Author Topic: Tron, in game 8way to 4way - WORKING! 100%  (Read 24241 times)
Re: Tron, in game 8way to 4way - WORKING! 100%
« Reply #40 on: February 03, 2012, 10:47:19 pm »
Couldn't you have used DaOldMan's Mrotate for this?
No, that application, along with DaOldMan's joychoose and controller choose send their commands on execution and closure of the target programs.  This application is for switching mid game and selects only on the light cycle stages... or whatever visual cue you set up.  I'm currently running Joychoose and this script together.  Joychoose sets the 8way for the game and the script does the rest.
darthpaul
  • Last login:July 08, 2025, 08:50:10 pm
  • Join, It's your duty
« Reply #41 on: February 03, 2012, 10:56:09 pm »
I seriously have to think about trying this, great job guys.
Automated Cabinet
Nintendo Pi
PiCubed
tony.silveira
  • Last login:September 27, 2024, 03:04:35 pm
    • my baby
« Reply #42 on: June 19, 2012, 10:24:25 pm »
sweet christmas!  i'm just now trying to wrap my head around an auto 4/8 and now this.  what work, great job guys!
Gray_Area
  • -Banned-
  • -Banned-
« Reply #43 on: June 20, 2012, 08:07:48 pm »
Oh. Right.
-Banned-
« Reply #44 on: June 21, 2012, 02:08:53 am »
All praise goes to Nitz for his awesome script work.  This is something that I showed to guests every now and then and they were never impressed.  Now I just let them play TRON and listen to them talk about how perfect the gameplay is.
  • Last login:August 23, 2025, 09:14:19 pm
« Reply #45 on: June 21, 2012, 10:08:13 pm »
Good work guys!
Some pretty neat stuff here!
tony.silveira
    • my baby
« Reply #46 on: June 21, 2012, 10:30:17 pm »
hey le chuck,
since you are up and running with this 100%, would you mind sharing your final ahk scripts that you and nitz figured out?  i know there were a few edits and what not.  can't wait to try this myself!
T
SLCFoxy
  • Last login:December 10, 2012, 12:38:32 am
« Reply #47 on: July 10, 2012, 12:40:14 am »
Le Chuck and all other contributors,
    I just registered so I could ask you this  ;)  Have you got these scripts shared somewhere.  This must make it to every arcade machine out there.  It's amazing!
EightBySix
« Reply #48 on: July 10, 2012, 02:10:12 am »
The same concept would allow us to detect when a game is in attract mode... I've been wondering if there would be a way to do that. We'll be able to have different led patterns, messages etc.
« Reply #49 on: July 10, 2012, 03:34:53 pm »
8x6 - I think it would be easier to key the setting off how long since there was an input from the CP.  Kinda like a sleep mode, after 3 minutes have the LED go into attract mode.  That's a perfect AHK application.  I don't know if this has already been done but it seems to ring a bell.  I think it would be easier than recognizing the switch into attract-mode by screen change unless it is always the same first screen.
SLCFoxy & Tony - I need to go in and get the settings off Darkade and get them uploaded here for the final solution to do both 4:3 and 3:4 orientations.  I should be able to get that done in the next few days.  For now the solution for a single orientation (doesn't matter which) is below and should satisfy the needs of most out there.
Following script allows you to call the servo batch file without stealing focus (necessary for in-game use).  Saves as .vbs.
Code: [Select]
Set WshShell = CreateObject("WScript.Shell")
WshShell.Run chr(34) & "C:\arcade\tronswitch\4way.bat" & Chr(34), 0
Set WshShell = Nothing
and modified the AHK script to call the .vbs files rather than the bats.
Here's the script:
Code: [Select]
Loop
run c:\arcade\tronswitch\8way.vbs
Loop
ImageSearch,,, 223, 94, 252, 130, c:\arcade\tronswitch\startlightbike.bmp
If (ErrorLevel = 0)
break
run c:\arcade\tronswitch\4way.vbs
Loop
ImageSearch,,, 304, 107, 360, 165, c:\arcade\tronswitch\endlightbike.bmp
If (ErrorLevel = 0)
break
ImageSearch,,, 334, 142, 510, 175, c:\arcade\tronswitch\gameover.bmp
If (ErrorLevel = 0)
break
$esc::
send {esc}
exitapp
Just get the screens mentioned earlier in this thread and trim them down to small unique chunks.  Before you trim them note their parameters (doable in paint fairly easily) so you can tell the script where to look.  I will try and put together a more coherent set of instructions in a bit as this is getting some renewed interest.
