Author Topic: jpac problem - about to give up  (Read 2688 times)
tony
« on: March 10, 2002, 01:05:15 pm »
hi all, finally got around to trying to hook everything up. i am running arcadeOS with the monitor option set to "1" for an arcade screen. switching that back to "0" makes everything run perfectly on my PC.
when i switch it to "1" and try plugging everything into my j-pac, i can see the side by side screen boot up on my arcade screen (the bios info, etc) but then it gives me a "no keyboard attached" error. i've double checked my connections and everything is right.
any suggestions?
thanks
« Last Edit: December 31, 1969, 07:00:00 pm by 1026619200 »
LedFinZep
Re: jpac problem - about to give up
« Reply #1 on: March 11, 2002, 06:55:58 pm »
I'm definately no expert on this subject but have you tried pluging in the keyboard though j-pac's keyboard pass through? Maybe the computer won't run without a kb. Also what happens when you don't have the j-pac set up and are running the computer without the keyboard attached? Does the same problem come up? I don't know if this info helps but I know how frustrating (and eventually rewarding) arcade building can be.
Hope this helps!
Thenasty
  • Last login:Yesterday at 10:33:59 pm
« Reply #2 on: March 11, 2002, 07:08:09 pm »
goto your BIOS setup and select the option for HALT ON ERRORS by default its set to ALL ERRORS, set this to NO ERRORS......
Free VGA Breakout Cable
shane
« Reply #3 on: March 11, 2002, 09:47:28 pm »
glad you mentioned that i havnt gotten around to setting mine all the way up yet
tony
« Reply #4 on: March 13, 2002, 05:45:10 pm »
hi, i tried the halt on no errors.  although the machine now boots to advancemame, not even the keyboard will operate.
i have a replacement coming from andy who has been VERY helpful and a pleasure to deal so i'm sure that will fix my problem...
