Author Topic: Scratch Slim Marvel vs Capcom [14 Nov - Finished]  (Read 149733 times)
BurgerKingDiamond
Re: Scratch Slim Marvel vs Capcom [8 Aug - Volume I/O Panel Done]
« Reply #80 on: August 15, 2011, 09:12:27 am »
Nice! Jtag's are the way to go.
You can install Final Burn and you probably won't need a PC for MAME. Unless you want some of the classics. I think Final Burn is more for NEO-GEO, CPS, modern shmups.
-Welcome to the Fantasy Zone.
njay
  • To Nudge or Not to Nudge !
« Reply #81 on: August 15, 2011, 09:19:55 am »
Nice work on the jtag
was it easy to do?
Martijn
  • Akira!
    • ModMyBox
« Reply #82 on: August 15, 2011, 09:31:07 am »
Hi and yes 360 jtag is all i need. the old mame360 has been redone i think since June this year
http://www.emucr.com/2011/06/mame-072-release-2-for-xbox-360.html
It runs all the classics now fine with all the mame options you want, even preview video
with nand-x and the official jtagtool and youtube it was very easy. jtagtool is a all in one package to get it running.
I still want to test some more because xenons can really get hot, i don't want it to rrod on me.
« Last Edit: August 15, 2011, 09:43:20 am by Martijn »
  • Last login:March 04, 2026, 02:43:09 pm
« Reply #83 on: August 15, 2011, 09:58:57 am »
That's gonna be sweet in your cabinet for sure.  :cheers:
syph007
« Reply #84 on: August 15, 2011, 11:05:42 am »
Hey I bought that whisper fan as well for my 360.  It was louder than the stock one for me so I threw it out and just used some proper stealth fans in its place that I modded to fit.  I love the vantec fans as they are actually quiet.
Martijn
  • Akira!
    • ModMyBox
« Reply #85 on: August 20, 2011, 08:02:35 am »
Finalised the woodworking for the most part.
Things left to do
- artwork
- wiring
- installing all components
and the whole control panel still left to do. But i decided on the design and now i can make artwork for it.
Installed 2 noctua fans for airflow
And brought the cabinet inside and cleaned it. Picture flood :applaud:
note : switch looks like its not straight, but it is  ;D
Next to wire it all up and finishing the artwork, then work on the cp
jasonhu55
  • Last login:December 06, 2012, 10:00:53 pm
  • Mission Start....
Re: Scratch Slim Marvel vs Capcom [20 Aug - Brought my baby inside]
« Reply #86 on: August 20, 2011, 11:26:24 am »
Master :notworthy:
« Reply #87 on: August 27, 2011, 02:12:11 pm »
Very sexy pictures!  :cheers: She's a beauty.  :applaud:
DirtyDachshunds
    • First Project: MillerCade
« Reply #88 on: August 29, 2011, 09:01:18 am »
Looks great!  Very professionally done.  Congrats on the new addition
Martijn
  • Akira!
    • ModMyBox
« Reply #89 on: August 29, 2011, 10:18:13 am »
Thanks, i am still busy with the artwork, i need to have that done before i can proceed drilling holes for the cp.
I lack a lot of skill and ideas for designing and creating artwork, been using adobe photoshop a lot and learning it everytime i use it (thanks youtube).
Also with my last cab i send my drilling template local and the artwork to scott, but after drilling there was a difference in the holes, some are a few mm off. I still wonder what went wrong (was it the artwork or the printer or the drilling) , now i am scared to do that again, and will just wait for the final print and drill from that.
And for hardware part i am still experimenting with the xbox 360 heat. Doing something very insane with the 360 at the moment :P
Martijn
  • Akira!
    • ModMyBox
« Reply #90 on: August 29, 2011, 04:54:01 pm »
Just to show i am not all talk  :laugh:
Xenon xbox 360 heat problem solved  :applaud:
Bought 2 x Cooler Master Hyper 212 Plus
I wont recommend this to anyone, the CPU coolers i bought didn't fit at all, the xclam system that came along with it was to big , had to cut all the legs by 1 cm
Then drill new holes in the clamps, also needed to remove more metal from the clamps so it would fit at many places.
Then extended some Capacitors that were in the way of the heatpipes of the coolblock
Added arctic silver as CPU/gpu past instead of the what came with the CPU cooler.
With my old cooling setup i was getting 65-75 degrees in the cab
First i tried 12 volt, that was really cool, CPU and gpu didn't get above 35 degrees loaded
but the sound was terrible lol, like a vacuum cleaner
Then tried 5 volt, that was giving me CPU at 55 degrees and gpu at 42 degrees
Finally settled with 8 volt, giving CPU 48 and gpu at 35 degrees
Well i am happy with the result.
