of laminate and with the correct angle, then glue it to the side and trim it
Checking the weather its getting colder in a week, so fighting the clock here :P
I ordered more then a month ago that new plunger unit, sadly its still not shipped, site stated 2-3 weeks till shipping, but he got behind in work or something..
Because i wanted to finish the bottom unit this week , now ill just drill the plunger holes later..  :-\  (Don't like drilling and vacuuming the cab again with hardware installed)
swaffar
Re: Pinball Cab - MultiBall Madness II [Upd 7 Oct. - Plunger, where art thou?]
« Reply #94 on: October 07, 2013, 12:12:17 pm »
Keep up the great work.  I really like the use of laminate.  It looks great, as always.
My projects:
keilmillerjr
  • Web Developer.
« Reply #95 on: October 07, 2013, 01:44:08 pm »
This project looks amazing! Very detail oriented.
Where did you get the aluminum grill? That might b a good option to lighten up the weight of a cab.
edekoning
« Reply #96 on: October 08, 2013, 02:44:59 am »
I bought mine at multimate.nl
Martijn
  • Akira!
    • ModMyBox
« Reply #97 on: October 08, 2013, 01:39:57 pm »
I got my perforated aluminum from a local DIY shop (Praxis)
Little update, i finished laminating the front and sides, made flipper holes, finished the back latch and started on the backbox.
I removed the II from the titel, it was in the way on some parts of the artwork  :angel:
Added a extra bar for strength
Glued 2 pieces of mdf on the sides of the speaker grill, i forgot the hole wasn't big enough for the sub to fit in it, so i elevated it a little.
Placed the woofer on top, and screwed it fastened on the pieces of mdf below
Then added 2 extra metal brackets to add extra strength to the sub and the entire cab
Then started on the backbox
And thats how she is standing now..
Also i finished up on the artwork and getting it ready for printing.
swaffar
Re: Pinball Cab - MultiBall Madness [Upd 8 Oct. - Started backbox]
« Reply #98 on: October 08, 2013, 02:36:40 pm »
Good progress today.  I'm most excited to see your DMD/speaker grill.  I was shocked at how well my second one turned out.  It was EXACTLY the right size.  Of course I drafted it up in sketchup, but it's still hard for me to trust software.
« Last Edit: October 08, 2013, 02:40:30 pm by swaffar »
My projects:
Martijn
  • Akira!
    • ModMyBox
« Reply #99 on: October 12, 2013, 07:18:19 am »
Some more progress on the cabinet. I finished the bottom mostly, still waiting for the plunger kit. And almost done with the backbox. I have also installed hinges for the backbox, i was uncertain i would install them, the pinball cabinet is not that big and the top could be easily removed. But i went for it and cut the hinges up and mounted them , had some trouble with installing them, i forgot how wide the screw in part was, so i removed 1.5cm from the sides.
Cut them up and drilled new holes
Ready
All my panels have non visible hinges
Still need to cut the DMD hole and laminate the piece, then apply artwork and t-molding and then hardware + wiring.
Oh did i mention i still don't have my plunger (6 weeks now, still not shipped!)  :banghead:
a1pharm
Re: Pinball Cab - MultiBall Madness [Upd 12 Oct. - Hinges]
« Reply #100 on: October 12, 2013, 12:40:00 pm »
Lookin sweet.  Superb craftsmanship, as always
tron84
  • Last login:November 15, 2017, 06:45:56 am
« Reply #101 on: October 12, 2013, 01:48:01 pm »
Zoinks!!!!!
That is Beautiful as hell, truly stunning work. :applaud: :burgerking:
Even the back of the pin cab is Sweet!!!!  Wow  :cheers: :cheers:
  • Last login:February 13, 2026, 05:20:07 pm
« Reply #102 on: October 12, 2013, 03:40:16 pm »
She's a beauty.  :cheers:
AlienInferno
« Reply #103 on: October 12, 2013, 09:36:08 pm »
Can't believe I haven't seen this until now. Great  job so far. Subscribed.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
blueznl
« Reply #104 on: October 13, 2013, 06:35:50 am »
Martijn, better close of the areas around the fans, it will make them more efficient, otherwise they'll be moving air around the edges (ie. there's a shortcut between outlet and inlet).
(Het regent nu, ik hoop dat je het buitenwerk af hebt...)
Martijn
  • Akira!
    • ModMyBox
« Reply #105 on: October 13, 2013, 09:29:11 am »
Hey people, thanks for the kind words. Keeps people motivated you know  :P
Didn't think that over, i just went for a big gap for heavy breathing room. I can always close it up with plexi if needed.
Yep its raining allot today,so i covered my balcony partly with a plastic sheet. Just a few things and bringing it back inside.
Everyday when i finish a part i clean up the whole balcony and vacuum the house, my wife loves it lol , i just don't want a messy working space.
Cleanliness is next to godliness  :angel:
Oh might as well post some progress i did.
Installed the ledstrip, i didn't trust that 3m adhesive that came along with it so i hotglue every 5 cm or so
Wired them up (be sure to wire 12v to 12v, cutting the strip can easily make you mount a part upside down)
and made a hole where the cables go to the top
Sexy  8)
This ledstrip has 60 leds per 100cm and is the new 5050 model, really bright !
