Author Topic: coin door to i-pac??  (Read 2374 times)
Petesie
  • Last login:September 06, 2010, 07:16:23 am
« on: August 15, 2008, 06:53:32 pm »
does anyone know the easiest way to wire my coin door to my mini i-pac so that coins register on the screen??? pictures would be good if possible.
Thenasty
  • Last login:February 26, 2026, 10:04:40 pm
Re: coin door to i-pac??
« Reply #1 on: August 15, 2008, 10:31:41 pm »
same way you connected your buttons. Underneath the Coin Door/Chute, there is also a Cherry Switch. Just wire the GND and (5 in ipac) to NO (normally open). Leave the NC alone, don't wire anything to it. Just those 2 ( GND, NO).
the WIKI have more info.
Free VGA Breakout Cable
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: August 16, 2008, 04:03:15 pm »
Also, if you have a switch with three prongs pointing downward, you'll wire it to the outer ones, leaving the middle prong alone.
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #3 on: August 17, 2008, 12:26:47 pm »
I wire mine up using a molex cable
That way when i remove the cp i can just un-plug it and plug it back in
Slow In Fast Out
Ginsu Victim
« Reply #4 on: August 17, 2008, 12:35:53 pm »
Thank you! I've been trying to figure out an easy solution for something similar. Can't believe I didn't think of that!
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #5 on: August 17, 2008, 01:45:32 pm »
i had a bunch of harness cables from the cabinet i got
so i used some 3 prong power cable dongle molexes
Huge wires though lol
You could easily use a power supply molex from a computer
I know ive use some on arcade projects before
Radio shack also sells them in different sizes
Slow In Fast Out
Ginsu Victim
« Reply #6 on: August 17, 2008, 02:39:19 pm »
Yeah, I have several around here. Time to get to work on it...
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #7 on: August 17, 2008, 06:28:51 pm »
SEE SEE i contribute .... ocasionally.....
Slow In Fast Out
