Author Topic: MP3 Jukebox Software (Touchscreen, With mp3+g, Video and WMA Tag Support)  (Read 177975 times)
Barry Barcrest
  • Last login:November 09, 2021, 09:54:17 am
  • Simple Plan
    • E-Touch Jukebox
Re: MP3 Jukebox Software (Touchscreen, With mp3+g, Video and WMA Tag Support)
« Reply #440 on: January 27, 2006, 11:23:28 am »
27-01-06
What
« Last Edit: January 27, 2006, 12:05:40 pm by Barcrest »
mr.Curmudgeon
  • It's going to hurt your brain. A lot.
  • Last login:October 11, 2021, 07:15:49 pm
  • Huzzah!
« Reply #441 on: January 27, 2006, 02:36:44 pm »
Awesome....much, much better!!
mrC
Silver
  • Last login:April 16, 2025, 04:09:53 pm
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #442 on: January 28, 2006, 05:58:30 am »
Nice - the text on the white strips does not work in touchclone when setting 12 albums instead of 6....
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #443 on: January 28, 2006, 03:14:01 pm »
28-01-06
What
« Last Edit: January 28, 2006, 04:23:04 pm by Barcrest »
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #444 on: January 28, 2006, 07:31:30 pm »
Here is the new skin i am working on, it's called chrome... I know it's not great but i can't use anything other than MS Paint...  ;D
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #445 on: January 28, 2006, 11:05:37 pm »
You need this version it fixes up more skin issues, this is for skin creators and end users. I have also released the Chrome skin i made as a proof of concept for the new skin stuff. It was inspired by Mr C's great work...
DOWNLOAD:
http://www.freeboxjukebox.com/files/beta/setup1661.zip
Chrome Skin:
http://www.freeboxjukebox.com/files/beta/chrome.zip
Thanks to Ninja Episode for the drop shadow effect at the top.
« Last Edit: January 28, 2006, 11:16:49 pm by Barcrest »
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #446 on: January 28, 2006, 11:37:33 pm »
Please post any bugs and i will fix them for the next release as it's too late to release another tonight...
Bug List For Next Release
BUG: Next song display doesn't appear in the right place (FIXED)
mr.Curmudgeon
  • Huzzah!
« Reply #447 on: January 29, 2006, 02:28:31 pm »
BUG (?): The background color on the appearance setting '4 Covers + Tack listing' does not call on the same settings as the other sections. (ie: Queue and Search Backdrop). Should it be skinnable, or editable (background/foreground) with the Skin Tool?
I ran into the problem since I'm designing a dark color skin (w/ white fonts), and the tracklisting next to the 4 Covers is white. So the tracks don't show up.
BUG/FEATURE (?): I was having a problem getting the right backgrounds to show in the correct screens, but I realized I was using the Skin Tool 'Texture Viewer' to load the backgrounds in. Apparently the application uses specific naming conventions for some background screens, thus not loading in the images I was selecting through the 'Texture Viewer'... Ultimately the texture viewer is the bomb, since I can name the images and format myself (ie: jpg, etc)  I'm perfectly willing to accept that I was also doing something wrong, but felt it was worth mentioning.
DESIGN SUGGESTION: The text info below the album cover on the 'Track listing' screen should line up vertically (ie: Left justified) with the left edge of the album cover. Possible even indented to the right a little. The way it is now makes any skinnable elements created to wrap around the text (ie: Windows, whatever) come too close to the menu on the right. No breathing room, per se. Same with the track listing itself, on the right. Maybe that should be indented a little as well. Any other places you can think of?
I realize you may be making this info drag n' drop w/ the skin tool in the future, so disregard the above if that's the case.
 (God, aren't graphic designers picky?)   :P
mrC
« Last Edit: January 29, 2006, 02:40:01 pm by mr.Curmudgeon »
mr.Curmudgeon
  • Huzzah!
« Reply #448 on: January 30, 2006, 01:09:53 am »
BUG: I've changed the Album Frame image using the Skin Tool by selecting a .jpg image in the texture viewer. However, "AlbumFrameTextureNew3.bmp" is always loaded as the Album Frame for the first album in the list. All the others are the correct selected .jpg.  For now, I've gone back to using the filename AlbumFrameTextureNew3.bmp so all the frames load correctly.
I'm REEEEEALY close to finishing the skins. Just tweaking minor stuff before I consider them ready to go.
mrC
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #449 on: January 30, 2006, 05:03:51 am »
Right i think all thoose suggestions are perfectly valid and i will look at them in depth once i get home tonight.
The album frame image sounds like a bug so i will try and recreate that and then eliminate it.
The 4 covers with track listing screen is really experimental to see if i could do it and is not reallly as complete as it should be. I am not to sure how many people actually use this but what it does is put the album frame in the track listing background. I should really make this a seperate image i suppose so i will also get onto this tonight.
