Author Topic: FLYNN'S ARCADE (Project Code Name: Overambitious) - FINISHED  (Read 592605 times)
DarthBS
  • Last login:May 26, 2019, 01:35:39 am
Re: FLYNN'S ARCADE (Project Code Name: Overambitious) - FINISHED
« Reply #720 on: June 02, 2016, 04:01:05 pm »
It's a site/forum that mostly focuses on restoration/repair/collection of original arcade hardware, from what I can see.
thanks!
  • Last login:Today at 03:54:46 am
« Reply #721 on: June 02, 2016, 04:03:30 pm »
what is KLOV?
It's the arcade-museum site and forums -- a great resource for finding info and parts for dedicated cabs.
http://forums.arcade-museum.com/
DarthBS
« Reply #722 on: June 02, 2016, 04:18:53 pm »
thansk guys. i signed up and got banned for 30 minutes for not logging in with the right username on one page and my email on the other. not my day lol
« Reply #723 on: June 02, 2016, 04:23:35 pm »
When you do send them a p.m. there, make sure you tell him I sent you.
Sent from my SM-G386T using Tapatalk
« Reply #724 on: June 02, 2016, 04:24:54 pm »
Why does BYOAC hate Tapatalk?
« Last Edit: June 02, 2016, 04:28:31 pm by yotsuya »
« Reply #725 on: June 02, 2016, 04:27:25 pm »
Somebody really needs to do something about this site.
ChanceKJ
« Reply #726 on: July 08, 2016, 12:39:11 am »
« Last Edit: March 19, 2021, 01:55:58 am by ChanceKJ »
DarthBS
« Reply #727 on: July 08, 2016, 09:17:49 am »
Oh, and you might have better luck with him on KLOV.
^^^^This is good advice.^^^^
...how much did you roughly spend on everything for this build?
a LOT.  Lost track past $5500 Canadian, (whats that like $50 USD??).  But thats including a TON of parts and supplies i didn't use, or had to buy replacements of if i messed something up.   This build was my first, a labor of love, and an all out balls to the wall effort of throwing money at things until they were how i imagined them.
...Just, would have used plexi instead of glass...  ::)
thanks for the reply. I am debating making it myself or getting PDX to make it. trying to see how much I would be saving doing it myself. (which in turn could mean jack if I end up messing up over and over)
Fydo
  • Last login:December 20, 2023, 11:02:26 pm
  • Alberta, Canada
« Reply #728 on: July 08, 2016, 05:58:28 pm »
Hi Chance!
Awesome build, and a pleasure to read through the log.
Quick question: I love the glow effect around the joysticks. Where did you source the polycarbonate tubing for the "glow rings"? I found one place online but they wanted an arm and a leg for it (and the other arm + leg to ship it!)
Also, since I see you're in Alberta, do you have any of the tubing left over that you'd want to get rid of? :)
Cheers
jbl77
  • Last login:March 01, 2024, 04:52:21 pm
ChanceKJ
« Reply #730 on: July 16, 2016, 09:08:33 pm »
« Last Edit: March 19, 2021, 01:56:04 am by ChanceKJ »
Fydo
  • Alberta, Canada
« Reply #731 on: July 18, 2016, 05:20:14 pm »
Thanks for the help, guys! Once I have enough things in order I'll likely start up a build thread of my own. The threads / worklogs on this forum are super inspiring (especially this one!)
jbl77
« Reply #732 on: July 20, 2016, 12:25:02 am »
Where abouts you at in Dipperland?
hilyou
  • Last login:September 24, 2016, 12:52:16 am
« Reply #733 on: July 21, 2016, 02:03:37 am »
Great build!
Just wanted to ask what those 4 black knob looking things are in the control panel?
I've seen them in numerous other builds too
On another note, glad to see another Canadian on this forum
  • Bitches love Centipede
« Reply #734 on: July 21, 2016, 09:02:31 am »
%Bartop
nexusmtz
« Reply #735 on: July 22, 2016, 01:27:55 am »
They're what they look like. Star Knobs. The bolts come upward, through the board that the control panel rests on. The control panel base has holes the the bolts pass through, and the knobs secure the panel to the cabinet. They just make it easy to remove the panel without tools.
