The WeeTail Cab - Little Ms. Pac-ManA Portable Cocktail Cabinet for kids to play while sitting on the floor, or adults to play on a table at home or take to parties, playable by humans 1 - 1000 years old.
Finished Cocktail CabinetConcept ArtInitial Sketches
Configuration:- 5/8" particle board laminated cocktail case with acrylic top
- HUGE!!! 21.3" Samsung 214t Syncmaster 4:3 IPS LCD Screen
- 2 Player face-to-face
- 4-way sticks with pink bubble tops
- LED lit Custom Dustwashers from TEFightstands
- LED yellow & black buttons, 3 per player
- LED pink & chrome P1/P2 start & coin Buttons
- LED lit Ms. Pac-Man speaker & ghost fan grills
- Ms Pac-Man color matched Pink T-molding
- Custom Ms. Pac-Man artwork on sides/bezel/CP
Wood Cut Template Files -
Zip Package attached at the end of this postI've uploaded these template wood cut files for anyone to use as they wish to make their own build of this cabinet. I don't use sketchup or CAD programs to create my builds so everything may not be perfect, I have however used these files to build the cab myself and had no fitting issues.
You can build this entire cab out of one 4'x4' panel of 5/8" wood, or 2x 2'x4' panels of 5/8" wood.
All measurements are based around 5/8" media, so if you use something of a different thickness you will have to adjust the templates to compensate.If you want to use them, modify them or stick them on your fridge go ahead.
Art Files -
Zip Package attached at the end of this postThere are two art packs:
- PDF's of the Sides, Control Panel, End Caps and Bezel for those of you that just want an easy way to get it printed.
- Adobe illustrator Art files for anyone to use or modify as they see fit.
Side Art
Control Panels
Bezel
End Caps
Serial Plate
