Author Topic: Coin Door Wiring  (Read 1294 times)
acevedor2
  • Last login:May 25, 2024, 08:21:24 pm
Coin Door Wiring
« on: December 01, 2008, 01:19:23 am »
I know there are a bunch of threads and I know how to get the coin 1/2 hooked up to the IPAC.  My question is, do I have to send the grounds from the coin mechs back to the ipac as well, or will they work fine just grounded to the cab.
In other words, can i just run the positives from the coin mechs back to their respective ipac ports and then run the grounds to the cab, or do I have to run both positiver and ground from each mech back to the ipac?
Thanks as always!
Cheers!
Dedicated - Working:
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Pool Sharks - Pinball
Projects:
Pole Position
Pole Position 2
Thenasty
  • Last login:April 02, 2026, 11:01:08 pm
Re: Coin Door Wiring
« Reply #1 on: December 01, 2008, 08:38:15 am »
just try it, its quicker than typing this respond, but I connected the nd to the IPAC.  ;)
Free VGA Breakout Cable
Franco B
« Reply #2 on: December 01, 2008, 08:55:50 am »
Just daisy chain the Common terminals (ground), wire them to the IPACs GND terminal and wire each NO (normally open) terminal to the IPACs input terminals (Player 1 coin, Player 2 coin etc)
