Author Topic: CNC Cut Bartop Kits - Orders Open! New Models Available!  (Read 1058072 times)
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
« Reply #2160 on: October 12, 2015, 03:39:19 pm »
So, I've been slowly compiling design changes, and have been testing out some new hardware to make these kits better...  :)
Some changes are in the works!   :cheers:
I definitely don't want the suggestions to take away from what the cabinet offers.  If no changes are made at all, I still plan on getting another one.  The obstacles are space in the living room and time.  At some point my children will need to understand that making room for my toys is just as important as making room for theirs.   ;D
If you are looking to improve design, the CP mounting is probably the place, but adding to the instructions would go a lot further than design changes for me. FWIW I have the Golden Age Vertical and the kit didn't really cause the hurdles as much as I did.  Idiot proof instructions are the solution for that.
Pick what you think is the best way to mount the CP and put the recommendation in the instructions.  If people want to do something else, they will.  You can add the early speaker mounting and goldleaf type button recommendations if you agree with those.  In the end, I liked the option of putting the hole for the cable where I wanted, but it's another spot where officially giving your opinion would be nice,  The way to keep the back on is another.  I used the same velcro as the cp and it works well.
raidersan
  • Last login:November 28, 2022, 10:27:34 am
« Reply #2161 on: October 18, 2015, 07:35:39 pm »
Hi HaRuMaN,
Do you share the plans for your other variants as well? I am interested in getting the 2 player wider cabinet CNC cut here in the UK as shipping from the US is not an option. Do you have a shared repository of all your models?
Here is my current revision of the CNC plans:
https://docs.google.com/file/d/0B7Rqi_4oIj-wbDVtaWlLQ1NTQk0/edit?usp=sharing
raidersan
« Reply #2162 on: October 19, 2015, 05:35:20 am »
Hi, could you tell me what primer & paint (how many layers) you used to get that white finish?
Many thanks!
Previous pedestal kit concept:
To reality:
JDFan
« Reply #2163 on: October 19, 2015, 10:26:00 am »
Many thanks!
Don't think it is painted - they cut white Melamine panels that already had the white surface and covered the exposed areas with the t-molding.
  • Last login:Yesterday at 01:44:17 pm
« Reply #2164 on: October 19, 2015, 10:33:29 am »
Many thanks!
Correct.  That is 3/4" white melamine coated particle board.
« Reply #2165 on: October 19, 2015, 10:34:28 am »
Hi HaRuMaN,
I think you emailed me, too?  If so, just sent you an email back.   :cheers:
raidersan
« Reply #2166 on: October 20, 2015, 07:26:44 pm »
Apologies if I am being thick but you replied without any text?
The link in the initial quote from your message back in Feb only points to 1 design, I was wondering if you also shared the designs of the wider kits?
« Reply #2167 on: October 21, 2015, 11:13:19 am »
Messed up my reply using tapatalk, lol.
I have updated the first post with the wide plans, here is the link:
https://drive.google.com/open?id=0B7Rqi_4oIj-weFlwQ05NekFlRkE
SNAAKE
  • Trade Count: (+29)
« Reply #2168 on: October 21, 2015, 03:20:22 pm »
these holders on side should be optional. not everybody want those lol..
« Reply #2169 on: October 21, 2015, 03:21:29 pm »
Huh?
heykool69
  • Last login:February 07, 2019, 02:18:33 pm
« Reply #2170 on: October 21, 2015, 05:35:37 pm »
Yeah. But i think it'll be great for extra tipping support.  You know how crazy some folks are after losing a challenge :)
« Reply #2171 on: October 22, 2015, 04:34:24 pm »
New coupon, good through Nov 22, 2015.  Coupon code BYOAC saves you $10 off a purchase of $100 or more!
On a side note, 5 people used the PBJ coupon for $10 off.  Lol.   :cheers:
« Reply #2172 on: October 22, 2015, 05:01:46 pm »
What does the PBJSUX code give you?
« Reply #2173 on: October 22, 2015, 05:12:33 pm »
Absolutely nuffin
« Reply #2174 on: October 22, 2015, 05:15:42 pm »
Absolutely nuffin
Not even a free "Inspected by PBJ" Sticker?
« Reply #2175 on: October 22, 2015, 05:16:34 pm »
Absolutely nuffin
Ha!  I wonder if I can make a coupon code that gives you a free item...
« Reply #2176 on: October 22, 2015, 05:18:10 pm »
Absolutely nuffin
Dooooooo eeeeeet!
« Reply #2177 on: October 23, 2015, 01:31:55 pm »
rablack97
« Reply #2178 on: October 23, 2015, 03:37:26 pm »
I see ya sir.........the sketchup skill gettin solid... :applaud:
« Reply #2179 on: October 23, 2015, 03:40:29 pm »
Yessir!  :cheers:
raidersan
« Reply #2180 on: October 24, 2015, 06:15:32 am »
[quote author=HaRuMaN link=topic=130522.msg1539970#msg1539970 date=1445440399
[/quote]
Many thanks!
KuddlKat
  • Last login:September 08, 2022, 12:26:26 am
  • Where has the time gone?
« Reply #2181 on: October 27, 2015, 10:00:28 am »
I have a question regarding the Widescreen version.  It might sound a bit stupid, but I'll be ordering one shortly and was trying to plan it out.
(Ref:  http://shop.harumancustoms.com/index.php?route=product/product&path=59&product_id=51)
On the "admin" panel (vertical, front) there's holes for 6 buttons, 3 under each player.  What would be recommended for these, probably for a Pandora's Box (most likely) or a Mini-ITX MAME setup (later)?