After reading on the internet that there is a new hack to get homebrew and unsigned code to run on ANY xbox i felt kinda pissed  :laugh2:
I could just get a cheap 4GB slim , its cool and low power consuming and has hdmi  :banghead:
Ah well, nothing beats doing it yourself. And still that new hack could take up to a few minutes to boot (quote : "Even in the glitch we found is pretty reliable (25% success rate per try on average), it can take up to a few minutes to boot to unsigned code."), this one boots in 12 seconds  :cheers:
« Last Edit: August 29, 2011, 04:59:15 pm by Martijn »
Re: Scratch Slim Marvel vs Capcom [29 Aug - keeping it cool]
« Reply #91 on: August 29, 2011, 06:19:25 pm »
That's not a slim 360.  :laugh2: Nice work.
CthulhuLuke
  • Last login:May 22, 2025, 01:03:42 am
  • old school
    • CthulhuLuke's Arcade Parodius
« Reply #92 on: August 30, 2011, 12:21:02 am »
Well the reset glitch hack came out today, so I wouldn't beat yourself up about it. Plus you need a Xilink proto board and some other stuff, so that'd run you another $150 just to hack it.
SNAAKE
  • Trade Count: (+29)
« Reply #93 on: August 30, 2011, 12:41:35 am »
^ damn you are alive lol..you just randomly disappeared?
DirtyDachshunds
Martijn
  • Akira!
    • ModMyBox
« Reply #95 on: August 30, 2011, 08:44:12 am »
She has a nice pair doenst she  :lol
SNAAKE
« Reply #96 on: August 30, 2011, 11:56:51 am »
yeah those are nice and fluffy..can I touch them >:D
Woodshop Flunky
« Reply #97 on: August 30, 2011, 02:43:11 pm »
That looks really cool!  Bad pun!  :banghead:
Looks like something out of Tesla's labs!  :applaud:
CthulhuLuke
  • old school
« Reply #98 on: August 30, 2011, 03:13:48 pm »
Haha yeah, real-life took over. I abandoned my old AIM nick when I started working full time, so you probably haven't seen me online in a few years. PM sent to keep clutter off Martijn's post :)
Martijn
  • Akira!
    • ModMyBox
« Reply #99 on: September 01, 2011, 09:02:08 am »
Straight from Tesla's Lab
The silent HDD  :applaud:
The hdd resonated a lot being mounted directly on the mdf.
With these 4 rubber feet its all gone now, in a completely silent room i don't hear the hdd in the cab now , or even on this testing table.
Together with the silent cool 360 setup i am happy with the total silence cool thing i wanted.
I bought 2 zalman fan mates v2 as well, to get the max out of the fans without hearing them.
Will install those this weekend and finalize the hardware part.
AND I COMPLETED MY ARTWORK  :applaud:  :applaud:  :applaud:
Send the order today to gameongraphics  :cheers: Cant wait  :P
« Last Edit: September 01, 2011, 09:09:34 am by Martijn »
gbeef
    • arcadepix.com
Re: Scratch Slim Marvel vs Capcom [1 Sep - keeping it Silent]
« Reply #100 on: September 01, 2011, 12:02:00 pm »
very nice work., whats the HD holder made from?
My cabs
4 Player Arcade
X-men Arcade Remixed
Martijn
  • Akira!
    • ModMyBox
« Reply #101 on: September 01, 2011, 12:15:06 pm »
Giant rubber suction cup rubber , normally used for camping tent poles i think.
dandare
« Reply #102 on: September 01, 2011, 12:25:07 pm »
I thought they were something OND had whipped at first glance.  :)
« Reply #103 on: September 01, 2011, 01:02:18 pm »
Your harddrive sucks!  :laugh2:
Martijn
  • Akira!
    • ModMyBox
« Reply #104 on: September 01, 2011, 01:09:52 pm »
I bet it walks around my house at night
dandare
« Reply #105 on: September 01, 2011, 07:04:25 pm »
you could stick it in your car window like one of those old Garfield toys!
Martijn
  • Akira!
    • ModMyBox
« Reply #106 on: September 05, 2011, 03:30:01 am »
The suctioncup and fanmates work great  :applaud:
Very silent Cab  :cheers: And getting good cool temps from the xbox now.