If anybody else has tackled this feel free to chime in.
« Last Edit: July 10, 2012, 03:42:49 pm by Le Chuck »
nitz
  • Last login:November 24, 2015, 07:57:29 pm
« Reply #50 on: July 11, 2012, 12:42:31 am »
That would work as long as the attract mode has some image that does not appear in the actual game - otherwise you would get false positives. Another hurdle is the fact that this would be a lot of work if you wanted to do it for a large number of games.
Yep, that would be pretty easy. AHK has a built in variable that keeps track of idle time.
joe35car
  • Last login:July 17, 2025, 11:43:10 pm
« Reply #51 on: August 05, 2012, 01:30:02 pm »
Where can I get this script? Like to use it with the new stick from ultimarc.
http://www.ultimarc.com/servostik.html
« Reply #52 on: August 05, 2012, 03:20:29 pm »
Please refer to this earlier post: http://forum.arcadecontrols.com/index.php/topic,117395.msg1287582.html#msg1287582
That should be everything you need.  I don't know what Andy's software looks like to do the switch but if it can be a .bat or .exe then you just need to write a .vbs script around it and point the AHK script at that.
SLCFoxy
« Reply #53 on: December 09, 2012, 11:49:33 pm »
Is there a step by step instruction guide on how to make this work?
  • Last login:September 13, 2025, 11:24:38 am
« Reply #54 on: December 10, 2012, 01:11:18 pm »
I just read through this thread and my original solution is still best. Don't play Tron.
If this post hasn't helped you at all, click Like
« Last Edit: December 10, 2012, 01:12:53 pm by leapinlew »
« Reply #55 on: December 10, 2012, 01:22:14 pm »
I would have agreed with you a few months ago but I fell back in love with Tron on a recent trip to Denver.  I played Tron on 3 different machines while there and am really looking forward to trying this solution once my cabinet is done.
« Reply #56 on: December 10, 2012, 05:43:37 pm »
Nope.  There is a lot of information in this thread about how I went about it and the exact code I used.  I will eventually get around to making a step by step but first I need to test out calling the servo directly from the AHK script and see if that has a focus issue.  If that doesn't it will reduce everything by a step.  However, the current solution posted is completely viable and hasn't misfired yet.  If you want to cruise through the posts and put together some questions that aren't addressed I'd be happy to answer them and it could only help me out when I go to make a tutorial.  What's got you stumped Foxy?
rockyrocket
« Reply #57 on: November 15, 2013, 10:58:25 am »
I know this thread is(was) dead but it always stuck in my mind as a really cool bit of code and figure some of you would like my usage of it,
Anyway it was either bump this old thread or my own equally dead starwars one so its this one.
So my Implementation is to use this to start a targeting animation ingame in starwars on the second screen, basically it loops one vid then waits for the "T" in tower at the start of the tower sequence then sleeps for a bit then starts the trench run animation.
The timing is a bit hit and miss and its still being tweaked but largely works as wanted, and personally I am super pleased that it works.
I now realize that the revolving trench transition will be a much better trigger and would negate the need for the sleeps but I guess that's for V2 :) .
I did not create any of the animation its a montage of vids all pulled from youtube.
Anyway the code is fairly self explanatory and looks like this..
Code: [Select]
Loop
run C:\Program Files\VideoLAN\VLC\vlc.exe --repeat C:\trench\Radar.mp4
Loop
ImageSearch,,, 1204, 95, 1393, 138, c:\trench\T.bmp
If (ErrorLevel = 0)
break
sleep 42000
run C:\Program Files\VideoLAN\VLC\vlc.exe --play-and-stop C:\trench\Trench Run.wmv
sleep 40000
And a badly played game video to demo this is here..
« Reply #58 on: November 16, 2013, 08:58:52 pm »
This is a fantastic application of this script!  :applaud:  :applaud:
rockyrocket
« Reply #59 on: November 17, 2013, 06:48:17 am »
Thanks Le Chuck!
Not sure what youtube is upto with my vid though - it has repeated my 5m vid into a 10m one , I had the same thing happen before and it was magically corrected.
Just wish my gameplay was more like this...
