Author Topic: How do you play Q-bert?  (Read 10862 times)
Ummon
  • Trade Count: (+13)
« on: March 18, 2008, 12:35:20 am »
I don't know how many people really like this game. I always have and have a special stick for it on my panel. I haven't seen anyone mention accounting for this game in their design/set-up and am curious how those of you who do like the game play it?
Yo. Chocolate.
Stephen Hawking
TheShanMan
    • My Arcade (updated 1/30/13)
Re: How do you play Q-bert?
« Reply #1 on: March 18, 2008, 12:44:49 am »
You can alter the keymap for q-bert, using an 8 way, to only register inputs on the diagonals (i.e. requires 2 keys simultaneously). I haven't played it a whole bunch, but it seems to work fine.
Danny R
  • Last login:May 04, 2008, 02:27:43 pm
« Reply #2 on: March 18, 2008, 12:56:36 am »
You probably don't hear as much about Q-bert now because its now so easy to program a standard stick for just the diagonals, and one can use a restrictor plate to get the specific feel of the game.  And advanced sticks like the U-360 are a breeze in setting up for the game.
But only a couple years ago there were several designs of control panels that had slightly rotated 4 way joysticks mounted especially for Q-bert, which is what it sounds like you have.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #3 on: March 18, 2008, 09:50:32 am »
I have Happ Universals, so I just twist the base 45°, then turn the dial to 4-way mode.
EDIT: I've since replaced them with U360's and I'm convinced there's no better sticks out there. These play damn near EVERYTHING!
« Last Edit: April 28, 2008, 08:33:42 am by GinsuVictim »
  • Last login:Today at 03:55:38 pm
« Reply #4 on: March 18, 2008, 09:51:21 am »
I use the U360s and it's matter of loading a simple map (totally seamless thanks to FatFingers!)   :cheers:
(+_+)
  • Let me splain.
  • Last login:July 27, 2012, 09:00:32 pm
  • For I am ]{eyser Soze
« Reply #5 on: March 18, 2008, 10:23:07 am »
With my right hand.  ;)
It plays extremely well with my U360.  I'd say infinitely better than my old crappy dedicated 4 way cheapo replica pacman joystick with the small ball. Man, did I hate that piece of crap.
I think it was this one. If anyone disagrees, then it must be that I got 2 lemons.  ::) The one dedicated to Q-Bert and the other to Pacman.
http://www.happcontrols.com/joysticks/5060841125r.htm
This plan is so perfect, it's retarded. -- Peter Family Guy
milhouse
  • Last login:March 02, 2023, 08:03:32 pm
« Reply #6 on: March 18, 2008, 10:40:41 am »
U360 is awesome for q-bert (and congo bongo).
My wife is a big fan and I would have put a dedicated diagonal on my CP, but thankfully I got a U360.  Its great.
Matthew Anderson
  • Last login:September 01, 2020, 04:06:08 pm
  • What does that even mean?
« Reply #7 on: March 18, 2008, 10:56:33 am »
Don't hate me for this but....
When I play Q*Bert I play with push buttons....
*DUCKS*
I always go in the direction I want...
You might want to try it.... or not
I have a 6 button + neogeo layout and I just use
XX0
XX0  the x buttons!
Ginsu Victim
« Reply #8 on: March 18, 2008, 11:01:52 am »
^Not a bad idea actually, for those without a proper setup for playing it.
shardian
  • Trade Count: (+23)
« Reply #9 on: March 18, 2008, 11:33:26 am »
Back in the day, I had Q-bert for my gameboy. It had two control schemes: one that used the diagonals to control, and another that used the standard UDLR controls, but you had to train yourself that up was actually up/left, and so on. I prefered the latter, thus that is what I use with a standard stick. I've never even played a dedicated Q-Bert, so its all the same to me! ;D
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #10 on: March 18, 2008, 12:45:08 pm »
FWIW, you don't even need the map anymore.  Leave the u360 in analog mode and let mame do the exact same conversion but in software.  Mame modeled the analog to digital joystick conversion from u360's; both have 9x9 grids, a diagonal 4-way map, game specific remapping, etc.
So you just need the u360 and a semi-current mame.
OTOH if you use other emus, you'll need the external remap app.
