Author Topic: 2018 Chuff thread - is it chuffy in here?  (Read 188091 times)
dkersten
Re: 2018 Chuff thread - is it chuffy in here?
« Reply #560 on: July 03, 2018, 01:07:04 am »
My vision is becoming a reality.
At about 25% power and still 2 subwoofers short, the dishes in the kitchen above are rattling in the cabinets and the bottles in the minifridge 2 levels up are bouncing around, and that is despite major efforts at soundproofing.  21,000 watts just can't be contained...
For reference, this pic is 16' wide and 9' tall.  The subwoofer enclosures are 5'6" tall and 25.5" wide.
jennifer
« Reply #561 on: July 03, 2018, 01:18:38 am »
Oh my that's just a wall of scary, I got/had a 750watt Yamaha that just blew up in testing on Halloween sound  tracks, Jenn will have to look into that seeings how I will be needing some witch cackle and chains sounds pretty soon.... I would LOVE to see the rest of that pile, you know like amps and such (please?) ...Oh andI cant see where your missing the 2 subs either ::)
« Last Edit: July 03, 2018, 01:21:48 am by jennifer »
dkersten
« Reply #562 on: July 03, 2018, 01:34:06 am »
Here's a couple from a couple months back.
The top of the right rack is for whole house audio, the rest is theater.  Emotiva didn't come out with their Atmos upgrade on that XMC-1 pre/pro yet (been saying next quarter for 2 years now) so I picked up a Marantz AV7703 as a temporary processor until the new Emotiva upgrade is out.  Amps are Emotiva XPA-3 for mains, and two XPA-5's for surround and Atmos speakers.  Subs are powered by Behringer inuke6000dsp's, 6kw each (about 3k RMS measured in reality).  Each amp has a dedicated 20a circuit, with 220v for the Emotiva amps and 110v for the Behringer amps (they don't make a 220v version here in the states).  Overkill on the electrical power, but I wanted enough for any future expansion before I started putting drywall up.  I also have dedicated 20a 110v circuits for the network, and for the pre/pro and accessories.  NVidia ShieldTV handles most of the sources for the system as it does Plex, Netflix, Amazon, and PSVue.  All my blurays are ripped without compression but I still have a UHD bluray player that will go in the rack.  There's also a 24v 350w power supply on the wall behind that rack for the LED lighting in the coffered ceiling in the theater.  It is powered off a light switch in the theater room.  Eventually I will get all my home automation stuff loaded up and set up as well.
The left rack is mostly network.  Gigabit internet coming in via fiber optic, about 75 cat5e and cat6a runs terminating at the patch panels, a 24 port PoE switch, a regular 16 port switch, and a bunch of Ubiquiti enterprise network gear (USG, cloud key, and 3 hardwired wifi AP's).  I put 7 cameras around the outside of the house and it all terminates here. Also in there is a Plex server, about 22tb of external storage, and 2 battery backups, one for the network and one that powers the projector in the theater.
jennifer
« Reply #563 on: July 03, 2018, 01:51:08 am »
"Before putting up dry wall?". OMG, There are no words, even Jenn is rendered speechless.... That's just awesome. ;D
dkersten
« Reply #564 on: July 03, 2018, 01:52:40 am »
2 more going in the back of the room.  Short and squatty but the same internal volume, same 18" drivers, and same power to them as the others.  Also not pictured is the 4 Atmos speakers and 4 surround speakers, each are DIYSG Volt 10lx's, 10" midbass drivers with coaxially mounted internal waveguides and compression drivers for the highs.  All the speakers were built in my shop, with only the drivers and SEOS waveguides purchased (all DIYSoundGroup kits).  Subs are Dayton UM18-22's from Parts Express, and each one takes about 2.5 sheets of 3/4" MDF and weigh close to 300 lbs each.
