Author Topic: First Cabinet Build: I have no idea what I'm doing  (Read 195502 times)
obizues
  • Last login:June 11, 2023, 06:17:35 pm
  • Before you start your next project, don’t.
Re: First Cabinet Build: I have no idea what I'm doing
« Reply #360 on: August 03, 2018, 12:16:24 pm »
Yup that’s the one I was going to recommend.
Well what sucks is that I will need to order the S-mount from paradise arcade and the arcade bat from somewhere else.. they don't have IL EuroJoystick in stock.
Unless you know a place where they have the IL Eurojoystick black bat in stock that also sells universal S plates.. most places I checked though only have it for a couple brands or flight sticks.
« Last Edit: August 03, 2018, 02:51:05 pm by obizues »
obizues
« Reply #361 on: August 03, 2018, 02:49:54 pm »
By the way the simplest thing would be to buy a longer shaft and mount to the bottom.  A lot of people do this and avoid routing all together.
Does anyone have the measurements on the S-plate?  I only have this router this weekend. It looks like I would have to route the part 23mm from the top and another for where the part ends since it’s provably not .75”-23mm
« Last Edit: August 03, 2018, 02:51:25 pm by obizues »
Arroyo
  • Budgets are boring
« Reply #362 on: August 03, 2018, 05:00:23 pm »
I assume you mean the Sanwa Bat Top screw on that looks like an IL bat top (I can tell you it’s not the same, close but not the same)?
Focus Attack also sells both, however their mounting plates are not universal, they are stick specific.  It looks like they have the Sanwa JLF’s but not JLW’s.
I’d call Paradise to see when they plan on getting things back in stock.  I’d also call them for the dimensions in the “S” plate, you’ll probably get a faster response then someone in the community, although I think I have one at home that I can lookup, but I’ve got a million boxes to go through with my move.
obizues
« Reply #363 on: August 03, 2018, 05:09:38 pm »
Yeah I have a message and phone call out, but there are OOO at the evo conference so I don't think I'll have much luck.
Is it needed for me to use the S plate method?  Or is that just extra security for the controller?
This is just unfortunate timing  :-\
obizues
« Reply #364 on: August 03, 2018, 05:22:45 pm »
I guess this is kind of an open question.  I currently have two sticks that are Zippy's, but after thinking about it I would like black bats for this build.
I would like a joystick that are used on the current fighting games.. so maybe getting a sanwa JLF is what I should do... Aesthetically I just want all black...
Arroyo
« Reply #365 on: August 03, 2018, 05:51:32 pm »
If your going with an IL joystick then you have a lot more flexibility, as the recommended height is:
“Happ/IL joysticks can be mounted 1/3" to 2/3" below the control panel in a 1-1/8" hole.”
http://www.slagcoin.com/joystick/attributes_brands.html#HAPP/INDUSTRIAS_LORENZO
Then you can route the bottom somewhere between 1/16”-7/16” depending on how long you want your stick to be, and then just screw in from the bottom.
JLF’s are not by default all black, they look like the ones you have.  You can get black shaft covers however, and there are some aftermarket all black shafts you can replace the standard ones with.  I know you are rushed for time, but in my opinion this is a critical decision, I’d take your time to figure it out.
obizues
« Reply #366 on: August 03, 2018, 05:58:37 pm »
[url=http://www.slagcoin.com/joystick/attributes_brands.html#HAPP/INDUSTRIAS_LORENZO]http://www.slagcoin.com/joystick/attributes_brands.html#HAPP/INDUSTRIAS_LORENZO[/URL]
Well using IL JLF sticks is something I want to do.. so I can say I've "made" that decision and worry about the heights when it is time.. but my issue is still not knowing what the dimensions of the S plate are so I can route out what I need.
  • Bitches love Centipede
« Reply #367 on: August 03, 2018, 06:07:01 pm »
 :laugh2:
%Bartop
Arroyo
« Reply #368 on: August 03, 2018, 06:40:17 pm »
4.5”
2 9/16”
1/4”
Respectively.
« Last Edit: August 03, 2018, 07:23:28 pm by Arroyo »
obizues
« Reply #369 on: August 03, 2018, 08:24:06 pm »
4.5”
2 9/16”
1/4”
 :notworthy: :notworthy: :notworthy: :cheers:
Thank you so much!
« Reply #370 on: August 03, 2018, 11:57:12 pm »
Have you thought of one of these, my friend?
« Reply #371 on: August 03, 2018, 11:57:55 pm »
In all seriousness, I prefer to carriage bolt mount my joysticks.
obizues
« Reply #372 on: August 04, 2018, 12:03:07 am »
I don’t get it.
« Reply #373 on: August 04, 2018, 12:06:02 am »
It’s a joke.
Anyhoo, I like to top mount my joys with carriage bolts because it’s authentic and I don’t have to worry about them getting pushed down into the CP.
obizues
« Reply #374 on: August 04, 2018, 12:08:26 am »
It’s a joke.
obizues
« Reply #375 on: August 04, 2018, 08:30:22 am »
4.5”
2 9/16”
1/4”
Respectively.
So the plate itself I assume is square so it’s 2 9/16” x 2 9/16”?
obizues
« Reply #376 on: August 04, 2018, 03:48:47 pm »
Here's a template for the future
obizues
« Reply #377 on: August 05, 2018, 03:57:48 pm »
Routed 1/16th inch off top for trackball flush mount.