The track listing screen should be Drag N Drop esque by tonight as well i have already started it. This will fix the issues you are getting with some elements being too close to the edge of the screen. Likewise time permitting i will also make thoose buttons on that screen fully skinable as per the menu bar so you may end up holding your skins back further to incorporate these changes.
From what i can see the tracklising changes to the skintool will effect your skins release the most so i will try and get that in first as it enables you to carry on working.
NOTE: I have fixed up the bug causing the top 20 display not to work, or least i think i have so some feedback on this would be good. Whatever i get done you will see a release tonight.
Silver
    • Mods'n'Mods
« Reply #450 on: January 30, 2006, 08:03:37 am »
BUG:
Go to options, select random play settings, click on the text at the top "Random Play Options"... and the entire options screen and buttons all dissapear!
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #451 on: January 30, 2006, 09:11:51 am »
BUG:
Confirmed, it is when you click anywhere on that frame? Don't know why it is doing that or where that code came from. As soon as i get back that will be fixed in tonights release, Good Catch Silver.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #452 on: January 30, 2006, 02:00:59 pm »
FIXED.
BUG: Go to options, select random play settings, click on the text at the top "Random Play Options"... and the entire options screen and buttons all dissapear!
FIXED.
Right i have almost got the skintool completed.... I have made some buttons settings global throught the jukebox so you set them once and they look like that on every screen. These are....
BACK
ADD TO QUEUE
PLAY NEXT
PLAY NOW
I have done this so the jukebox has a consistant look to the end user, i doubt anyone would want to make these buttons look differently on every screen/occurance. If i am wrong let me know but htis is how it will be for now.
« Last Edit: January 30, 2006, 03:59:49 pm by Barcrest »
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #453 on: January 30, 2006, 07:07:18 pm »
DOWNLOAD:
http://www.freeboxjukebox.com/files/beta/setup1673.zip
Now you can skin the tracklisting see image.
« Last Edit: January 30, 2006, 07:30:50 pm by Barcrest »
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #454 on: January 31, 2006, 05:15:51 am »
Known Issues:
BUG: Actual Listing of tracks doesn't move to where it is set to in the skin.
BUG: First time you click a cover the screen doesn't show the tracks.
BUG: Add Album/Add To Carasole Don't resize in skintool.
If you find any more let me know and i will fix them up. This is what happens when you rush things, i wasn't looking at making a release tonight but as the list of issues is growning i feel i might have to. Damn i need a flash drive and i could be working on it from here at work.
« Last Edit: January 31, 2006, 06:21:44 am by Barcrest »
eist1
  • Last login:September 30, 2008, 02:38:59 pm
« Reply #455 on: January 31, 2006, 10:54:58 am »
Barcrest,
Do you think that there could be an option to have the track listing in expanded mode to have the song names as buttons to be easier to hit for touchscreen users? Just an idea. Thanks
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #456 on: January 31, 2006, 12:00:01 pm »
Barcrest,
If you can let me know where you are refering to? The main track listing or the 4 covers with tracklisting??? I am using it fine on a 14" touchscreen in the main track listing. I don't mind changing something if it is not working if you could just clarify what you are looking for.
eist1
« Reply #457 on: January 31, 2006, 04:27:22 pm »
Barcrest,
I am referring to the Main Track Menu (After Expanding Album). It is working for me also, I have a 15" touchscreen, and sometimes when users are hitting a song, they hit the song above or below, due to them being close together. I was just thinking if they were buttons, they'd be spaced apart. I was just asking to see if this was feasible. If not, I'll just have to make sure the users don't have such fat fingers :) Thanks for the response
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #458 on: February 01, 2006, 06:45:24 am »
Ok at the moment the skintool treats this list as one block, i could make it so it treats each track (Row) seperatly and this would enable you to resize them to whatever suits you best. At the moment the bulk of my time is taken up with the skinning options and bug fixes so new stuff is on a back burner until the skintool is complete and all know bugs are ironed out.
Thanks for your interest, check back later tonight for a new release.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #459 on: February 01, 2006, 03:47:11 pm »
01-02-06
What
Sly
  • Last login:August 30, 2016, 08:49:53 pm
« Reply #460 on: February 01, 2006, 03:49:25 pm »
Barcrest,
love the program. working on building a jukebox and trying different programs to use. while trying your software i found a few bugs and thought i would post them.
Bug: in the appearance settings options when i set the track display options to "use database for track names" or "use filename for names" and restart the program it will not play songs or add songs to the queue, but when random play is turned on random songs will play fine. Reinstalling the program fixes the problem, but making the above changes again will cause it not to work right after restarting it.
Bug: the add entire album button and the add album to carosuel are reversed. pressing the add to carosuel button actually adds the entire album to the queue.
Bug: the credits display does not refresh when credits are deducted from the total credits. also when you start the program with the freeplay option the credit display does not display freeplay. and it is possible using credit mode to go into negative credits and still keep playing.
Bug: in the config program i can't remove albums from the database. i get "runtime error '5': invalid procedure call or argument" and the program closes.
keep the updates coming!!
