OK, I am trying to stick as close to your plan as I can. Do you have a list of what parts you used and where you got them?
I ordered the Pink Ball Tops from Cajun Arcade
Sent a message to TEFightStands about the pink washers
Ordered 60n1 PCB board / Wiring Harness / 16a Power Supply from Amazon (Paradise Arcade) - cheaper at Cajun, saw too late
Ordered power inlet / cord from Amazon
Will get my printing done through Game on Grafix
Which joysticks (Ms Pacman/Galaga replacements or zippy short shaft?) / buttons / chrome buttons did you order and from where?
Where and which lights did you order?
Sorry for all the questions, just trying to order everything
Also, you said if one thing you would change is you would use MDF instead, would you still laminate the top of the CP if you used MDF?