...looking at it I should probably give myself more room on the (picture-shown) right.
Here's an updated template with instructions for S plate.
JudgeRob
  • Last login:July 13, 2024, 10:00:33 pm
« Reply #378 on: August 05, 2018, 07:27:36 pm »
You're probably overthinking it a bit.  You just outline your plate on the wood, drill out the center hole, then stick your router in the hole and rebate out the square pattern you drew on the wood.    If you looked at my build, I just cut a couple steel strips to length (doesn't need to be exact).  I painted mine bright white.  Under the metal strips are little pieces of wood which press against the stick plate.  Again, it doesn't have to be the exact thickness, because you just have to add thread locker to the threads and then slowly screw down until it feels nice and tight.
obizues
« Reply #379 on: August 05, 2018, 08:01:34 pm »
Routed:
And also door...
Ian
  • Last login:September 26, 2021, 01:50:35 am
« Reply #380 on: August 05, 2018, 08:24:51 pm »
Page 10... Only 20 more to go.
obizues
« Reply #381 on: August 05, 2018, 08:31:18 pm »
You must have a rough life.
« Reply #382 on: August 05, 2018, 09:05:03 pm »
Good job.
No concerns about the cabinet sitting flush to the wall with that cabinet handle out?
obizues
« Reply #383 on: August 05, 2018, 09:19:23 pm »
No, I wouldn’t want it flush against the wall since I have my plug also going on the back frame.
obizues
« Reply #384 on: August 07, 2018, 12:16:21 pm »
Is there an example of what someone has done in order to show the best way to cut out the artwork for a top mounted trackball?
Since the lip of the trackball housing would come up from the bottom and through the trackball plate that is flush on the control panel, I would need to be a lot more exact on cutting my artwork.
Or is it just "cut slowly?"
I figure i could lay it over the control panel, cross out the hole, and just slowly outline the hole with an exacto knife.
JudgeRob
« Reply #385 on: August 07, 2018, 09:41:51 pm »
yeah, just lay it out and cut that puppy.  Doesn't your trackball have a flange for the top?
obizues
« Reply #386 on: August 07, 2018, 09:56:45 pm »
I’m honestly not sure if this would cover anything up...
« Last Edit: August 07, 2018, 09:58:42 pm by obizues »
barrymossel
  • Spectrum
« Reply #387 on: August 09, 2018, 03:51:26 pm »
I think he should Google/search a bit more, but still he learns and accepts critics. He does better than most of us newbies.
« Reply #388 on: August 09, 2018, 03:55:41 pm »
I’m just glad he’s posting everything to one thread now. It’s progress.
Buick455
  • Last login:April 03, 2024, 03:24:29 pm
  • I MUSTA WRECKED IT!
« Reply #389 on: August 09, 2018, 05:17:46 pm »
This isn't meant to come off dick'ish, but you can use a key as a handle to open the door  :)
Order an arcade machine lock (7/8" maybe). Take that handle off, putty the screw holes & paint.. Mount the lock so the paddle part catches the door frame.
When I seen the pic all I could think of is the outhouse on the farm I spent the summer at 30+ years ago (just missing the moon cutout). Thanks for the flashback  :cheers: I haven't thought of that place in at least 20 years..
obizues
« Reply #390 on: August 09, 2018, 05:25:12 pm »
So this may sound stupid, so I should put the lock in and the latch on the inside, then twist and pull the door out with the key..?
Do you have a picture of it on an arcade?
Buick455
« Reply #391 on: August 09, 2018, 06:15:49 pm »
This is all I could find.
https://youtu.be/f-eeUCmjvVE?t=1592
JudgeRob
« Reply #392 on: August 09, 2018, 10:57:13 pm »
yeah, just use a lock like that.  Home Depo has them for a few bucks.
Not sure if this will fit yours, but see the "bezel" here.
http://www.ultimarc.com/store/section.php?xSec=10
obizues
« Reply #393 on: August 10, 2018, 08:34:13 am »
Nice!  I didn’t know they existed until now. Any clue what Home Depot calls it?
  • Last login:January 22, 2026, 03:21:17 pm
« Reply #394 on: August 10, 2018, 08:42:55 am »
Dude. Use freakin' Google every once in awhile.
obizues
« Reply #395 on: August 10, 2018, 08:59:00 am »
Jeez man... assume positive intent sometimes...
« Reply #396 on: August 10, 2018, 09:25:40 am »
its a cam lock, they might call it a barrel lock.
« Reply #397 on: August 10, 2018, 10:07:48 am »
Ultimarc sells the bezel ring
Home Depot and a million other places sell the barrel locks.
Why did you search Home depot for the bezel ring. A link to Ultimarc was provided to you.
Sorry if I come of too harsh, but this is basic comprehension. I will tone it down some, but take the time to read what is provided to you.
« Reply #398 on: August 10, 2018, 10:42:08 am »
Man, that's just a few words and a question mark shy of how my dad would use Google if he could figure it out...
%Bartop
obizues
« Reply #399 on: August 10, 2018, 05:50:39 pm »
Why would I order a bezel ring online if I can get one at Home Depot?  You also never said the words “barrel lock.”  How was I supposed to know what that’s called.
Feel free to ignore this thread if it’s so hard for your eyes to read a question, but it’s literally a project called “I have no idea what I’m doing.”
Either be helpful, chill out, or just stay out of the thread entirely if you are such a fragile flower your ego can’t handle newbie questions.