Aside from hiring out the mudding and taping, I have done 100% of this myself, from electrical and HVAC, to low volt wiring, to framing and drywall (2 layers of 5/8" drywall with green glue in between, mounted on hat channel and clips for sound proofing), riser and stage construction, all columns and trim work, paint, speaker building, acoustic design and treatments, etc.  It has been my life every evening and every weekend since Christmas and I am about 700 hours into it with almost 100 hours of work left.  I watched the first movie in there tonight, and although we were sitting on lawn chairs, I was pretty chuffed.  I will post some pics when done in a few weeks, the room is looking really good but I still have 80 cloth panels to build and a few other details, like hanging the 200lb door and finishing the air circulation system for the projector housing.
jennifer
« Reply #565 on: July 03, 2018, 02:25:33 am »
I would venture to guess few people would understand what it is your actually talking about, the size and weight of those speakers would be example. heavy as sin, almost to the point of WTH? but with that much power it can actually go though your body and the weight is cause and effect of physics, In fact heres a link to 432hz for those that might be curious to the effect of harmonics, (But be warned it is totally off topic from a BYOAC chuff ::) ....  Impressive build man, sooooo very cool. 8)
« Last Edit: July 03, 2018, 02:40:04 am by jennifer »
  • Last login:Yesterday at 02:22:29 am
« Reply #566 on: July 03, 2018, 03:27:18 am »
Giving the Casa de Yots gameroom a makeover... stay tuned...
jdbailey1206
« Reply #567 on: July 03, 2018, 07:12:42 am »
I would love to see your game room.  Your pictures are always dark.  Guess I'll have to come see it in person.
« Reply #568 on: July 03, 2018, 09:26:46 am »
They’re dark because I turn off the lights, just like an arcade. Duh.
You have a standing invitation. Stop kicking the tire and commit!
  • Online Online
  • Last login:Today at 07:53:46 am
« Reply #569 on: July 03, 2018, 10:41:24 am »
Got my copy of Apocalypse Culture II.  As I previously thought, someone has already uploaded the entire text of the Roy Shildt article to the internet, but it's missing the photos.  I've saved you $15 and attached one of the highlights.
« Reply #570 on: July 03, 2018, 11:37:19 am »
He warned you, dude!
« Reply #571 on: July 03, 2018, 11:38:01 am »
Oh, and I’ve got Richie Knucklez himself on the case looking for one for you.
jennifer
« Reply #572 on: July 03, 2018, 11:58:44 am »
Jenn has always had a strange attraction to Stunt cycle,.... Never did ever really play it much however, cause the thing would suck up quarters just as fast as you could feed it, and Mom would only usually give me $5.00, which had to last like all night (including all the other things a young girl needs  ::)) **fun fact, soda pop was only .35** pinball was usually the go to for stretching quarters, .... Just kinda curious if you can actually make it work like one would think it should?
« Reply #573 on: July 03, 2018, 12:59:21 pm »
That’s my Bronze Age section. A sit down cocktail pin from the 70s, Atari Video Pinball, and Stunt Cycle. Next to the newest game in my collection, which came out in 1999.
Stunt Cycle is fun. My record is 27 busses.
  • Last login:Today at 05:40:32 am
« Reply #574 on: July 03, 2018, 01:02:47 pm »
One of those came up for sale near me. I regret not pulling the trigger.
jennifer
« Reply #575 on: July 03, 2018, 01:16:20 pm »
Bronze age?  OMG, and here I am talking about it like it was yesterday.... (Jennifer does a suspicious edit) **What I  ment to say is I have never ever seen even seen one of those ultra cool Stunt cycles  ::)), Although27 busses sound like a lot, Almost like The Fonze doing the big jump at Arnolds before he skidded into the chicken stand.
« Reply #576 on: July 03, 2018, 02:07:30 pm »
jdbailey1206
« Reply #577 on: July 03, 2018, 03:42:51 pm »
Shark jumping or GTFO.
  • Last login:June 25, 2025, 03:09:16 pm
« Reply #578 on: July 03, 2018, 04:05:42 pm »
Stunt Cycle, Happy Days, giant speakers, Mr. Awesome.... This thread is really hitting it off on all Chuff cylinders today.
« Reply #579 on: July 03, 2018, 04:14:02 pm »
« Reply #580 on: July 03, 2018, 04:45:16 pm »
Let the chuff continue. A friend of mine gave me a little present today. It needs a little cleaning, but he told me it is in good working order. A 1952 Craftsman Jointer.
Sent from my Pixel using Tapatalk
jennifer
« Reply #581 on: July 03, 2018, 08:48:50 pm »
**Jennifer peeks over the top of her glasses..... Dude, "You got mail"
  • Last login:September 20, 2025, 07:17:24 am
« Reply #582 on: July 03, 2018, 09:16:05 pm »
Sweet!
man that thing is older than I am LOL
jennifer
« Reply #583 on: July 03, 2018, 11:13:09 pm »
Older than Da/Man? I need a moment, Its almost like seeing a unicorn >:D....**Jenn laughs at her meaness**.... Anyway Mike do not sand that deck clean, use this stuff,  https://www.theruststore.com/Boeshield-C20.aspx That rust kit is the cats meow, The remover smells like nasty acid goat barf however but works awesomely, scrub it around with a fine scotch brite, clean it off with mineral spirits/reducer and a shot of that T9 on a rag OMG, its like new again....Highly recommended.
« Last Edit: July 03, 2018, 11:23:04 pm by jennifer »
jennifer
« Reply #584 on: July 03, 2018, 11:20:52 pm »
.... Even after all this time Jennifer is still worried about Fonze. :o
« Reply #585 on: July 04, 2018, 12:18:41 am »
Check Fonzie's twitter feed. He has been doing nothing but fishing lately.
jennifer
« Reply #586 on: July 04, 2018, 01:29:51 am »
Oh look he is so dreamy and happy with his big fish, That's so my new home page desktop.... I got a feeling if Jenn got all twitter creeper and google map, I would wind up with some 500ft, pervert restraint order. :-\
« Reply #587 on: July 04, 2018, 09:26:20 am »
I heard all he had to do was snap his fingers and the fish jump into the boat. Evidently it dont work with the girls anymore.  ::)
« Reply #588 on: July 05, 2018, 02:24:14 am »
Got hooked on Adventure on the 2600. So hooked, I even did this....
« Reply #589 on: July 05, 2018, 07:15:17 am »
Going to close the Oasis on Tuesdays and Thursdays?
jdbailey1206
« Reply #590 on: July 05, 2018, 08:41:38 am »
Love me some old tools.  You can't kill them.  I borrowed my old mans router and a thick plastic piece came flying out from the inside when I was using it.  Thought I killed it.  It has been going strong with regular use for 5 years ever since.  Todays tools are nice and light but seem to die quickly.  The old girl is pictured below during my Nintendo cab build.
« Last Edit: July 05, 2018, 09:51:51 am by jdbailey1206 »
« Reply #591 on: July 05, 2018, 08:45:01 am »
The guy who gave it to me has a whole shop full of old tools that he uses everyday. His band saw is huge and it is older than the jointer. Next time I am over there I will take some tool porn pics for Jennifer.
jennifer
« Reply #592 on: July 05, 2018, 03:22:53 pm »
**SMOOCH ::)).... Oh how I miss my vintage industrial equipment, I never should have downsized, the weight and quality of old cast iron just cant be duplicated in the big box store. The milling machine in particular hit me the hardest still even today, late in the nights Jennifer walks by the empty spot and misses her old friend, And thinks of all the fun things we did together..... My jointer however was downsized to a Rockwell 4",that has some sentimental attachment, and is so tiny and cute its really hard not to love it, although the rebuild took 6mos. and with the custom stand build was a bit spendy (more so than just buying a new Jet 6" long bed) But Jenn would do still do that again today, given it can now shave wood as thin as paper. and don't really need a big one anymore.
Ian
  • Last login:September 26, 2021, 01:50:35 am
« Reply #593 on: July 05, 2018, 11:36:02 pm »
New pick up... this was on my Grail list of cabs. Check the restoration thread for more info! Will need some advice.
Drnick
  • Plodding Through Life
« Reply #594 on: July 06, 2018, 04:05:54 pm »
:applaud: :applaud: :applaud:
  • Online Online
« Reply #595 on: July 29, 2018, 04:21:10 pm »
Dr. PBJ starts her postdoc in September and we go from treading water to slaying the debt demons soon.
Grill covered in meat.
Frying my balls in the Texas sun.
Life is good, Bros.
« Reply #596 on: July 29, 2018, 10:10:44 pm »
Life is good, Bros.
You better start squirreling away cash for ZapCon 7. If you’re gonna fry your balls, do it in the Arizona sun.
nexusmtz
« Reply #597 on: August 01, 2018, 12:23:05 am »
Got to play some Computer Space at Funspot in NH this weekend. Lots of games there, but so many need repairs. Still, a good time.
  • Online Online
« Reply #598 on: August 05, 2018, 06:11:41 pm »
One of these is not like the others.
« Reply #599 on: August 05, 2018, 06:17:46 pm »
Pterodactyl?
