I am officially in painting hell
![Cry :'(](http://newforum.arcadecontrols.com/Smileys/default/cry.gif)
The first layer of paint after priming went on nice and smooth, and looks terrific.
I applied a second layer of paint for all the visible parts: side panels, front panel, speaker panel, and a few other areas.
The results were horrible though, as it seemed my roller disintegrated, leaving small fabric parts all over the place.
I did not notice this during the painting, as when painting black on black its really hard to see what you are actually doing.
So more sanding and using a non-fabric roller for another layer of paint, and again the results were not great.
Dust specks everywhere! How the F@#$ did that happen, as I waited a week between sanding and painting, and used a damp cloth to wipe the cab and surrounding area multiple times, during that time.
Then I realized, I left the stick to stir the paint on the ground next to the cab when sanding, and never cleaned it afterwards. So that is most likely the source of contamination of my paint.
The front panel and speaker panel are luckily not that bad actually. It's only noticeable when you either feel the wood, or a bright light reflects off the surface. The side panels are worse and I fear for when I need to apply side art.
So I was wondering, can I just lightly wet sand the side panels with say 1000+ grit, and then apply the side art. Or does the side art stick better when I just repaint it after sanding?