I can see having Player 1/2 and Coin 1/2, but what would some of you recommend for the 3rd button on each side?  I did a CP a few years ago and have pause, menu (tab), and enter, but the grouping would look strange like that.  I have no problems drilling extra holes as necessary and prefer to keep the non-standard controls separate from the rest, but blanks always looked odd (not to mention they seem to cost more than actual buttons  ;D).
« Reply #2182 on: October 27, 2015, 10:02:53 am »
Was kind of designed with MAME in mind, so a Pause and Exit button as well.
That being said, if you only want 2 on each side, let me know when you order, and I can change it.  No charge for modifications like that.   :cheers:
TheGuy
  • Last login:January 06, 2016, 04:19:33 pm
« Reply #2183 on: October 31, 2015, 03:26:57 am »
Hello everyone,
I just ordered my first kit from HaRuMaN, and i'm very excited to get started. My brother has been wanting to buy an old arcade for quite a while, so i'm hoping to surprise him with a much nicer/more modern alternative.
Problem is, I have almost no experience with any of this with the exception of using RetroPie. Based on what i've read through the tons of pages on this thread, i'm thinking of going with the ipac-2 controller, but i'm at a loss for what buttons and other accessories I should go with. I'd like to emulate 05SRT4's build as much as possible.
Any advice you guys could give me would be greatly appreciated.
« Last Edit: October 31, 2015, 03:32:39 am by TheGuy »
Phreakwars
  • Last login:December 07, 2025, 07:04:20 pm
  • Waka-Waka
    • forum.arcadecontrols.com/index.php/topic,146325.0.html
    • My Facebook Page
« Reply #2184 on: October 31, 2015, 07:37:14 am »
Hello everyone,
Start by reading my review of it:
http://forum.arcadecontrols.com/index.php/topic,147711.0.html
That should help you choose the right buttons for you.
The Goldleaf buttons that yotsuya talks about can be found here: http://www.ultimarc.com/goldleaf.html
Speaking of which, Haruman, you should put an option on your website so that the buyer can choose with or without admin CP button holes. Would save you time on the drilling, and people wouldn't have to contact you to request it. I'd have at least 1 button for the admin CP on the right side though. There is nothing that it will get in the way of over there. Then a person could go coin and start on top, and pause on the admin CP, everything else, into the iPac shift function.
« Last Edit: October 31, 2015, 07:45:36 am by Phreakwars »
TheGuy
« Reply #2185 on: November 02, 2015, 09:44:23 pm »
Awesome. That's actually very helpful. I've ordered a couple more things for the build, and was able to sneakily get some info on what kind of art to add to the cabinet.
« Reply #2186 on: November 05, 2015, 04:11:02 pm »
I have 2 extra kits sitting here due to me getting a little slap happy with my ordering.  Both are Minitendo variety, one is black melamine, one is baltic birch.
http://shop.harumancustoms.com/index.php?route=product/product&product_id=61&tag=1+player
« Reply #2187 on: November 05, 2015, 04:12:45 pm »
Yes.  I'm working on having more customization available from the main order page to make it smoother.  Have incorporated materials already, control panel layouts should be next.
« Reply #2188 on: November 05, 2015, 05:25:55 pm »
Bro price to 85015?
« Reply #2189 on: November 05, 2015, 05:45:46 pm »
Bro price to 85015?
For which one?  Baltic Birch one is a little more
« Reply #2190 on: November 05, 2015, 05:47:33 pm »
Someone else buy these bar tops before I'm tempted.
« Reply #2191 on: November 05, 2015, 05:48:03 pm »
Save them and sell them at the knock off 2.
« Reply #2192 on: November 05, 2015, 05:51:30 pm »
Lolol
Sent from my SPH-L710T using Tapatalk
jackfrost2015
  • Last login:January 16, 2016, 11:39:31 pm
« Reply #2193 on: November 10, 2015, 09:45:57 am »
Hello All,
I'm think of buying my first kit from haruman.  I was leaning towards the Ultimate Widescreen kit.  Does anyone know if the OMNI2 joysticks and the Spectra Eclipse push buttons will fit with default control panel or would I have get it custom routed and cut.
Thanks in advanced
« Reply #2194 on: November 10, 2015, 06:22:11 pm »
Hello All,
Thanks in advanced
I would need to change the control panel for those, but that's easy enough, and no extra charge.   :cheers:
« Reply #2195 on: November 11, 2015, 10:50:01 am »
Ugh.  Something's wrong with the SQL on my shop, it's kinda working again now, but still pretty buggy.  If you need anything, let me know.  Until then I'm working with my host to sort it out.   :banghead:
« Reply #2196 on: November 11, 2015, 11:44:00 am »
Back up!
jackfrost2015
« Reply #2197 on: November 11, 2015, 12:03:03 pm »
Great thank you.   ;D Just placed the order.  i also asked if 4 holes could be added to the admin panel 2 on each side 1 for usb extention and 1 for the NovaGemCDR™ Coin Drop Replacement Pushbutton.  Thanks again,  Can't wait to get started,   ;D
« Reply #2198 on: November 11, 2015, 12:29:02 pm »
Order received, and no problem!  :cheers:
spedinfargo
  • Last login:September 28, 2023, 12:53:23 pm
« Reply #2199 on: November 20, 2015, 02:33:11 pm »
Has anyone ripped the buttons and joysticks out of an Xarcade and put them in one of Haruman's kits?  I'm tired of stumbling over my half-completed bartop every time I walk in my work room and not actually playing any games... esp. since it's winter here now and I know I won't work on it anymore until next Spring/Summer...  So I think a Haruman kit would be a good christmas present to the family (er... myself)
