November 29, 2025, 03:21:30 pm
You want to wire them to the COMMON and NO contacts of the button.Just wanted to point that out so you dont wire it to the GROUND that goes back to your keyboard emulator. (Keywiz,etc).The button that turns on your PC needs to be separate from your other buttons, electrically.Heres one way to do it.
Consider this, as a tech I generally turned MBs on with the tip of a screwdriver.
