Author Topic: Illuminated Button: Ultralux, HAPP, others?  (Read 2517 times)
shilmover
  • Last login:September 25, 2018, 12:36:59 am
« on: August 10, 2008, 01:27:49 am »
Hi all,
I have decided to install some illuminated buttons on my MAME cab.
I like the look of Ultralux buttons, but I am concerned that the feel would not be that of a "normal" arcade button (concave).
Any suggestions as to which is better?  I do like the fact that I can put in inserts on the Ultralux buttons.
Barry
My projects...
Finished:  Stargate (only 'cause I got it that way)
In progress:  Tron, 48-in-1 for School Auction, DKJr (currently a 60-in-1), Millipede, MAME System
shilmover
Re: Illuminated Button: Ultralux, HAPP, others?
« Reply #1 on: August 11, 2008, 01:14:10 pm »
No one?
My projects...
pie taster
  • Last login:April 03, 2015, 09:21:51 am
« Reply #2 on: August 11, 2008, 09:38:20 pm »
Just installed the ICE buttons on my mame cabinet last weekend.  I love'em.  If you are going illuminated, you might want to thing about using the ICE buttons with the RGB boards.. the ability to have them be different colors based on the game is pretty hot!  I'd also look at the NovaGems from Groovy Game , although i do not have any.
shilmover
« Reply #3 on: August 12, 2008, 12:17:36 am »
I have the LED-Wiz+GP™ 16-port from GroovyGameGear.  It looks like those would work, no?
I saw the ICE buttons on GGG, but which LEDs would I need?
My projects...
arzoo
  • Last login:January 26, 2025, 08:51:53 am
  • Robots WILL kill you.
    • LEDBlinky
« Reply #4 on: August 12, 2008, 08:40:25 am »
With the ICE buttons you're best off using the RGB Drives from GGG.
Robots will kill you.
Arcade Addiction
pie taster
« Reply #5 on: August 12, 2008, 09:03:52 am »
You can read this post about them here.
Linky
shilmover
« Reply #6 on: August 12, 2008, 10:42:12 am »
That settles it...  I am half way there since I already have the LED-Wiz.
Thank you all!   :notworthy:
My projects...
thatitalian
  • The Revolution Is Coming...
« Reply #7 on: August 12, 2008, 12:33:39 pm »
I had this dilema. The Happ translucents are prob one of the nicer ones as well. You can get inserts for these too from GGG and can get the diffusers from GGG also as they halp spread the light better. You have to mod the buttons a bit but that is what I went for!
Just my opinion.
shilmover
« Reply #8 on: August 12, 2008, 01:34:31 pm »
Just my opinion.
Can you post pics of what yours look like?  what did you have to mod?
My projects...
thatitalian
« Reply #9 on: August 13, 2008, 05:06:22 am »
I haven't done it yet, although this is the path I have taken.
The best place to read about it, and where I found out about it, is here at the bottom of the page:
http://forum.arcadecontrols.com/index.php?topic=72173.40
Franco drilled a hole in the base of the buttons in order to put the led in place. If you have a look through his thread you will also see how he programmed the led wiz (from GroovyGameGear) to run a sequence using an app called ledblinky.
I am sure you will agree it kicks some serious ass!
But don't forget to get those diffusers for the buttons, they will help disperse the light! across the whole top of the button!!
You can read about my dilemma here, I recommend you do!
http://forum.arcadecontrols.com/index.php?topic=82633.msg864388#msg864388
Shieldwolf
  • Last login:November 16, 2020, 12:48:53 am
  • SpearShield.com
« Reply #10 on: August 13, 2008, 10:06:11 am »
I just made the plunge myself. I went with translucent buttons,diffusers and rgb. Can't wait to wire that mess  ;D  :applaud:
shilmover
« Reply #11 on: August 13, 2008, 11:26:15 am »
Boy,
You guys have just complicated everything.   >:D
I was ready to make the plunge and go for the ICE buttons.  I like the fact that they are "Plug-n-Play" (or is that Plug-n-pray?  :)).
Anyone used the HAPP with diffuser and the ICE side by side with the RGB Drive?  I would really love to see that.
Barry
My projects...