NinjaEpisode
  • Last login:June 16, 2019, 06:47:45 pm
« Reply #461 on: February 01, 2006, 03:56:09 pm »
Hey Sly, regarding your first bug, until Barry fixes it, which'll be like faster than lightning, you can always go into the directory that Freebox is installed in and delete the Freebox.ini file.  This will set your preferences back to default and you should be able to launch Freebox again without having to reinstall.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #462 on: February 01, 2006, 05:35:29 pm »
Barcrest,
Yes, neither of these options should be there anymore. It is now based totally around the database created from the config so i will remove these. They date back to a much earlier version.
Good catch, this is part of me enabling the skinning options for this screen. I have fixed this.
Yep another bug but i hadn't got around to fixing this as no one had brought it up before. I have been pretty much working on issues people are getting as they get them. I will look at sorting this out on the next release.
This is new to me i will have a look at it for the next release.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #463 on: February 01, 2006, 06:19:12 pm »
Ok i fixed up some stuff quickly...
BUG: Top20 wasn
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Last Edit: February 02, 2006, 08:43:29 pm by Barcrest »
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #465 on: February 03, 2006, 08:52:17 am »
New version, allows you to see related albums on the track list screen. Also includes a load of bug fies, see screenshot.
Download:
http://www.freeboxjukebox.com/files/beta/setup1690.zip
« Last Edit: February 03, 2006, 09:01:00 am by Barcrest »
NinjaEpisode
« Reply #466 on: February 03, 2006, 09:09:42 am »
Can you select those "related items" ?
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #467 on: February 03, 2006, 09:14:19 am »
Yes and it takes you to that album..  ;D
NinjaEpisode
« Reply #468 on: February 03, 2006, 09:15:59 am »
very very cool.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #469 on: February 03, 2006, 09:20:36 am »
It'a not too intelligent, you have to have albums byt the same atrist with the same artist name for it to work. It doesn't know The Police are the same as Police for instance. If you are tagged prooperly it should work.
NinjaEpisode
« Reply #470 on: February 03, 2006, 09:22:06 am »
Ah, that's always the issue though...  ;D
mr.Curmudgeon
  • Huzzah!
« Reply #471 on: February 03, 2006, 09:47:26 am »
For the tracklisting, why not do it the way demonstrated below?
- Then you get (5) albums listed, from a similiar artist.
- The Main album listing is at the same size ratio. It's the same size as the old one in this image.
- The vertical space is utilized more efficiently.
I think the Album/Artist/Year info should be closer together anyhow...and the character limited. Longer titles could then scroll or whatever.
mrC
« Last Edit: February 03, 2006, 09:49:33 am by mr.Curmudgeon »
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #472 on: February 03, 2006, 10:24:25 am »
Well you can resize the covers, i had 4 underneath like how you have it but decided i wanted to put them up the side.. It's just a matter of taste, If you have downloaded the latest release you will see you can position them anywhere you like, don't forget you can resize the album tag labels and move them closer together if you wish.
That skin is more just to show you what can be done, i leave it to experts like you to make the really good skins.
mr.Curmudgeon
  • Huzzah!
« Reply #473 on: February 03, 2006, 10:55:01 am »
Ah....ok.  My bad!   ;D
mrC
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #474 on: February 03, 2006, 12:44:33 pm »
Very Nice!  Me rikey!
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #475 on: February 03, 2006, 01:07:46 pm »
Hey
When selecting an album in the newest version, it always shows the album art for the album in the bottom right corner of the main screen.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #476 on: February 04, 2006, 11:26:08 am »
Hey
Dude i am not sure what you mean? Give me a shout on MSN later and i will look into it for you.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #477 on: February 04, 2006, 02:48:06 pm »
DOWNLOAD:
http://www.freeboxjukebox.com/files/beta/setup1698.zip
Some bug fixes that i can't remeber now and also more skin support for the new skins that should be out later today/tonight.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #478 on: February 04, 2006, 04:45:05 pm »
runtime error 6: overflow when trying to use any other skin than metal.  The album bug is as follows:
When I have my collection in the twelve album view, whatever album is in the bottom right corner of that view(or either of the other views for that matter), when I select an album to look at the songs, that album in the bottom right is the one I see blown up.  No matter what.  Does that make sense?
mr.Curmudgeon
  • Huzzah!
« Reply #479 on: February 05, 2006, 08:16:24 pm »
NOTE: The first five colored skins are now part of the 1.6.99 install!
Alright, here's some skins I put together to be used with the latest version of Freebox. As with the program itself, these are ALPHA versions which will most likely be updated and improved as more features become available and more aspects become skinable. Let me know what y'all think.
(click on thumbnails to view)
AgentOrange
BlueGrass
DeepPurple
GrayDay
GreenRiver
50's Diner (Download)
Design by mrC / [f!nk]media
« Last Edit: February 06, 2006, 09:30:45 am by mr.Curmudgeon »