...Once i was happy with the base, i lined up the CP centre with the cab, clamped it down and used the same small forester bit to cut holes through the CP and mounting board. The bolts shown in the picture are just temporary ones i had in case i went with a thicker mounting board. I need to get shorter ones or cut these down.
chito
  • Last login:July 23, 2023, 12:29:26 pm
    • forum.arcadecontrols.com/index.php/topic,151843.0.html
« Reply #736 on: September 05, 2016, 11:55:23 pm »
I havent finished reading the whole 19 pages of this amazing build yet
but im not sure if these were available at the time of the build but couldnt you use the PELE ring light for the joysticks?
http://www.paradisearcadeshop.com/button-leds/580-pele-30mm-led-rings.html
has anyone tried this?
jemkewl
  • Last login:September 29, 2016, 02:42:04 pm
« Reply #737 on: September 16, 2016, 12:41:16 pm »
Chance, first of all great build.  I have now read through this twice.  Once a while back, and again, yesterday.  It is interesting how many ideas I took from you that I didn't realize that I had.  Mostly what I have done is a bit of a redo of my control panel and marquee, but I ended up using the IL buttons that now come pre-done with the black inserts and the same RGB illumination, only using an Ultimate I/O instead of the PacLED.  I have even incorporated similar Bulgin buttons for power and admin, but I am using the UIO to control the admin buttons as well (power gets its power from the PC).
I need to get some pics of the wiring cleaned up and actually hooked up to the UIO.
Keith
Hello Keith,
Can you share where you purchased your black IL buttons with transparent bezel that come pre-done with the color changing RGB LEDs?  I too am researching to do a similar control panel and want to light up the bezels for the player, start, controls, etc. in different colors.
bboris74
  • Last login:June 15, 2017, 06:34:55 pm
« Reply #738 on: September 22, 2016, 05:34:25 am »
Hi Chance,
Really love your build, its inspired me to build my own but I have a question about your power supply.  Is it a 12VDC, 5A, 60W POWER SUPPLY such as the one found here http://www.mroelectronics.com/mro/product.php?id_product=880?  If so are you running a direct 12v line into your two PacLED64's?  The reason I ask is that the button led's I picked up from Paradise arcade are 5v and if i run 12v power into my PacLED64's I assume I will either shorten the life of my led's and or my PacLED64's.
Thanks,
Bill
« Reply #739 on: September 22, 2016, 09:03:28 am »
Hi Chance,
Thanks,
Bill
Yeah, just see if you can exchange the 5v leds for 12v ones.
fablog
  • Last login:January 04, 2026, 04:27:15 pm
« Reply #740 on: September 22, 2016, 06:36:57 pm »
Hello Keith,
Arcade Paradise ;)
« Last Edit: September 22, 2016, 06:38:32 pm by fablog »
julezvernez
  • Last login:March 01, 2017, 03:17:23 pm
« Reply #741 on: October 12, 2016, 09:36:38 am »
 :applaud: Hey !
I am working on building my own Arcade... already have parts of the hardware done and Hyperspin running...
Can you let me know where you got the Coin Door?
What kind of Coin-Mech did you use?
Where did you get your own "Flynn's" Coins?
THANK YOU for the help,
Julez
80sarcadegames
  • Last login:October 01, 2025, 09:41:51 am
« Reply #742 on: November 30, 2016, 01:57:07 pm »
:applaud: Hey !
Julez
Just read through every post on this thread, all 19 pages of it.
Lots of information!!!! Love the detail of the build shared in this thread!
Couple of questions if the builder ChanceKJ:
1.  Where did you buy the black L brackets to hold the marquee in?
2.  Did you keep the display frame on and then place weather stripping on the sides, then the tinted glass?
3.  How do you control power to everything? Is there a one button control for everything to turn on at once?
Wow! Great cabinet!!
« Reply #743 on: November 30, 2016, 05:29:40 pm »
Why don't you people just PM him directly? He doesn't come around much anymore. That's his business, but I bet if you sent him a message, he'd probably answer it.
gumby510
  • Last login:November 17, 2022, 09:19:44 pm
  • SR-20 NX 2000
dgrace
  • Last login:February 21, 2026, 10:13:27 am
« Reply #745 on: December 04, 2016, 01:20:09 am »
I'm digging those speaker grills.  Anyone know where he purchased those or where I could get similar ones for my cab? Thanks
« Reply #746 on: December 04, 2016, 11:51:13 am »
I don't know. Why don't you PM him?
eleehl
  • Last login:April 17, 2017, 12:29:00 am
  • I want to build my own arcade!
« Reply #747 on: December 19, 2016, 12:39:51 am »
Hi Chance,
I've literally been lurking on your build for the past month. A neighbor and I are really inspired by your build and are starting to piece everything together for the build! I feel the need to give you props for the amazing work and ideas you've given us!! We won't be able to build anything close to your caliber but we'll do our best and if we don't screw up we'll definitely be posting here!!
