Author Topic: Addressable LED strips  (Read 2887 times)
« on: September 24, 2014, 08:26:25 pm »
Anyone else using these?  I just picked up a 5m roll to see if I can find a good use for it in my gameroom.  This video only shows a few of the modes on this particular controller.  This controller isn't programmable and only has 7 colors without brightness control.  You get like 130 modes with speed control.  Controller is independent of the strip so I could get another with different capabilities if necessary.
spoot
  • Destroyer of electronics
Re: Addressable LED strips
« Reply #1 on: September 24, 2014, 11:23:50 pm »
If you want absolute control check out NeoPixel strips and arduino to control it.
« Reply #2 on: September 25, 2014, 08:31:02 am »
Will do, thanks.  These strips have come down SO FAR in price of late that I really wish I could come up with more uses for them.
EDIT:  Just looked at the Neopixels and I think they might be the same thing I have here.  They're referring to them as "5050" and that's what this is...
« Last Edit: September 25, 2014, 08:32:55 am by ChadTower »
Sjaak
« Reply #3 on: September 25, 2014, 08:40:35 am »
You can do this, although it might be a little bit slower with neopixels.
I used LPD8806 LED strips and an arduino.
« Reply #4 on: September 25, 2014, 09:26:00 am »
A strip cut up into 8 lines?
Sjaak
« Reply #5 on: September 25, 2014, 10:00:15 am »
Yes, 8 lines and daisychained together
spoot
« Reply #6 on: September 25, 2014, 10:23:32 am »
Cool, then you can pick up an Arduino Mega for about $15.00 on fleabay and experiment.  The library includes samples for rainbow, chase, etc.  Libs, samples and demo vids can be found on Adafruit's website.
  • Last login:Yesterday at 08:11:32 pm
« Reply #7 on: September 25, 2014, 11:21:46 am »
That seems like an awful lot of work for something that would wear out its welcome in 5 minutes.
« Reply #8 on: September 25, 2014, 11:36:44 am »
With a specific timing library it looks like you can also use a Pi.  I already have a Pi.
Odds are I won't do much more than set these up as a waterfall down the stairs.  I just don't have time right now to customize it.  I need to find a way to diffuse a bit because that stairwell is dark and the LEDs are retina searing.  I might pick up some "clear" duct tape tonight and see how that looks.  I tried masking tape and it worked but looked stupid on the stairs.  :)
dkersten
« Reply #9 on: September 30, 2014, 06:24:55 pm »
Ultimarc makes a tiny controller for addressable led strips that can be used with LEDblinky, but for RGB it is only 20 channels total.