Robin
Knowledge is Power
Spacedueler
  • Last login:February 16, 2026, 01:39:47 pm
« Reply #11 on: March 18, 2008, 12:49:25 pm »
Unfortunately I'm still in the planning stages of my cab. If I'd stop researching (playing the games) I might get the project started sooner. In the meantime I use the computer number keypad. I works better for me than my analog stick. I use these settings in mame to get the diagonals:
Up - keypad 9
Down - keypad1
Left - keypad 7
Right - keypad 3
Just because I like Qbert I was thinking of using the E-stik from Ultimark as my dedicated 4-way. They say you can switch it to 45 degrees by simply rotating the base while it's mounted on the CP. I think the draw back is the oval vs. round knob for authentic play of most 4way games
Unfortunately to play robotron I'm using the keypad for fire and my analog stick for movement... I gotta get that cab built...
ahofle
    • Arcade Ambience Project
« Reply #12 on: March 18, 2008, 12:55:05 pm »
I have an E-Stick which I got specifically for Qbert and 4 way games.  I now use my 8 way Super with the MAME mapping mentioned by TheShanMan because it's so much easier and works just about as well.
« Reply #13 on: March 18, 2008, 12:55:35 pm »
Does this work for 4-way, 2-way games as well?  (Using Mame .122) I would like to try something other than Mala with my U360 but really like how Fatfingers mapping works with it.  Non 8-ways were basically unplayable with my U360 until I got his Mala plug-in configured.
I'm at work so I can't try it out myself.  ;)
mrserv0n
  • Last login:May 25, 2021, 09:20:06 pm
« Reply #14 on: March 18, 2008, 01:51:54 pm »
did the original qbert cabs stick only move in diagonals?
Ginsu Victim
« Reply #15 on: March 18, 2008, 01:53:44 pm »
Yes.
Thenasty
  • Last login:February 19, 2026, 09:22:54 pm
« Reply #16 on: March 18, 2008, 02:10:21 pm »
What I did with mine  is attached LEAF Switches to my P360 Diagonally (Q-Bert/Congo Bongo) and change the Joystick with a longer shaft. Works great
Free VGA Breakout Cable
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #17 on: March 18, 2008, 02:18:58 pm »
It was a normal 4-way (like pacman), but rotated 45 degrees so it could only do "diagonals", even though to the joystick it was still up, down, left & right.  This is also why mame calls the directions as such.
So yes, and no. ;)
Yes.  Mame has automatic default maps for 8-way, 4-way, diagonal 4-way, and (sort of) 2 way games.  If the u360 is in analog mode when mame starts, mame will use the correct map.  You can also make your own maps if you don't like mame's default ones.  More info can be found in docs/config.txt, under -joystick_map option.
I don't know what you're talking about. ;D
Robin
Knowledge is Power
« Reply #18 on: March 18, 2008, 02:26:17 pm »
In Soviet Russia, Q-Bert plays you.
Ginsu Victim
« Reply #19 on: March 18, 2008, 02:26:52 pm »
Well, when I answered yes, that meant, "Yes, the original was restricted to diagonals." Of course it was a standard 4-way at 45°
I didn't get into specifics.
telengard
  • Last login:October 21, 2025, 02:12:46 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« Reply #20 on: March 18, 2008, 05:31:15 pm »
I just finished a module w/ an original Q-bert joystick.  I had a tough time orienting it though.  Looking forward to trying it.
~telengard
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
fjl
  • Pixels Rule!
« Reply #21 on: March 18, 2008, 11:20:58 pm »
paigeoliver
  • Awesome face!
« Reply #22 on: March 18, 2008, 11:43:40 pm »
I always saw that as the best possible Q*Bert option out there and is what I have done on multiple machines.
genesim
  • Last login:April 12, 2010, 08:18:42 pm
« Reply #23 on: March 19, 2008, 12:13:16 am »
I use to have the J Stick rotated, but now I have a U360 and it works great.   Just waiting on a tighter restrictor, and all will be perfect.   Great stick!!
Ginsu Victim
« Reply #24 on: March 19, 2008, 09:48:57 am »
You're the person who inspired my decision to get Universals.
EDIT: Which, as previously mentioned, have been replaced with U360s.
« Last Edit: April 28, 2008, 08:34:27 am by GinsuVictim »
Ummon
« Reply #25 on: March 19, 2008, 09:36:45 pm »
I looked that up but it doesn't say specifically. Do you have to open your CP to change it?
That's outta sight. I didn't know that.
Do you have any pictures of that?
Yo. Chocolate.
Stephen Hawking
Ginsu Victim
« Reply #26 on: March 20, 2008, 08:28:10 am »
I have a flip-up panel on the front of my CP. I just reach in to twist the base/dial.
EDIT: Not anymore. U360s...
