Author Topic: How to secure video card to side mounted motherboard  (Read 3299 times)
Negativecreep0
  • Last login:November 28, 2020, 10:59:49 am
« on: July 29, 2008, 10:41:52 am »
ok so my motherboard is mounted vertical in my cabinet and the video card slides into the vid slot. This is not a problem however when some intense action starts going and the cab starts shaking a lil, you can see the vid on screen kinda jiggle. Im pretty sure this is due to the vid card moving in the slot...... any ideas on how to secure it?
brock.sampson
  • Last login:May 31, 2018, 10:11:41 pm
Re: How to secure video card to side mounted motherboard
« Reply #1 on: July 29, 2008, 11:04:08 am »
I recently added a decased computer to my cab as well.  I run a component dongle off of mine and the card drooped because of the cable weight.  I bought a wood stake at the hardware store cut it to length and made a slot in the middle for the cables to pass through.  I glued and nailed that to the plywood that the mobo is mounted to and then screwed the card to the stake.  It's really solid and doesn't droop any more.  Attached is an awesome paint rendition.  I can take some pics when I get home tonight if you like.
DOC! YOU HAVE A TABLE OVER THERE WITH A SIGN THAT SAYS, "LASER DEATH RAY BARGAIN BIN!"
lettuce
  • Make It So!
« Reply #2 on: July 29, 2008, 12:07:41 pm »
I just got a heavy duty dome head screw and screwed it into the wood. I had to file down the screw shaft near the head as it was too wide to fit the gfx cards mounting hole...
Ummon
  • Trade Count: (+13)
« Reply #3 on: July 31, 2008, 11:57:49 pm »
That's a nice idea. I have a backplate laying around as well as some component cages I've thought of using for stuff like this.
Yo. Chocolate.
Stephen Hawking
severdhed
  • RIP Dinosaur Hippo
« Reply #4 on: August 01, 2008, 12:00:07 am »
that looks like a good one lettuce.  i was just thinking of ways to do this tonight.  my card is just sitting in there now, like it has been for a year or so and i havent had any problems with it yet, but i'd like to secure it..the long screw/bolt idea looks like a good one.
thatitalian
  • The Revolution Is Coming...
« Reply #5 on: August 01, 2008, 07:11:17 am »
Lettuce, where did you get those legs that are holding your motherboard to the wood (the white plastic L shape ones in the top right corner of the pic)?
I'm looking for something exactly like that!
Neilyboy
  • Last login:October 08, 2025, 08:19:14 am
  • what day is it...
« Reply #6 on: August 01, 2008, 07:34:28 am »
thatitalian. those are just pcb mounting feet.. check out the vendors in bst section to pick some up.. usually like a quarter a piece or so..
Neil
« Reply #7 on: August 02, 2008, 12:43:56 am »
I found mine at my local Radio Shack store.
~ DeLuSioNaL
thatitalian
« Reply #8 on: August 02, 2008, 01:08:51 pm »
yeah cheers! I got sum from DM!
krisbee
  • Last login:May 27, 2015, 04:55:07 pm
« Reply #9 on: August 12, 2008, 09:38:40 pm »
What I did was just use a cable clip to hold the cable to the side, and this locks in the card pretty good.
Thenasty
  • Last login:February 22, 2026, 07:36:08 pm
« Reply #10 on: August 12, 2008, 10:51:19 pm »
what I did was... I screwed my mobo in a sheet of wood (not the cabinet wall) with those plastic legs, then I screwed (glued) another piece of wood right where the video card will be seated and then I screwed a hole on the bottom of video card (some already have a hole) and I screwed it to the piece of wood underneath. Hope you got the pic.
Free VGA Breakout Cable
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #11 on: August 14, 2008, 08:02:28 am »
Just use a small blob of hot glue on the ends where the board meets the slot. It's incredibly tough stuff, non-conductive, and if you ever need to swap out just give it a quick swipe with a stanley blade.
severdhed
« Reply #12 on: August 14, 2008, 09:40:18 am »
after reading this thread the other day, and moving my cabinet...my agp card popped out of the slot for the first time.  i used standard little brass threaded motherboard stands that come with just about all PC cases.  i drilled some holes in the wood, threaded in those inserts, and then screwed the motherboard in just like it was in a pc case.  this didn't put it up high enough to allow the video card to go the entire way into the slot, so i had to bend the bottom part of the video card bracket to make it fit, so i just bent it at 90 degrees and drilled a hole in it.  then i installed another motherboard stand and screws the card to it...i is rock solid now...i'll take pics later if anyone needs them.
Ummon
« Reply #13 on: August 16, 2008, 08:40:28 pm »
Yeah, sure.
Yo. Chocolate.
Stephen Hawking
MrMojoZ
  • Last login:June 25, 2009, 11:34:56 pm
« Reply #14 on: August 18, 2008, 01:29:09 pm »
If you want to REALLY secure your cards and don't have an old motherboard try to hack up try a:
http://www.mountainmods.com/modular-io-panel-brushed-alu-p-486.html
Ummon
« Reply #15 on: August 18, 2008, 07:28:40 pm »
This is what I meant above.
« Last Edit: August 18, 2008, 07:58:21 pm by Ummon »
Yo. Chocolate.
Stephen Hawking
MrMojoZ
« Reply #16 on: August 18, 2008, 07:59:30 pm »
The one I linked has threaded hole built in that could be used to mount it into your cabinet.