E
« Reply #748 on: December 19, 2016, 05:01:25 pm »
Welcome aboard, eleehel. Batten down the hatches, hoist the mainsail and all that.
Typefighter01
  • Last login:February 01, 2026, 04:15:26 pm
  • Back I guess...
« Reply #749 on: December 19, 2016, 08:14:39 pm »
Must just burn your guys nuts that that his build keeps floating to the top...I love it.
I think Chance got thrown into the same pot as Kaneda (for reasons really unknown to me other than he had some hard earned expendable income that he threw at a hobby he enjoyed...something that is frowned upon on this forum as you need to be some cheap ass ---fudgesicle--- that wouldn't pay retail to save a drowning baby to get any respect)...then it turned into a hate parade. Also...he seemed generally happy...another trait frowned upon.
Most of the people I know don't give two shits about building their own arcade cab...think you folks need to embrace (tolerate?) someone that at least enjoys(ed) the hobby and contributed something other than snide ass comments about his forum etiquette (which never bugged me).
Also, who gives a ---steaming pile of meadow muffin--- when he decides to post here either...some guys don't post here for years and when they do, people jump all over their d$#k.:dunno
Let the thread do what it does...if ya don't like it...ya don't click on it...pretty simple... :cheers:
Actually...not sure I ever posted in this thread, so as not to upset the forum police with an unnecessary bumping, I will say "Good work on the cab...don't think I have seen a more popular design since I joined.". As they say, "Imitation is the sincerest form of flattery!!!".
« Reply #750 on: December 19, 2016, 09:00:52 pm »
I get along with Chance very well.  We chat outside this forum. What I don't like/feel bad for are people who post questions for him and then get ignored. That's why I recommend they PM him.  It has nothing to do with being a "hater". :dunno
Typefighter01
  • Back I guess...
« Reply #751 on: December 19, 2016, 09:43:42 pm »
Mehhh... he took some cheap shots from a lot of people.
Also, I said "hate parade"...not "yotsuya the hater". You know what goes on in here, the people I am talking about and exactly what I am talking about, so lets not not act the different.
ChanceKJ
« Reply #752 on: December 20, 2016, 04:18:42 pm »
« Last Edit: March 19, 2021, 01:56:18 am by ChanceKJ »
sealcouch
  • Last login:October 19, 2025, 07:08:59 pm
« Reply #753 on: December 20, 2016, 07:17:20 pm »
You guys see that new Star Wars?
« Reply #754 on: December 20, 2016, 07:18:38 pm »
No beefs allowed on the SS BYOAC. Go help people with their monitor problems and leave this thread alone, Mel.
KLRinstinct
  • Last login:February 24, 2021, 11:35:00 pm
  • Burrrrn baby burn
    • forum.arcadecontrols.com/index.php/topic,152916.0.html
« Reply #755 on: January 10, 2017, 12:19:46 am »
G'day Mate! I just signed up to the forum specifically to say thank-you very much for the awesome write up! Its proved kinda hard to find decent info on cab building online so this has been my saviour. I've been over and over this thread the last week or so and its helped me a lot! I'm now ready to dive in and get this puppy made. Your design is soon to exist way across the ocean in Australia! Gonna go with a more rounded at the front CP and a Street Fighter theme, cant wait!
ChanceKJ
« Reply #756 on: January 10, 2017, 02:55:12 am »
« Last Edit: March 19, 2021, 01:56:23 am by ChanceKJ »
KLRinstinct
  • Burrrrn baby burn
« Reply #757 on: January 10, 2017, 07:06:49 am »
Cool, thanks a lot. Ive started a thread here http://forum.arcadecontrols.com/index.php/topic,152916.0.html
Not much to see yet though. I could use some tips on joysticks and buttons as it turns out. Will be playing mostly beat em up's on the machine would you have any recommendations? Should I make sure I get a SANWA brand stick ya think? Also just thought of another one after scouring your thread again - How much T-moulding did you end up using? TIA
« Last Edit: January 10, 2017, 09:46:05 am by KLRinstinct »
ChanceKJ
« Reply #758 on: January 10, 2017, 09:49:16 am »
« Last Edit: March 19, 2021, 01:56:27 am by ChanceKJ »
Modigy
  • Last login:June 14, 2018, 04:50:47 pm
« Reply #759 on: January 10, 2017, 01:42:11 pm »
This looks fantastic, amazing work!
