Author Topic: STAR WARS: Pinball Unleashed - 46"/32"/DMD Widebody Virtual Pinball Build  (Read 86160 times)
Maximus
  • Plans are for fools!!!!
    • Arcade Icons
Re: STAR WARS: Pinball Unleashed - 46"/32"/DMD Widebody Build
« Reply #120 on: April 29, 2013, 03:49:48 pm »
PFFFFT there's hardly any dust on this VPin anywhere. You should see the excellent layer mine is building up, now that's patience!!
Seriously though well done Gamester this is looking great
TheShaner
« Reply #121 on: April 29, 2013, 05:22:04 pm »
MaxiGriff ... you have a VPin the works?
« Reply #122 on: April 29, 2013, 05:25:14 pm »
You really haven't been around, have you?
TheShaner
« Reply #123 on: April 29, 2013, 05:25:54 pm »
Apparently not.  There isnt one in his sig ...
Maximus
    • Arcade Icons
« Reply #124 on: April 29, 2013, 05:55:26 pm »
I ran out of space in my sig, which is kinda disturbing. At the risk of thread jacking ... http://forum.arcadecontrols.com/index.php/topic,130727.msg1338582.html#msg1338582
Gamester
« Reply #125 on: May 31, 2013, 01:27:09 pm »
Wow, it's been a while since I updated my build thread!  Was on vacation for a couple weeks and also diverted my attention to some real life stuff for a bit.  But in between all that I still managed to reach some major milestones on the build.
So, to catch things up...
I debated earlier in the build whether I wanted to do backbox hinges.  After much deliberation I decided that I would rather not obscure the artwork with hinges just to try to accommodate the very rare occasion where this thing will need to be transported.  Instead I opted to simply use brackets and wingnuts to allow for easy dis-assembly.  So removing the backbox is as simple as unplugging the cables inside it and unscrewing the wingnuts.  There's one of these brackets on each side.
Next I tackled the light bar.  I sandwiched two 1/2" MDF panels together, one because I wanted the lights to be very recessed and secondly to fill the gap at the back where the play field meets the light bar.
Drilled the holes for the flasher caps using a 1 1/8" spade bit, then hand routed recesses for the screw tabs.  Then just primed and painted it using a foam roller and brush.
The heatsinks on my Cree flashers do not have mounting screw holes, so I had needed a retainer to mount the LEDs to the light bar.  These are basically just blocks with holes recessed to hold the heatsinks.  The flasher cap got screwed on and then the whole assembly was attached to the light bar.
Finished product:
Originally I had also planned to include the strobes on the light bar.  After I thought about it, I decided that I didn't want those things beaming me in the face.  So I mounted them just under the front of the cab so they shine down by the player's feet.  That way you still get the effect of the strobes without the blindness.  My plan is to pick up another pair of them and mount them on the back side of the backbox.  You'll also notice in the pic that the under-cabinet accent lighting is installed.  The accent lighting is RGB and is totally configurable using an included remote control.  I have it set up to smoothly fade between colors.
Next up was the glass for the backbox.  For this I just purchased a sheet of glass from Home Depot and had my Mom, who does stained glass, size it for me.  I decided to paint on the bezel.  For that I just masked off the edges, cleaned the glass with alcohol and painted it using a foam roller and black latex.
And then wiring...lots of it.  It would have been much worse though without Zebulon's boards.
I wanted to be sure everything was functioning properly before I started bundling wire and making it all look pretty.  That's still on the to-do list.
Started the installation of the gamepad PCB for the nudge functionality.  After disassembly is when I came to the realization that the gameport to USB adapter was missing from the package.  D'oh!  To solve that I ordered a Belkin F3U200-08INCH from Amazon, which I just received.  UPDATE: this cable didn't work for me unfortunately...apparently you have to use the cable that actually comes with it.  This part of the install is to be continued.
So currently the machine is 100% playable.  All lighting and force feedback options are working perfectly.  It's amazing how much that stuff adds to the gameplay experience!  When the lights, sounds and feedback are all working together in concert, it's simply fantastic.
A few pics of the almost-finished product.
