Author Topic: Aliens Themed Cab  (Read 236613 times)
Pixelhugger
  • Last login:February 11, 2026, 06:45:00 pm
I love the curved top. Man that looks awesome. :afro:
Project mega thread HERE
Pixelhugger
How do you plan on handling the back? Did I miss that somewhere in the thread? I'm planning a curved door for mine so I'm interested to hear how you are approaching yours.
Silas (son of Silas)
You're now entering the Twilight Zone........
I was just about to pose the same question. I thought it, you posted it... Spooky
My Project MAME clone
Who is Silas?
Epyx
  • "You're an oddity"
Re: Aliens Neon Curvy Upright Horizontal Project *Joined, mount, wheels, roof* N
« Reply #203 on: November 02, 2009, 01:13:19 pm »
What is really spooky is I was just answering that and tried to post and you both beat me to it! Lol:
Thanks Pixel. Ya, Im definitely happy with how it turned out. So far no popping after about 3 weeks, so feel confident it will be fine. The back will be similarly curved but I will do that in 2 parts...a permanent top half and a removable bottom half for the computer.  The top half will have an opening but only for a UV Green 120mm fan.  The back straightens out at the midway mark going down so the removable bottom panel will not be curved, making it easier to remove etc.
So picture a similar curve extending from where the top ends down to the midway point where the back straightens, with a green UV fan. I want to get a custom Aliens picture laser cut for it.
Oh and to get the curved shape, same idea that worked well for me for the top...curved ribs that I have already put aside for the sides and some mid structure to attach the curve to.  All of them were template routed based on the back curve. so it will be a flush mount riding just shy of the t molding.
« Last Edit: November 02, 2009, 01:16:53 pm by Epyx »
Last Project
Epyx Tutorials:
Tutorials
Pixelhugger
And "Spooky" is my son's nickname. Coincidence? You decide.
@Epyx
Very interested to see your curved removable panel. (My plan is to have the top arc over the top edge and come about 10" down the back. Another panel will arc up from the bottom a foot or so. That leaves a large opening which will be covered by a similarly curved door recessed behind the two panels.) My biggest concern has been that the curved door will twist and flex . From you pics it looks like the top stayed pretty rigid when not attached. How do you plan on attaching it while keeping it removable? I've been planning on having mine bolt into position on a brace running horizontally behind it.
This'll be interesting to folllow.
Epyx
« Reply #205 on: November 02, 2009, 01:34:54 pm »
I have been using threaded inserts. So each side rib has a three threaded inserts. The outermost ribs on the roof itself have lined up threaded inserts...then I just screw the bolt in to join them together.
It is completely solid and won't move on its own or when joined to the cab.  I did the top and bottom first for this very reason...my first cab different parts of the cab weren't the same width...this time I wanted 26.5" from top to bottom with not even 1/16" variance...so far so good ;)
And looking forward to your next update Pixel!
« Last Edit: November 02, 2009, 01:41:37 pm by Epyx »
Last Project
Epyx Tutorials:
Tutorials
Gamester
« Reply #206 on: November 02, 2009, 05:01:30 pm »
Ya the lamination definitely adds to the aesthetics. With a regular paint job you tend to second guess a lot...is it smooth enough? One more sanding? Another coat?
Boy, you are NOT kidding.  I have spent 5 days trying to get mine primed and smooth.  I think it will probably look fantastic when I'm done, but I'm hating life right now...   :banghead:
Ryglore
    • The Brush Wizard
« Reply #207 on: November 02, 2009, 09:10:13 pm »
I am totally glad the painting is behind me, though I do have a few touch ups to do yet....  :cry:
I painted my boat a couple of years ago and my father taught me a technique for using these.
The finish was nothing short of amazing, it looks like it was sprayed. The trick is to only apply in one direction with the pad and never ever go back over the paint in the other direction. I can't see any reason why they wouldn't be good for painting a cab too?
Failing that, a small hobby compressor and a spray gun would produce good results.
Who is Silas?
Franco B
This cab is turning out to be fantastic   :applaud:
I would love to build a laminated cab even half as good as this one day  :)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
I'd recommend adding a back just to keep dust out.
NO MORE!!
Epyx
« Reply #211 on: November 03, 2009, 10:57:42 am »
Oh for sure...as I mentioned above, the back will be fully covered...the curve will continue down to the midway point, where it straightens out and then a removable access panel will sit on the bottom half to access the pc and back of monitor (by reaching up).
Ill buy a few with my foam rollers and try that, thanks.
Ya, that was my main motivator, seeing so many nice looking laminated cabs, particularly Martijn's SF cab. Even though he's put up side art the front panels, bezel all look so pro.
