Author Topic: Retro-Futuristic Mame cabinet  (Read 693404 times)
0 Members and 21 Guests are viewing this topic.
Re: Retro-Futuristic Mame cabinet
« Reply #1360 on: February 13, 2013, 02:06:17 pm »
Wouldn't it be easier....
You lost me there.
jammin0
« Reply #1361 on: February 13, 2013, 02:33:56 pm »
Do you have a friend with a vinyl cutter?  I cut out a square and use that to mask with and it doesn't pull up the paint nearly as often.  I think because the material is more dense and not as thick and I don't know why but I have all but stopped using tape to mask anything.
It would literally take 5 minutes to cut a mask out of adhesive vinyl and any old piece works.  If you didn't live so far away I would throw one in the mail for you this afternoon.
Yvan256
    • Yvan256
« Reply #1362 on: February 13, 2013, 03:06:27 pm »
Wouldn't it be easier just to have the glass stay still and only rotate the monitor?
That's what I would do. Do not rotate the glass but have a fixed, round panel attached to the monitor frame for the mask. Rotate the thing from the inside, keep everything sealed from the outside.
At least it works in Sketchup for MVS-99-6.   ;)
« Reply #1363 on: February 13, 2013, 03:47:18 pm »
« Last Edit: October 04, 2017, 11:28:32 pm by Ond »
XeviouS
  • Last login:March 11, 2016, 08:38:20 am
    • Noah's Arkade
« Reply #1364 on: February 14, 2013, 01:57:03 am »
I'm not in a good mood at the moment though your post cheered me up.  I'm having challenges coating the glass  :banghead:  I thought I had it in the bag on the second go but I waited too long for the primer backing coat (which protects the black paint and provides a surface to stick mounts to) and when I lifted the masking tape the primer coat tore ragged edges.  GAH!
Maybe run a very sharp razor-blade along the edge of the masking tape to cut the paint away from the tape before pulling the tape off?
« Last Edit: February 14, 2013, 01:59:51 am by XeviouS »
Pinball Wizard
« Reply #1365 on: February 14, 2013, 02:42:31 am »
Depending on how the glass was tinted, this may or may not hurt the tinted effect.
Where's my gold star :P
« Reply #1366 on: February 14, 2013, 04:35:12 am »
« Last Edit: October 04, 2017, 11:28:57 pm by Ond »
« Reply #1367 on: February 14, 2013, 06:25:00 am »
Looks bad ass. :cheers:
« Reply #1368 on: February 14, 2013, 07:27:05 am »
Nice! What did you use for the surround ring? Perfect fit in any case!
jammin0
« Reply #1369 on: February 14, 2013, 09:20:22 am »
sweet :applaud:
Yvan256
    • Yvan256
« Reply #1370 on: February 14, 2013, 12:02:17 pm »
Finally I switched on the monitor and fed it some blue, all in all it's the look I had in mind, I'm happy with it, it looks slick no?
Words cannot describe the awesomeness. :o
« Reply #1371 on: February 14, 2013, 01:59:26 pm »
« Last Edit: October 04, 2017, 11:29:31 pm by Ond »
  • Last login:Yesterday at 09:07:40 am
« Reply #1372 on: February 14, 2013, 02:18:37 pm »
Looks like it was made by expensive precision manufacturing equipment.   :notworthy:
« Reply #1373 on: February 14, 2013, 02:21:36 pm »
It is.  Ond's a robot.
smalltownguy
  • Last login:October 07, 2025, 12:45:27 pm
« Reply #1374 on: February 14, 2013, 02:25:44 pm »
I subscribe more to the 'Ond operates on a plane higher than humans' concept too, but not robotic. This project's got WAY more style than a robot could make.
« Reply #1375 on: February 14, 2013, 02:44:04 pm »
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #1376 on: February 15, 2013, 11:26:20 am »
That's the same way I paint my Plexi/Lexan/Glass!!  Aweeesome.
Great job man, keep it up!