Installed fan mates for the xbox 360 fans and the cab fans
Made the setup like this
Its working  :applaud:
ill post some pictures from the inside once i have all the wires a bit more organised, i am still moving things around.
njay
Re: Scratch Slim Marvel vs Capcom [5 Sep - A Sign Of life]
« Reply #107 on: September 05, 2011, 03:46:50 am »
It's aliveeeee  :notworthy:
« Reply #108 on: September 05, 2011, 02:53:26 pm »
I like how your son has to stand on a small chair to see the screen properly.  ;D Looking great!  :cheers:
SNAAKE
« Reply #109 on: September 05, 2011, 03:39:29 pm »
thats pretty much how I started playing at the arcades lol. my brother would hold me up so I can beat up some baddies in cadillacs and dinosaurs :cheers:
aqualyricist
  • Last login:April 16, 2012, 11:51:38 pm
Re: Scratch Slim Marvel vs Capcom [26 July - Subwoofer Grill]
« Reply #110 on: September 05, 2011, 09:05:28 pm »
Hey awesome build sofar. Where did u get the ports for the usbs and the power cord port in the back bc I wanna do the same.
Martijn
  • Akira!
    • ModMyBox
« Reply #111 on: September 06, 2011, 02:30:26 am »
The power socket is something i just got from an electronic store, or you can buy them online from www.arcadeshop.de in europe.
The usb and headphone are http://www.neutrik.com/uk/en/dataconnectors/204_1047652869/USB_productlist.aspx
They have many types for any connection you can think off high quality too
clickaus
  • Last login:November 11, 2017, 04:20:47 am
« Reply #112 on: September 06, 2011, 06:38:41 am »
I would install noctua fans on the CoolerMaster Hyper 212+ as well for full silent build.
Great choice of the noctua fans for the cabinet.
Also Scythe 120mm Gentle Typhoon 1850rpm Fans are awesome for cabinet fans aswell
TopJimmyCooks
« Reply #113 on: September 06, 2011, 09:38:07 am »
Aqualyricist:  I got a computer power port from a dead lcd tv, worked great.  Can usually find a dead monitor, tv, or power supply to recycle one of those from.  Will not have the fusing or rocker switch that Martijn installed of course.
« Reply #114 on: September 06, 2011, 03:06:46 pm »
I'm in awe.  It's inspiring, sir.  Seriously.
aqualyricist
« Reply #115 on: September 06, 2011, 03:49:22 pm »
@TopJimmyCooks Thanks. Good idea. I just recycled 1 off a psu and soldered it to the smart strip.
@Martjin thanks for the usb info. I found a dealer here in the US w/ free shipping for $6.00/ea
Martijn
  • Akira!
    • ModMyBox
« Reply #116 on: September 07, 2011, 01:15:36 pm »
Game On Grafix - Shipment Notice
Hello Martijn, This is an automated email to notify you that your order #xxx has shipped today (7 sep).  ;D
(placed order on 1 Sep, was delayed because of holiday he told me)
Martijn
  • Akira!
    • ModMyBox
« Reply #117 on: September 13, 2011, 04:19:29 pm »
Customs Clearance, September 13, 2011, 7:22 pm, NETHERLANDS
Almost here  :laugh:
Martijn
  • Akira!
    • ModMyBox
« Reply #118 on: September 23, 2011, 11:02:09 am »
Straight from Gameongrafix!, After 22 days its here  :applaud:
Packed in a strong cardboard tube
After opening, its filled with bubbleplastic
The artwork is rolled in some white soft printing paper to protect it
It slided right out , very nice
I am very happy with the result of the marquee and control panel, i hoped for that the template for drilling was cut the same size as the cp artwork, i am have trouble figuring out how-to place the template for drilling on the mdf cp, and after drilling placing the art spot on. I first thought i would just place the cp art and cp drilling template top of that, then placing the mdf control panel on top of that, and just cut out the correct size in one perfect go. The cutting template seems larger then the artwork.
Ill leave that for now, here's some inside pics
Bottom side, with the subwoofer, coinbox, powersockets, and 12volt power adapter
I tie-wrapped a wire to the back bottom panel with, network, power and on off switch
Above that the panel with the Xbox 360 and its components, i think i moved the xbox and all of the component around more then 5 times to get it right with the huge cooler and large power socket and airflow etc.
I cut off 20% of the dept of the Xbox 360 panel, this was for more airflow and easy cable maintenance.
Other angle
On top i have the fanmate for the 2 cabinet fans to control and on off switches for all of the CCFL tubes
Casefan / Grill closeup
Now that i received my drilling template i can finally begin working on the Control Panel.  :cheers:
dandare
Re: Scratch Slim Marvel vs Capcom [23 Sep - Artwork Arrived & Inside Peek]
« Reply #119 on: September 23, 2011, 02:47:40 pm »
you are such a tease!  ;D
