Author Topic: Hantarex Polo 2 28 inch questions  (Read 21474 times)
njay
  • To Nudge or Not to Nudge !
Re: Hantarex Polo 2 28 inch questions
« Reply #40 on: April 17, 2010, 09:11:41 am »
I did hook it up to my vga card to only see if the screen would garble in the bios (like my old hantarex 900 did) then my plan was to shut it of and that point and install soft15khz
but the screen always stayed white and then poof
grantspain
« Reply #41 on: April 17, 2010, 09:16:56 am »
polo 2 do not like to be fed 31khz,the HOT cannot handle it-its almost certainly a bu508a at position T22 which has blown,you can prove it by metering the centre pin of the transistor to the flyback heat shield-if you get dead short then the HOT is blown
there are a few repair places in the u.k that will fix your chassis,in general the price seems to be around £50 plus parts
I am not sure about any repair places in Holland although it may be wise to PM ckong on this forum and ask if he knows
njay
« Reply #42 on: April 17, 2010, 09:19:56 am »
Ok thanks but its not a polo 2
it just polo 25 on the psu sticker on the chassis.
but i did manage to run a 19 inch hantarex mtc 900 with the same setup , in the future how should i run my video card to the monitor then?
or should i try to find a 25 vga chassis?
grantspain
« Reply #43 on: April 17, 2010, 09:25:18 am »
you should set the video card with soft15k on a lcd and then plug the polo in
fyi polo 1 and polo 2 have the same problem with vga
njay
« Reply #44 on: April 17, 2010, 09:26:59 am »
Ok,
but the startup of the bios does not load the driver yet in windows? so i need to switch cables everytime from a lcd to my polo?
or is it just one time?
(btw thanks for your help really cool)
grantspain
« Reply #45 on: April 17, 2010, 09:39:54 am »
you set it once on your pc lcd and then it should be fine,one further thought-if you had the screen volts set far too high on the flyback transformer then that could put the monitor into trip,try turning the screen volts anti-clockwise to minimum and power on again
njay
« Reply #46 on: April 17, 2010, 09:42:01 am »
Ok i can try that
are those the two black nobs on the flyback ?
where the wires come out to the anode?
grantspain
« Reply #47 on: April 17, 2010, 09:43:57 am »
Ok i can try that
yep,focus and screen volts
njay
« Reply #48 on: April 17, 2010, 09:58:32 am »
Nope tryed it no go
you can hear the ticking noise coming from big black thing near the metal psu rack
can i run a polo star chassis for my tube  ? this would include the vga connector with 31khz right?
you wouldn't have any chassis for me buy ?
sigh man what a bummer... what to do ... if i cant get it to be fixed i will sell it all i guess
« Last Edit: April 17, 2010, 10:44:40 am by njay »
grantspain
« Reply #49 on: April 17, 2010, 10:46:33 am »
you will not find a vga chassis that fits your crt/yoke combination,I don't have any new chassis to sell at the moment
you only realistic options are to get your chassis fixed,buy a different 15khz chassis and rewire to fit or buy a complete new tri sync monitor
njay
« Reply #50 on: April 17, 2010, 10:49:24 am »
Ok,
i just saw some thread about some building the 8liners chassis to a polo 25
it has a different connector for the yoke on the chassis is it possible to use the exisiting wires from the yoke and resolder them to the new connector?
for the power issue i have a inline transformer in the cab
grantspain
« Reply #51 on: April 17, 2010, 10:59:22 am »
yeah it pretty simple to connect the 8 liners chassis but you must be sure to get the horizontal and vertical wires in the correct place or your new chassis will fry as well as any resistors on the yoke
njay
« Reply #52 on: April 17, 2010, 11:12:12 am »
Thanks for your help
but a new chassis will cost me around 180 with shipping and the risk of blowing it up again its really high
i put up 2 ads on internet one for a mechanic who can fix the chassis and 1 for a complete sale of the cabinet
i am technical with servers and computers but monitors and all goes beyond my range
i know it sounds really weak maybe but its better then blowing money in the sky everytime i try to fix it
thanks for your help !
grantspain
« Reply #53 on: April 17, 2010, 11:16:44 am »
if you get problems finding a repair person let me know as i can fix it for you although i do not usually fix chassis for non industry
njay
« Reply #54 on: April 17, 2010, 01:27:09 pm »
what would you charge for both chassis ?
njay
« Reply #55 on: April 17, 2010, 02:20:54 pm »
my father in law is willing to give it a shot
can you tell us what to ordet and to do ?
grantspain
« Reply #56 on: April 17, 2010, 02:48:47 pm »
well imo order a bu508a transistor for position T114
caps at C121 100uf 200v and C123 10uf 100v -both electrolitic 125 c rating
make sure if you replace t114 that you have a insulation sheet behind the transistor if it has a metal back,get yourself some heat conductive grease
remember electrolitic caps are polarity sensitve so make sure you get them installed the correct way around
if you get stuck and want me to fix your chassis I will charge £20 plus parts per chassis-i think you can fix this yourself though------with advice
njay
« Reply #57 on: April 18, 2010, 04:44:24 am »
See PM
thanks in advance
njay
« Reply #58 on: April 18, 2010, 05:25:40 am »
Also when the chassis is fixed i am going to order an arcadevga this will be the safest option for me not to frie the chassis again :)
njay
« Reply #59 on: April 18, 2010, 05:53:36 am »
Also what i noticed this morning on the monitor neck that two pins are slighty bend but the neck card fits anyway
should not be any problem right?