Ehhhhhhhehhhhhhuhhhhh.... ahhhhhhh damn.... I jizzed in my pants!
Lol, love that clip.
Last Project
Epyx Tutorials:
Tutorials
Martijn
  • Akira!
    • ModMyBox
Looking good there Epyx. Keep it up  :applaud:
Ryglore
    • The Brush Wizard
I really hope you can get the Green paint to work. It would be a shame to laminate the front panel. IMO, I think it would hinder the look of the cab. But then again, It may be because it's what we've been looking at since the beginning.
Now get this thing finished and get back to work on the Wasteland cab.... sheesh!  :laugh:
« Last Edit: November 03, 2009, 10:21:56 pm by Ryglore »
I don't agree. I think laminate would look really good.
Who is Silas?
thatitalian
  • The Revolution Is Coming...
+1 for that. Formica would actually tie in more to the cab. It would have the same texture.
BTW, has anyone thought to laminate in this?
Yeah, I have a sample of the F1485 High Gloss on that link, but decided to go with the F1485 velvet finish instead. (see pic) It's really nice stuff, but it looked a bit too BLING for my taste.
Who is Silas?
Ryglore
    • The Brush Wizard
Thus the reason why I said "It may be because it's what we've been looking at since the beginning.". But still if there was some green laminate that would look close to the color he's looking for, it would look good. But I'm not sure about laminating the whole thing black.
The cab has a great design to it and the color scheme is part of the package. I say, if he takes his time and does the painting well, with some semi-gloss or high-gloss paint, it would still look really good next to the laminated black.
Ah.. OK I'm with you. I agree. If the correct shade of green isn't available then I would paint it instead of black laminate. I just assumed with the huge range of laminates that there would be something pretty close.
Who is Silas?
Ryglore
    • The Brush Wizard
Ah, I figured you meant laminate the front black instead of painting. But ya, I agree.
Epyx
« Reply #220 on: November 04, 2009, 11:20:18 am »
It's a special formica/wilsonart which is about $140 for a 12x8' sheet...of which I will only be using a fraction so going to try the paint option first.  I'm going to be real fussy though so if it doesn't work out Ill go the formica route in green but the paint is already there and mixed and ready so this weekend ill know if it's a go.
Last Project
Epyx Tutorials:
Tutorials
Epyx
« Reply #221 on: November 07, 2009, 07:40:16 pm »
Today I installed the upper monitor brace and test fitted my WG D9800 monitor.  I have included some pictures of the bolt holes and placement on the beams. I ended up cutting 4 notches to clear the bolts.  Tomorrow the fun begins, cutting the various panels for the front, the bezel, speaker and bottomr marquee retainer shelf and the coin door, CP and piece that joins the two.  I will also close in the light chamber of the marquee area.
The width of the bezel area is 26.5", leaving 2-5/8" from edge of viewable screen to side of cab on each side.
« Last Edit: November 07, 2009, 07:46:50 pm by Epyx »
Last Project
Epyx Tutorials:
Tutorials
Ryglore
    • The Brush Wizard
Re: Aliens Neon Curvy Upright Horizontal Project *Monitor Fitting* Nov 7
« Reply #222 on: November 07, 2009, 07:49:15 pm »
Sweet! moving along nicely.  :cheers:
Epyx
« Reply #223 on: November 10, 2009, 04:46:26 pm »
Updated the marquee and placed the order. For the price, im happy with it (even though it has "characters"! and the caption is cheesy...but I like frommage!) and not like I can't take it out and change/update it later. This is an update to the earlier one on page 1 of this thread.  26.5' x 8.5". Here is the proof that FastSigns sent me (White border is just from the proof sheet and will not be on final print):
« Last Edit: November 10, 2009, 04:52:10 pm by Epyx »
Last Project
Epyx Tutorials:
Tutorials
Ryglore
    • The Brush Wizard
« Reply #224 on: November 10, 2009, 04:54:50 pm »
Nice! The only thing I worry about is the Lens Flare in the center being too bright and making the wording tough to read.
Epyx
« Reply #225 on: November 10, 2009, 05:22:31 pm »
Ill find out after Rememberance day when I pick it up...hopefully not :)
Last Project
Epyx Tutorials:
Tutorials
Ryglore
    • The Brush Wizard
« Reply #226 on: November 10, 2009, 05:24:37 pm »
if so, you could maybe get him to print up a second one on plain paper to deepen the colors.... our as you say Colours.  :lol
Luigi
  • Collecting/restoring cabs
« Reply #227 on: November 11, 2009, 01:50:57 am »
I just can't hold back any more......this is AWESOME  :notworthy: :applaud:
Can't wait to see the lit balltops on that sweet CP :)
Just one question: did you have to pay some sort of tax when you received my sticks?