« Last Edit: April 28, 2008, 08:36:10 am by GinsuVictim »
stan2323
  • Last login:January 13, 2023, 06:05:19 pm
  • Major Retired USS Enterprise Commanding
    • My home page
« Reply #27 on: March 20, 2008, 08:51:15 am »
*DUCKS*
XX0
XX0  the x buttons!
Tried this and it ROCKS.   :cheers:
Careful what you wish for you may get it!!
There are 10 kind of people in the world those that understand binary and those that do not!!
arzoo
  • Last login:January 26, 2025, 08:51:53 am
  • Robots WILL kill you.
    • LEDBlinky
« Reply #28 on: March 22, 2008, 07:01:11 pm »
I can't seem to get QBert to recognize my 360. When I try to set the up/down/left/right, it won't accept input from the 360 (which is in diag mode).  :dunno
Robots will kill you.
Arcade Addiction
« Reply #29 on: March 23, 2008, 09:48:12 pm »
I finally got a chance to test the automapping.  You are correct.  The newer version (.122) did not recognize diagonals on 4-way games.  Defender still recognized left and right (which is I think what you meant by "sort of") but the game was playable.  Interestingly Qbert worked fine as well.  Thanks again for the tip!  :cheers:
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #30 on: March 24, 2008, 04:14:39 pm »
Are you just talking about not accepting in game, or while remapping in-game mame too?
If the later, did you enable joysticks in mame? ("joystick 1" in mame.ini)
If just in game, try remapping in mame (tab, "Input (this game)", go to left, press enter, move stick up left, wait, repeat of other directions).
... automapping.... Defender still recognized left and right (which is I think what you meant by "sort of") but the game was playable....
Yup.  It's just the 8-way map, but signal-wise the 8-way map is just two 2-way maps superimposed on each other.
Robin
Knowledge is Power
arzoo
    • LEDBlinky
« Reply #31 on: April 27, 2008, 10:09:46 pm »
Well, I finally got back to messing with the QBert config. I do have the analog joystick enabled in mame. When the u360 is mapped as a 4-way diagonal - then the mame in-game config won't accept the diagonal mapping - I can't remap the up/down/left/right. When the u360 is mapped as an analog stick, then the mame in-game config allows me to map up/down/left/right, but these are not diagonals and the game does not play correctly - move the stick up and the game moves left/up, move left and the game moves down/left, etc. I'm running mame 121. I'm stumpted!
Arcade Addiction
ArtMAME
  • Last login:August 05, 2020, 12:59:17 pm
  • Hey where the ARCADE MACHINES at???
    • Art's Arcade Lab
« Reply #32 on: April 27, 2008, 10:47:22 pm »
I just finished a CP with standard Fighter layout plus 3" trackball plus dedicated Qbert joystick.  I used a Happ universal in 4-way mode and rotated 45 degrees.  Plays wonderfully.
"Klaatu. .. Verada. ...... Necktie...Nectar...Nickel..."
Zobeid
  • Last login:April 21, 2021, 10:36:32 pm
« Reply #33 on: April 28, 2008, 07:36:55 am »
The standard 4-way diagonal map that UltraStik comes with isn't any good for Q*Bert.  You need to make a special map that translates diagonals into non-diagonals.  Looks like this. . .
I tried this map and it worked like a charm for me.
Ginsu Victim
« Reply #34 on: April 28, 2008, 08:37:07 am »
That map actually didn't work for me. For some I had to move all the arrows counter-clockwise.
arzoo
    • LEDBlinky
« Reply #35 on: April 28, 2008, 11:11:53 pm »
Worked for me also  :applaud: Thanks!
Arcade Addiction
Jdurg
« Reply #36 on: April 29, 2008, 12:04:18 am »
Inebriated!   :P
Seriously though, I'll probably play with my 8-way joystick and just figure out how to do what I want to do.  Will probably cost me quite a few "practice" games.  ;D
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
TheShanMan
« Reply #37 on: April 29, 2008, 12:18:42 am »
Jdurg, see my post at the top. It's easy to configure an 8-way to work with diagonal games so that the diagonals work as expected.
GAJoe
  • Last login:September 05, 2012, 03:35:51 pm
  • Bluster Blaster will DESTROY YOU!
« Reply #38 on: April 30, 2008, 06:45:46 am »
Personally, I learned to play Q*Bert on the Atari 2600, so my brain is trained to play it with a regular joystick.  I considered getting an eStik for it, but couldn't justify getting a fancy stick just for it that wouldn't even feel right to me after playing Q*Bert for 20+ years the other way.
marlboroa
  • Last login:February 05, 2013, 06:41:13 pm
« Reply #39 on: April 30, 2008, 07:23:41 pm »
this is how i play Qbert
