Author Topic: Coloring arcade buttons  (Read 1876 times)
Haloman800
  • Last login:February 07, 2020, 12:40:00 am
  • Awfully Awesome
« on: October 19, 2016, 02:16:41 am »
Here's my situation:
I'm aware of how simple it is to switch out buttons, however in order to do so I'd have to disassemble my entire cabinet (it's how the machine was assembled)
So my question is, is there any type of marker or so that I could effectively color the arcade buttons that won't easily wear off, or damage them?
The reason why I want to to begin with is, both the panel and buttons are black, and it's hard to see the buttons as a result.
Here's a pic of the control panel:
Sent from my SM-N920V using Tapatalk
Titchgamer
Re: Coloring arcade buttons
« Reply #1 on: October 19, 2016, 02:35:17 am »
I think whatever you use its likely to wear off with acidic fingers hammering them.
You are best off changing them.
Can you not disassemble the CP from the bottom?
Or remove it from the main cab to work on?
They are usually bolted through.
  • Last login:Today at 12:33:29 pm
« Reply #2 on: October 19, 2016, 03:06:00 am »
If you were starting with white buttons, I would recommend Rit Dye.
Since you're starting with black buttons, consider replacing them or getting custom vinyl decals from SlammedNiss or hand-painting a halo on the control panel around the button bezels.
danny_galaga
  • Last login:Yesterday at 12:07:45 am
    • dans cocktail lounge
« Reply #3 on: October 19, 2016, 05:28:27 am »
No.
keilmillerjr
  • Web Developer.
« Reply #4 on: October 19, 2016, 08:35:26 am »
Add vinyl "dots" to the pushbutton tops.
Thenasty
  • Last login:November 28, 2025, 10:23:55 pm
« Reply #5 on: October 19, 2016, 09:22:44 am »
how about putting a strip of led lights under that cover (TOP CRT door) directly above the buttons and you choose a color you  like of have it strobe :)
« Last Edit: October 19, 2016, 09:24:24 am by Thenasty »
Free VGA Breakout Cable
reptileink
  • An 8 bit hero
« Reply #6 on: October 19, 2016, 09:52:18 am »
Do you really need to SEE buttons? How many times do you look down at your buttons while playing??  :dunno
Once I start a game, there is no reason to look at the buttons.
vwalbridge
« Reply #7 on: October 19, 2016, 11:26:44 am »
I'd be more concerned about the button spacing on that panel than the button color.
Titchgamer
« Reply #8 on: October 19, 2016, 11:36:12 am »
Fair point that lol
Never looked at the buttons :p
  • Last login:Yesterday at 12:24:02 am
« Reply #9 on: October 19, 2016, 01:22:34 pm »
Whoever constructed that so you couldn't switch the buttons without disassembling the whole cab did their 80% wrong...
vwalbridge
« Reply #10 on: October 19, 2016, 01:29:08 pm »