Thorsten's Led Balltops+ Hollow Shafts
$65
Total = Ouch...so much for the cheap upgrade lol but it's done the way I want it, that's what counts but safe to say next build will be a while.
26 Euros are 41 CAN$....what happened??  ???
« Reply #228 on: November 11, 2009, 03:30:23 am »
Exchange, and most likely duty. Especially from the UK. Wretched Canadian customs!   :banghead:
thatitalian
« Reply #229 on: November 11, 2009, 06:15:36 am »
Hmmmmm, I always seemed to get bumped with customs, yet other UK BYOACers seem to get nowt!
Yet another way we get bumped by the taxman! Have I mentioned stamp duty?...
Franco B
« Reply #230 on: November 11, 2009, 10:08:50 am »
Wow, its looking awesome with the monitor in Epyx.  :)
You can beat a nice big monitor, there is nothing worse than seeing a lovely cab with a ---smurfy--- 17" CRT in it IMO.
Its a bit hit and miss if I get charged, I would say 75% of the time I get hit. I'm not too fussed about paying the tax etc but its the ~£25 charge that Parcel Farce put on for 'handling' the item that gets me.  :angry:
« Reply #231 on: November 11, 2009, 11:26:07 am »
Wow, that's harsh. In Sweden we get away with £6 for the handling part. But in Sweden we not only have to pay for the item itself, but we have to pay for the shipping as well. AGAIN!. I was soooo happy when my Japanese 360 just sailed through. :D
« Reply #232 on: November 11, 2009, 03:12:23 pm »
If only vendors would mark the packages as gifts...I know, it's illegal. :(
But honestly, even though I paid for it, whenever I get a package in the mail that is arcade related, I get giddy as if it were a present!  ;D ;D ;D
« Reply #233 on: November 11, 2009, 04:15:18 pm »
Apparently the amplifier I bought on eBay from Hong Kong was sent from my 'Good Friend Jennifer" as a 'Gift'
Who is Silas?
Epyx
« Reply #234 on: November 11, 2009, 06:46:42 pm »
It was actually $42 and no customs as it was Canada Post...was a mistype ;)
Completely agree, I have about 2.5" (from viewable screen, 1.5" from edge of monitor) on each side. That will be enough for the bezel and give me a nice big screen.
« Last Edit: November 11, 2009, 07:03:10 pm by Epyx »
Last Project
Epyx Tutorials:
Tutorials
Expressline99
  • Last login:September 16, 2020, 11:00:55 pm
  • What have I done?
« Reply #235 on: November 12, 2009, 09:58:37 am »
I have to give you uber credit for your cab... I'm Jealous...and you are inspiring me to build a cabinet from scratch.
Epyx
« Reply #236 on: November 12, 2009, 10:44:34 am »
Thanks Expressline99,
It is a lot of fun building your own cab from scratch.  Even though I would like to take on a restore one day, I get a lot out of building it myself because a lot of the fun (for me) is the design and then building and executing to that original specific design.  It is really rewarding seeing a concept materialize from a drawing, then a render etc.
When you start your scratch build, throw it up for us to see!
Look for a massive update this weekend.  All the final pieces have been cut for the front of the cabinet and the next two weeks should see things get finalized. Although a massive IT project at work is preventing weekday work..the weekends are all clear for me to build and unwind.
Last Project
Epyx Tutorials:
Tutorials
Expressline99
  • What have I done?
« Reply #237 on: November 12, 2009, 11:14:34 am »
Oh believe me it will be up here. I always need all the help/opinions I can get!
I was in IT for years working for Pacbell so I know how the long projects go. Anyway, I look forward to the update!
BTW your name "Epyx" and avatar bring back great memories from my C64 days...which I still have stuffed away somewhere.
Epyx
« Reply #238 on: November 12, 2009, 11:43:41 am »
Good stuff looking forward to it.  As for the IT...ya we are installing a new ERP package...migrating these guys from an old, old, old Unix system to a modern graphical ERP...not fun.
Yep, indeed. Summer Games I/II, California Games, Winter Games are still some of the best 2 player experiences even today. Throw in non Epyx games like Bunten's masterpiece MULE and the C64 was/is hard to beat as probably one of the best 2 player game platforms of all time.
Last Project
Epyx Tutorials:
Tutorials
Gamester
« Reply #239 on: November 12, 2009, 12:31:23 pm »
Cool Epyx!  Looks like you and I are on a similar time line for completion.  My goal is to be able to spend the U.S. Thanksgiving holiday (in about 2 weeks) PLAYING a finished cab!
Can't wait to see yours finished!   :cheers:
