Author Topic: Hantarex MTC 900 Problem  (Read 2264 times)
njay
  • To Nudge or Not to Nudge !
« on: July 13, 2009, 09:39:37 am »
Hi All,
well after the issue that my picture would suddenly disappear i got another problem:
i fixed the disappear picture by soldering the video connectors on the pcb again
but now the monitor buzzes and the screen shakes sometime you can hear the current in the screen i guess.
there are two wires that comes from the plug on the tube one of the wires is not so good anymore this has always been so but after the first fix this has gotten worse.
what can it be? a grounding issue? i got a ground wire from the chassis to a metal plate in my cab.
or can it be that the high voltage cables need to be replaced? and so how can i do that?
thanks for answering
njay
Re: Hantarex MTC 900 Problem
« Reply #1 on: July 14, 2009, 03:43:00 am »
bump :)
njay
« Reply #2 on: July 16, 2009, 04:47:41 pm »
anyone?
i did manage to electrocute myself trying to fix it i pushed the anode cap around abit and it shocked the hell out me .. nearlly killed myself damni ... stupid me
it did solve it a little bit , but any idea how to replace the wires coming from anode cap?
Nipedley
  • Last login:October 04, 2024, 12:03:26 am
« Reply #3 on: July 16, 2009, 08:01:12 pm »
Yes they do give a bit of a shock! 25~30kv usually, you were lucky you werent flung into anything to sustain further damage. To replace the wires from the anode means you need to get a new flyback, as you can't really splice that wire due to the such high voltages it contains as you found out!
Discharge the charge from under the anode so you don't get a shock again, then you can lift it off along with the rest of the chassis and replace the flyback (where the big red wire goes) with a new one if that is your problem. Careful of those big capacitors too, they can give you a jolt though not as big as the anode does.
njay
« Reply #4 on: July 17, 2009, 03:31:25 am »
Hi,
thanks for your answer do you know any dealer that delivers flybacks for the 900?
nevermind found one:
LOPT for MTC900E
but can i use this one ? is it the same as the mtc900 ?
and can you give a good guide to discharge the monitor complety?
« Last Edit: July 17, 2009, 03:34:45 am by njay »
Nipedley
« Reply #5 on: July 17, 2009, 05:34:25 am »
I couldn't say specifically but I know Swallow Amusements do MTC 9000 flybacks, they might do 900 as well (try emailing them if not listed on their site as they do a lot of hantarex repairs)
I know that there are a few differences between the 900/E but I'm not sure if the flyback is one of them will have to wait for someone more knowledgeable on that model to chime in, however I wouldn't bet on them being the same worth looking for a MTC 900 one :)
A guide to discharging? Well there's quite a lot about it in the 'Monitor FAQ' up top. Basically, you get a long screwdriver, 2 alligator clips, clip one end onto the metal shielding going around the front of the tube, clip the other end onto your screwdriver. Then gently slide it in under the anode cap and it will discharge. Make sure you aren't holding onto anything metal, that the alligator clip is far away from your hand etc. and use your right arm to hold it so if it does bite you it won't go through your heart (but if you follow that/common sense and keep away from the metal then it won't anyway).
By no means a thorough guide but if you read the monitor faq sticky there's some more in there. This is what I've always done and it's always worked just fine for me :)
njay
« Reply #6 on: July 17, 2009, 06:36:29 am »
again thanks for you help and post
it still plays in the back of my head that i was very lucky when i got shocked my heart raced like an idiot.
i am in holland so i need to replace the flyback myself, looking at the board it seems removing the anode cap then desoldering the wires and desoldering the flyback from the board...
well if anyone know exactly the correct part i need post it , i can order it then
thanks all !
njay
« Reply #7 on: July 18, 2009, 10:10:13 am »
sorry to be so quick can anyone answer the question:
if the flyback of the 900 is the same as for the 900/e?
njay
« Reply #8 on: July 19, 2009, 12:55:34 pm »
never peeps,
the monitor died on me... since that i cannot get a flyback transformer near me i gave it up.
i will still keep it to be fixed in the future
i bought a second hand 19 inch crt today and installed that in my cab the higher reso i find good , because visual pinball looks amazing