Will probably post a video of it all in action soon.  :)
« Last Edit: July 05, 2013, 07:44:05 pm by Gamester »
TheShaner
« Reply #126 on: May 31, 2013, 01:29:46 pm »
This is so totally bad ass!!! Excellent work!  :notworthy:
TopJimmyCooks
« Reply #127 on: May 31, 2013, 01:57:13 pm »
What a great looking virtual pin.  I really like it - How about a gameplay video with some nudging, etc. so we can get a feel for the lights/sounds total package?
bearzilla333
  • Last login:August 15, 2024, 10:57:11 am
« Reply #128 on: May 31, 2013, 02:23:32 pm »
 :notworthy: Wow! Very nice!
Shall we play a game? My Project
http://goo.gl/kfyfNu
« Reply #129 on: May 31, 2013, 02:28:45 pm »
DMD looks tits! Can't wait to see a video! :cheers:
ebarlow99
« Reply #130 on: May 31, 2013, 02:34:44 pm »
on point!! they are a blast!!!  :cheers:
Maximus
    • Arcade Icons
« Reply #131 on: May 31, 2013, 04:03:29 pm »
Wow just saw the pics for the first time, absolutely amazing, this looks spectacular, well done sir!!!
mcseforsale
  • Creepy Mario Dude
« Reply #132 on: May 31, 2013, 04:37:01 pm »
I will be doing a "Hey wife, come look at what can be made in the garage" thing tonight.  It's easy to grease those wheels when it looks like this badass thing.
AJ
dandro
  • Last login:July 20, 2014, 12:32:46 am
    • Link To project
« Reply #133 on: May 31, 2013, 05:02:04 pm »
AJ
I tried this once,.. but with a porno. Should have done this first because now she don't fall for it.. LOL
« Reply #134 on: May 31, 2013, 05:26:19 pm »
 :o  :applaud:  :o  :applaud:
Great execution.  Looks fantastic!
« Reply #135 on: June 01, 2013, 01:33:36 am »
AJ
 :laugh2: :laugh2: :laugh2: :cheers:
sabreerbasAlpha
  • Remember those big 10ps?
« Reply #136 on: June 01, 2013, 04:06:26 pm »
Sweet mother of god. What else is there to say about this.?. You sir have built a thing of gaming beauty  :notworthy: :notworthy:.
What an amazing build truly amazing Gamester.. This has defiantly inspired me to attempt one of these builds.. :notworthy:
  • Last login:March 12, 2026, 07:06:30 pm
« Reply #137 on: June 02, 2013, 02:58:59 pm »
Sshado
  • Last login:October 04, 2024, 06:10:57 pm
  • Sshado's Club
    • Sshado's Club
« Reply #138 on: June 07, 2013, 09:42:42 pm »
It has been a week, take some time away from playing it and post the video already ;) This is the nicest pinball build I have seen and I know I am not the only one who wants to see this thing in action  ;D
mcseforsale
  • Creepy Mario Dude
« Reply #139 on: June 07, 2013, 10:17:36 pm »
Subscribed....wait, what?
hehehehe.
AJ
Gamester
« Reply #140 on: June 07, 2013, 10:19:48 pm »
Thank you all for the compliments and for the inspiration that many of you have provided through your own projects.  This is such a great forum! :cheers:
@Sshado - Sorry to leave ya hanging bud.  Life's been a little crazy the past few weeks.  Video this weekend, I promise!  :)
darthpaul
  • Last login:March 11, 2026, 02:46:45 pm
  • Join, It's your duty
« Reply #141 on: June 07, 2013, 11:21:33 pm »
Impressive, Most Impressive.
Sith Pedestal
Automated Cabinet
Nintendo Pi
PiCubed
« Reply #142 on: June 07, 2013, 11:29:20 pm »
Can't wait to see the video. My favorite overall build this year, bar none.
Connorsdad
  • Last login:May 18, 2024, 04:28:42 pm
« Reply #143 on: June 08, 2013, 03:38:59 am »
I wish I hadn't seen this thread, I haven't finished pouring money into my cab build yet and now I see this. I'm never going to have savings again am I. Awesome job, the skills of you guys on this forum are mental :)
« Reply #144 on: June 08, 2013, 08:45:40 am »
The year's only half over! But yes, this build was executed with precision. Love the attention to the details big and especially small. IMO the only way to do a Vpin right is with a DMD. 8)
« Reply #145 on: June 08, 2013, 12:32:52 pm »
hehehehe.
