Author Topic: Best bit for MDF?  (Read 2515 times)
GrandBofTarkin
  • Last login:July 31, 2014, 09:51:50 am
Best bit for MDF?
« on: July 30, 2014, 11:55:46 am »
Hi,
What's the best jigsaw bit and TPI to get for cutting MDF?
Cheers,
Bof
dkersten
Re: Best bit for MDF?
« Reply #1 on: July 30, 2014, 12:23:23 pm »
Depends on the type of cut you want to do.  If you are ripping a straight line, you want a thicker bit and anywhere from 8-16 tpi.  MDF is pretty soft, so you don't need something super aggressive to cut fast.  If you are scrolling tight radii, you want a good scrolling bit, and probably around 20 tpi.  Again, even a 20 tpi will cut fast through 3/4" mdf.
I use a bosche jigsaw and the t-shank bits.  I found that the thicker (wider, not deeper) blades make all the difference in the world when it comes to blade drift, but usually the thicker blades are also wider and not made for scrolling, so anything more than a slight curve and you are only grinding the blade against the guides and risking some major drift.
GrandBofTarkin
« Reply #2 on: July 30, 2014, 02:05:43 pm »
Got ya!
I've got a Bosch jigsaw too but only have coarse wood bits maybe 10 or 12 TPI. I was thinking maybe a metal bit but will take your advice.
Not doing any scrolling the cuts are all fairly straight and I'll be going real slow to keep it neat and stop the blade from wandering.
Cheers!