« Reply #1377 on: February 17, 2013, 05:24:03 am »
« Last Edit: October 04, 2017, 11:29:56 pm by Ond »
« Reply #1378 on: February 17, 2013, 08:36:14 am »
Those rubber thingies look excellent for the job! :cheers:
ccmathome
  • Last login:February 25, 2021, 12:40:52 am
« Reply #1379 on: March 02, 2013, 09:37:22 pm »
The spray on putty you used would it be any good on exposed mdf edges?
Sent from my SCH-M828C using Tapatalk 2
« Reply #1380 on: March 02, 2013, 10:18:32 pm »
« Last Edit: October 04, 2017, 11:30:21 pm by Ond »
matsadona
« Reply #1381 on: March 03, 2013, 04:29:06 pm »
It really is f-ing unbelievable how much effort you put into this build. The rest of us aren't worhty to call us selves arcade builders  :notworthy:
« Reply #1382 on: March 03, 2013, 09:55:37 pm »
« Last Edit: October 04, 2017, 11:30:44 pm by Ond »
matsadona
« Reply #1383 on: March 04, 2013, 09:55:35 am »
I hope you're there to see it when it all comes together  :cheers:
I'll stick around and would be happy to be the first one to buy you a beer when that day comes!  :cheers:
Yvan256
    • Yvan256
« Reply #1384 on: March 04, 2013, 10:28:59 am »
Let's just define a new category for Ond and we'll be able to keep calling ourselves arcade builders.  ;D
*** Ond has been moved to the "Masterpiece builders" category ***
eds1275
  • Rock and Roll!
« Reply #1385 on: March 04, 2013, 12:22:00 pm »
wait... this is an arcade machine?
« Reply #1386 on: March 04, 2013, 12:55:02 pm »
Nope, a tardis, just not a silly fictional one, but what would really be constructed 500 years in the future.
Superfrog
    • My YouTube Channel
« Reply #1387 on: April 03, 2013, 02:16:29 pm »
Ond,
Did you finished the bartop you started posting at bartopmania or is this your main project  ;D
Greetings
dfmaverick
« Reply #1388 on: April 03, 2013, 02:33:18 pm »
Ugh.
Clicked on this hoping there was an update.   ;)
« Reply #1389 on: May 09, 2013, 07:14:05 pm »
Ond...
...any progress?
quizz_kid
  • Last login:January 01, 2016, 03:10:29 pm
  • In the year 20XX...
    • http://www.lovehulten.com
« Reply #1390 on: May 19, 2013, 08:44:46 am »
Sorry for bumping, but what an amazing build this is. Interesting design and perfect execution!
« Reply #1391 on: May 19, 2013, 06:49:48 pm »
« Last Edit: October 04, 2017, 11:31:14 pm by Ond »
lcmgadgets
« Reply #1392 on: May 23, 2013, 12:45:11 am »
I think this might b the most amazing & beautiful project I've ever seen. :notworthy:
Professor Hayashida
« Reply #1393 on: May 23, 2013, 09:26:56 am »
« Last Edit: October 04, 2017, 11:31:43 pm by Ond »
« Reply #1394 on: May 24, 2013, 09:08:55 pm »
Hmm, this cab looks ... verrrrry familiar! ;) Nice work, as always my friend!
« Reply #1395 on: May 31, 2013, 12:48:44 am »
« Last Edit: October 04, 2017, 11:32:06 pm by Ond »
smalltownguy
« Reply #1396 on: May 31, 2013, 07:15:43 am »
For a minute I was convinced that you were going to tell us about how you modded Astro to heat your garage.
« Last Edit: June 02, 2013, 07:13:44 am by smalltownguy »
« Reply #1397 on: June 02, 2013, 03:52:36 am »
« Last Edit: October 04, 2017, 11:32:36 pm by Ond »
smalltownguy
« Reply #1398 on: June 02, 2013, 07:17:24 am »
OK, so what's the backup plan for when/if the gap is too close? I know you, Ond, you have a contingency plan....
Drnick
  • Plodding Through Life
« Reply #1399 on: June 02, 2013, 09:23:11 am »
I recognise those magnets,  once snapped a pair round my finger,  And I can safely say "damn it hurt" Have you got a pair of glass holders (Big rubber suckers with handles) for when you put it in place/remove the glass.