AJ
« Reply #146 on: June 08, 2013, 01:12:43 pm »
Fantastic work Gamester.  I like the chrome T-molding.  It matches your MAME cabinet.   :applaud:
Gamester
« Reply #147 on: June 09, 2013, 07:11:45 pm »
Thank you all for the compliments!   :cheers:
Here's a video, as promised:
« Last Edit: June 09, 2013, 07:17:17 pm by Gamester »
Maximus
    • Arcade Icons
« Reply #148 on: June 11, 2013, 03:46:44 pm »
Looks good man, lots of fun to be had there.
Gamester
« Reply #149 on: June 11, 2013, 03:58:54 pm »
Thanks Joel.
Hopefully the video doesn't come across too pretentious.  ;)  It was an excuse to try to get some basic practice with Adobe Premiere, plus I kind of wanted to gear it toward the average Joe who stumbles across it on YouTube and get them interested enough to lure them to this site and assimilate them into our community...kinda like the Borg; once you come here and see all these cool projects, resistance is futile.   ;D  That's how it happened for me anyway.
« Last Edit: June 11, 2013, 04:02:14 pm by Gamester »
mcseforsale
  • Creepy Mario Dude
« Reply #150 on: June 11, 2013, 04:02:03 pm »
Me, too.  I was just trolling ebay/craigslist for a DK cab for the house and I stumbled in here.  Now, I'm subscribed to just about everything.  :angel:
AJ
Thanks Joel.
Hopefully the video doesn't come across too pretentious.  ;)  It was an excuse to try to get some practice with Adobe Premiere, plus I kind of wanted to gear it toward the average Joe who stumbles across it on YouTube and get them interested enough to lure them to this site and assimilate them into our community...kinda like the Borg; once you come here and see all these cool projects, resistance if futile.  ;)  That's how it happened for me anyway.
Felsir
  • Last login:July 09, 2025, 03:34:33 am
  • Creating cab artwork
    • Felsir's World
« Reply #151 on: June 28, 2013, 11:15:54 am »
Very, very cool build!
a1pharm
Re: STAR WARS: Pinball Unleashed - 46"/32"/DMD Widebody Virtual Pinball Build
« Reply #152 on: September 02, 2013, 01:36:06 pm »
Well done!
SORHP
  • Last login:January 18, 2026, 03:57:45 pm
« Reply #153 on: September 20, 2014, 01:51:21 am »
Beautiful, Bookmarking for my future Build, sorry for reviving!
Games: Super Punch Out, Fix It Felix Jr, DK, DKjr, DK3, PC10, UMK3, TRON, MS-Pac, Pac, Centipede (2x), Robotron, Galaga, Space Invaders, Street Fighter 2 CE, X-Men vs SF, BuckHunter HD, 2X Custom Vewlix, Custom Nintendo VS 3/4, Atomiswave
Nestafari
  • Last login:August 21, 2019, 09:08:58 am
« Reply #154 on: September 21, 2014, 11:33:17 pm »
Yeah
Space Simpsons cab in progress
Viktory2k1
  • Last login:May 04, 2015, 03:23:56 am
OK, I just bought my router 3-17-15! Ready to go. I forgot I was a member on this forum, been so busy with the sleds and all.  Now It's time for some pinball!!!
Any idea what that Piece of Art weighs? I bought a plunge router, is that what you used? I already have all the other tools except that circle thing. I even bought an air nailer/stapler. Man thats great! I can't say enough about it. Now you need a pool table! I wonder if you can build those.
I'll be in touch.
Vic
If it ain't broke, It's probably a good idea to take it apart anyway!
Gamester
@Viktory2k1: The router I used has both fixed and plunge bases.
Haven't weighed the machine, but as I'm sure you can imagine, it's not exactly light.
I do have a pool table -- it's just in another room. Don't think I'd want to try to build one of those.  :)
Good luck with your project!