Finished cutting the dmd holes and laminated it
swaffar
« Reply #106 on: October 13, 2013, 10:08:31 am »
Great progress.  I'm still not sure if I'll use real hinges and cut them like you did, or if I'll make some custom hinges.
My projects:
njay
  • To Nudge or Not to Nudge !
« Reply #107 on: October 14, 2013, 02:29:21 am »
Martijn,
Good luck ! i would suggest going the pindmd route with a real plasma dmd
I also used one for my mini pin and it looks sexy and hot :)
If you are ever interested in viewing it give me a PM :) i live near Utrecht
here is a preview:
« Last Edit: October 14, 2013, 02:34:17 am by njay »
Martijn
  • Akira!
    • ModMyBox
« Reply #108 on: October 14, 2013, 02:52:12 am »
yep, only thing for you size cab would be the authentic look me thinks. when i look at your backbox, i think the wings on the hinges are also to wide to fit them flush.
Good luck ! i would suggest going the pindmd route with a real plasma dmd..
He Njay, remember me asking questions on tweakers, that was the first step to my current cab form :)
About the vishay dmd, i thought about it, money was not the problem, more the size of the dmd, the screen size would look out of place in my opinion.
njay
« Reply #109 on: October 14, 2013, 03:07:51 am »
I think you would be suprised about how it would look, i only use a 24 inch playfield monitor and 19 inch for the backbox :)
i still would consider it lol :)
anyways good luck with your build looks awesome, no build topic on tweakers?
swaffar
« Reply #110 on: October 14, 2013, 06:46:51 pm »
I agree.  I think the real DMDs look great, but I prefer keeping the proportions as close as possible.  Also, I really like changing the DMD colors to match each table instead of regular red/orange.
My projects:
kixfan
  • Last login:May 22, 2018, 06:59:26 pm
« Reply #111 on: October 14, 2013, 07:53:22 pm »
Can you clarify what size opening you created for the DMD?    A 9 inch diagonal screen seems to small?
Thanks,
Kixfan
Martijn
  • Akira!
    • ModMyBox
« Reply #112 on: October 15, 2013, 03:06:34 am »
This is a official size plan, hole for dmd and speaker
about 33 x 9 cm
i resized that hole to match the maximum width of my lcd (9" lcd)  (19,5cm x 5,4 cm)
Martijn
  • Akira!
    • ModMyBox
« Reply #113 on: October 21, 2013, 03:54:15 am »
Little update, i am still waiting for my plunger to get shipped , they promised this week. lets hope so. And i printed the artwork somewhere in my country, but i was unhappy with its result. Its still pending if i can get a refund or something else. They are very slow.. So i decided to print it at Gameongrafix, and its already shipped  :cheers:
I started working on the led flashers, i have 5 RGB leds in a row , they can get very hot and need a heatsink, so i cut up a cpu heatsink/
Cpu heatsink ready to get a new life
Cleaned it and drawn out the cut out plans
Chopping it up with my metal cutter, this material gets really hot !
Then drilling holes for screws to hold the leds
All done, backside of the leds have some thermal grease
Wired them up to a ATX connector
And mounted them
You need to have them connected to a connector because the cables need to be out of the way if you want to slide in the lcd panel
And i wired up the ledwiz some more, and added cable management sleeves
floriske.nl
Re: Pinball Cab - MultiBall Madness [Upd 21 Oct. - Leds]
« Reply #114 on: October 21, 2013, 06:52:10 am »
This project is coming along very nicely! Looking great so far.  :applaud:
swaffar
« Reply #115 on: October 21, 2013, 11:21:09 am »
Looking nice and clean.  I don't know if I'll use cable management sleeves, but I'll be cleaning up my wiring before I close it up for good.
My projects:
arno
  • Last login:August 03, 2016, 12:27:22 pm
  • ArcadeWinkel.nl
    • ArcadeWinkel.nl
« Reply #116 on: October 24, 2013, 09:36:56 am »
Really nice work Martijn! Is the artwork going to get over the lamination?
swaffar
« Reply #117 on: November 07, 2013, 11:07:57 am »
Updates, damn you!  Updates!
My projects:
Woodshop Flunky
« Reply #118 on: November 07, 2013, 11:26:16 am »
Impressive craftsmanship... as usual.  :cheers:
I'll be following this one.
Martijn
  • Akira!
    • ModMyBox
« Reply #119 on: November 08, 2013, 09:43:16 am »
Yep, sorry for the lack of updates. Cant do much until my parts arrive. Waiting for the Artwork (2nd revision), Glass and Plunger.
After almost 10 weeks the plunger has been shipped, he had many production problems, waiting for parts etc. But its on his way
21 of November will be my sons birthday, i hoped to had at least one table running. I wont rush things so that plan is canceled.
As for the rest, i got most wiring done, but i only post progress when i complete a part.
Not to disappoint anyone, here is a pic of all 3 screens running from the system. Main playfield and Backglass from the pci-e Videocard and the lcd for the DMD from the onboard graphics.
« Last Edit: November 08, 2013, 09:44:52 am by Martijn »
