Author Topic: Person needed in New Jersey to modify X-Arcade for handicapped man  (Read 3581 times)
icabjeff
  • Last login:May 10, 2009, 09:01:23 pm
I'm looking for a hobbyist to help me modify an X-Arcade for handicapped use. I know how to do the work but I can't physically do the work. I would like to pay on a per-project basis.
Jeff Gray
Arcadiac
  • Last login:April 14, 2020, 01:26:31 am
Re: Person needed in New Jersey to modify X-Arcade for handicapped man
« Reply #1 on: June 26, 2006, 05:20:09 pm »
Hi Jeff, welcome to the board!  There may be someone who posted in this thread (located in the FAQ/Sticky section), who can help you out if you contact them. :
 http://forum.arcadecontrols.com/index.php/topic,28718.0.html
Best of luck and let us know how it goes.
ARCADIAC!
MameMaster!
  • Engage number one!
    • Mame Invaders!
« Reply #2 on: June 28, 2006, 04:29:07 pm »
Jeff Gray
what are you looking to do to it exactly?
pointdablame
« Reply #3 on: June 28, 2006, 06:25:04 pm »
I'm curious what you need done exactly as well, and also what sort of timeframe you are looking at.
I'm in NJ, but don't have a ton of free time lately.  If I can be of any help though, I'd be glad to do it.
first off your and idiot
Santoro
  • Santoro
  • Trade Count: (+32)
  • Last login:July 14, 2025, 03:43:29 pm
  • Boycott Quarters!!!
    • ArcadeReplay!
« Reply #4 on: June 29, 2006, 04:24:41 pm »
Same here, very busy, but depending on the extent of the mods I might be able to help.  What are we talking about?
icabjeff
« Reply #5 on: June 29, 2006, 10:17:50 pm »
I'm in the process of modifying an X-Arcade joystick to incorporate sockets for disability standard switches.
A disability standard switch can range from a large separate  push button on/off switch that can be operated by broad movements of the body, to a chin operated mini-joystick with a center push switch.The standard part is that they plug into specially made or adapted equipment via a 1/8" headphone style socket for single switches and 9-pin dsub atari style socket for multiple switches
I'm basing my project on a project found at http://www.oneswitch.org.uk/4/DIY/x-arcade.htm
Since the circuit board can support two players my project will have two sets of sockets with 4 1/8" primary action button sockets and three 9-pin dsub sockets going to all of the joystick buttons.
I'm also trying to use a tilt switch to operate the four directional buttons with head movement.
Jeff
MameMaster!
    • Mame Invaders!
« Reply #6 on: July 06, 2006, 03:16:29 pm »
I may be able to secure 1 or 2 FREE XArcades from XArcade.
Would that help to get the ball rolling on this project?
icabjeff
« Reply #7 on: July 07, 2006, 09:06:46 am »
I already purchased the X-Arcade. I just need somebody to do modifications. Thanks for the kind offer though.
Jeff
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 10:12:02 am
« Reply #8 on: July 08, 2006, 10:34:48 pm »
where r u in NJ ?
If this switches you talk about are almost the same as microswitches (momentary), it should be no problem at all.
Free VGA Breakout Cable
icabjeff
« Reply #9 on: July 09, 2006, 08:54:17 am »
The single switch plugs are mono headphone style audio plugs. The multiple plugs are d-sub miniature 9 pin plugs. The special switches work like arcade switches. I live in Newton.
Jeff
stevejt
  • Last login:January 01, 2022, 01:21:32 pm
  • stevejt.com
    • My site
« Reply #10 on: July 09, 2006, 10:59:55 am »
Am I correct in thinking that you just need sockets to accept the 1/8" plugs and d-subs mounted in the x-arcade and wired to it?
If that's all, it's simple, even if a panel has to be mounted, (I never saw a headphone jack that would mount to anything other than the thickness of sheetmetal).
I am about 3 hours away from you.  I don't know when I would have a day  for it though, as I have my own business and custody of my 2 boys.  I will see what I can do.
Steve
arzoo
  • Robots WILL kill you.
    • LEDBlinky
« Reply #11 on: July 10, 2006, 09:22:09 am »
Correct me if I
Robots will kill you.
Arcade Addiction
Stingray
stevejt
  • stevejt.com
    • My site
« Reply #13 on: July 10, 2006, 07:23:11 pm »
I didn't think of that...  BUT- can't the x-arcade with adapters be used on the pc and ps2 and xbox etc?
Steve
icabjeff
« Reply #14 on: July 10, 2006, 09:42:58 pm »
Steve
Yes it does. That is why I bought it.
To modify it you need to directly jump off each arcade button and connect it to the mono and d-sub  9 connections for player one and jump off a wiring harness coming from theX-ARCADE circuit board for player two
Jeff
stevejt
  • stevejt.com
    • My site
« Reply #15 on: July 12, 2006, 01:06:48 pm »
Hey Jeff.
     Do you already have all the necessary mono jacks and dsub sockets already?
     Am I correct in assuming that a metal panel needs to be inserted to attach the jacks and sockets to?
     Does anyone here have a pic or a link to a pic of the inside of the x arcade?  Would like to see (1) entire inside, (2) circuit board, and (3) the connectors used attaching micros.  I am sure someone will ask why or say I don't need to see those specifics, SO, wondering best places to solder (would rather solder than splice), if terminals are uninsulated, wires can be soldered to them quickly.
   As I said, I would like to help, but don't know how soon I can get out there.  If someone else can, feel free to help.  But until I hear it's DONE, I will try to find a day.  (Not that easy as I have my own bussiness and custody of my children).
  If you have the dsubs and can show me a pic of the EXACT ones you have I might be able to make the panel in the mean time.
Steve
PS- Any ideas by anyone would be appreciated.
MameMaster!
    • Mame Invaders!
« Reply #16 on: July 13, 2006, 04:29:42 pm »
here's a shot of when I installed a spinner into my XArcade solo. The dual is identical except for another set of wires and joystick/buttons etc.
stevejt
  • stevejt.com
    • My site
« Reply #17 on: July 24, 2006, 08:48:17 am »
Hmmmm...  Wonder what happened...
icabjeff
« Reply #18 on: July 27, 2006, 05:32:11 pm »
Nothing has happened.
Jeff
stevejt
  • stevejt.com
    • My site
« Reply #19 on: July 28, 2006, 06:57:45 pm »
Hey Jeff.
icabjeff
« Reply #20 on: July 29, 2006, 01:42:25 pm »
I have all the necessary parts. Yes a metal panel needs to be inserted to attach the jacks and sockets to.
Jeff
stevejt
  • stevejt.com
    • My site
« Reply #21 on: August 03, 2006, 04:54:45 pm »
hey Jeff.  I haven't forgot about you.  Though I did think you dissapeared the first time I asked if you have the parts and got no response.  I've been real busy lately.  I know its 6 weeks away, but when the kids go back to school I will definately make a day to get out to you, if you don't have it done yet.  You are a few hours drive away.
Steve
