Author Topic: I'm looking for a USB to 5 pin motherboard thingy - does this exist??  (Read 2213 times)
I want to plug a USB device directly to the USB pins on my motherboard (so as not to waste any of the USB ports).  Is there some sort of adapter I can buy?
Thanks!   :cheers:
BobA
  • What Me Worry?
Re: I'm looking for a USB to 5 pin motherboard thingy - does this exist??
« Reply #1 on: March 19, 2009, 06:58:41 pm »
Here is one.  I am sure there are many others available.
http://www.usbwholesale.com/motherboard%20cable.htm
Octo
  • Last login:April 04, 2011, 05:55:22 pm
« Reply #2 on: March 19, 2009, 07:06:14 pm »
http://www.showmecables.com/viewItem.asp?idProduct=493
Same thing, little cheaper.
Why not just buy a USB hub? ???
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #3 on: March 19, 2009, 09:54:58 pm »
Thanks for the links - I want to make a custom shell-mounted i/o panel for my next cabinet and solutions like this are great.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #4 on: March 20, 2009, 03:41:14 pm »
I always think its best to use the on-board USB ports if they are present, but the M/B manufacturers dont make it easy to find or buy the header cables that are guaranteed to work.
Mind you if you think those are tricky to find, try finding a serial port header cable for an ASUS board! Virtually impossible, I had to make one in the end.
Andy
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 12:04:48 am
« Reply #5 on: March 20, 2009, 03:57:11 pm »
Andy
You could have traded one of your Ipac4 with mine :)
Free VGA Breakout Cable
Kevin Mullins
    • Me on Myspace
« Reply #6 on: March 20, 2009, 04:02:20 pm »
Like these ?
http://www.frontx.com/pro/cpx102_2.html