njay
« Reply #60 on: April 18, 2010, 03:59:38 pm »
any idea for the above ? the neckcard
fits but the two lower left pins are slighty curved on top
grantspain
« Reply #61 on: April 18, 2010, 04:03:30 pm »
how curved is curved?
photo please
njay
« Reply #62 on: April 18, 2010, 04:25:46 pm »
shall post a pic tommorow but the top
of the pin is slighty curved but the neck
card goes on easy
grantspain
« Reply #63 on: April 18, 2010, 04:42:31 pm »
card goes on easy
should be ok,if the pin was not making the socket then it would be a problem
njay
« Reply #64 on: April 18, 2010, 04:58:03 pm »
is it also correct i count 9 pins from left to right
then two empty spots then another pin in the triangle section
on the neck
grantspain
« Reply #65 on: April 18, 2010, 06:10:15 pm »
on the neck
yep
njay
« Reply #66 on: April 19, 2010, 05:48:16 am »
Here is your monitor noob again with a question  ;D
I ran direct 220v from the mains to the monitor with a spliced eurostyle cable , this is ok right?
what happens when its get overvoltage or under voltage is there a protector installed somewhere?
i have insulation transformer in the machine with one eurostyle connector on the back of the machine so my guess i would run a powerstrip from that then connect the monitor and pc on that strip  :applaud:
Also i noticed when the monitor worked for 4 mins lol that i had a real bad pincushion effect i read through some posts here and a lot of them say wrong chassis for the tube the guy said there where the correct ones 25 chassis for a 28 tube ... ooh well you will see them this week lol  :dunno
« Last Edit: April 19, 2010, 06:14:40 am by njay »
grantspain
« Reply #67 on: April 19, 2010, 12:59:11 pm »
hantarex polo are 230vac operation in europe,polo 2 are free range 85-255vac
If you input 230vac into a 110vac chassis you will blow the primary stage diodes/bridge and possibly the mains smoothing cap
if you put 110vac into a 230vac only monitor it may try to function but will cut out
Does not matter what mains voltage you input into free range chassis
polo 25/28 use same chassis-you will find 25" chassis will work on 29" crt as well
pincushion could be down to failure on east/west correction circuit or just a bad adjustment or east/west correction board actually missing
Polo 1 are cga low res chassis and will work with 0.900mh to 1.5mh horizontal yoke inductance and low impedence(less than 20 ohms)
njay
« Reply #68 on: April 19, 2010, 02:37:14 pm »
pff you really know a lot of monitors what's your background?
(p.s. can you check my east/west correction on my two chassis?)
grantspain
« Reply #69 on: April 19, 2010, 02:44:27 pm »
25 years as an arcade tech,work freelance now but have worked for various companies including sega and overseas also
will check the east/west correction as a matter of course-I have a feeling one of the diodes is leaky
njay
« Reply #70 on: April 19, 2010, 04:32:29 pm »
 :applaud: :applaud: :applaud:
need i say more?  :applaud:
njay
« Reply #71 on: April 21, 2010, 02:56:14 pm »
lol im tired as hell after my flight to paris and back but here goes:
since both chassis where dead but one displayed a complete white screen how i know the tube is not the problem?
something is broken? or is that not possible?
grantspain
« Reply #72 on: April 21, 2010, 03:28:37 pm »
normally a faulty tube will either not show any screen at all/if a gun is short then a colour will saturate the screen/if the shadow mask is damaged you will get the most insane gaussing effect which you cannot clear/yoke is short then either there will be no deflection on that winding or deflection circuit of chassis will fry/gone to air will give you a nice purple fireworks display around the neck area etc etc
njay
« Reply #73 on: April 21, 2010, 03:30:08 pm »
another worry disapeared  :applaud:
grantspain
« Reply #74 on: May 07, 2010, 06:15:24 am »
this is the chassis which had a white screen-fix 200v line 10ohm flame proof protection resistor o/c,4.7uf 250v cap o/c-cause incorrectly placed links on flyback repair
njay
« Reply #75 on: May 07, 2010, 07:36:16 am »
wow looks awesome graintspain thanks !! :notworthy:
grantspain
« Reply #76 on: May 07, 2010, 07:50:18 am »
yeah it looks good considering i am running it on a polo 2 crt :laugh:
one more to go-sure its the flyback judging from readings and behaviour
btw i enjoyed the 200v line fault as its the first time i have seen it on a polo-normally that fault would be down to the lm1203n or the 12v line missing or low
njay
« Reply #77 on: May 07, 2010, 08:36:57 am »
LOL i am glad you are liking my troubles :)
i am going to make a 220v cable for the chassis the connector is now haging in side the cabinet and when i trace back the wires like i did now it splits up a few times but it works, so i am going to cut the connector of leaving some cable and use a eurostyle terminal to connect it to it's own 220v cable
How are arcade monitors protected againt surges?
grantspain
« Reply #78 on: May 07, 2010, 08:41:51 am »
this particular monitor has onboard fuse rated at 3.15amp and a smps(switch mode power supply) that basically shuts down on shorts
some monitors are 110v ac only via a isolation transformer,some are 230v ac and others are what is termed free range 85-255vac operation-you must always check your model first before powering up
njay
« Reply #79 on: May 07, 2010, 08:57:06 am »
but my chassis are both 220v right?  :notworthy:
