Author Topic: Control Panel Hole Sizes  (Read 62445 times)
csa3d
  • Will game for food
    • Galaxian Mame Conversion
« on: September 08, 2007, 02:02:55 pm »
As I'm searching the boards, getting ready to to drill holes, I find that there's really no central location for this sort of information.  If you have reached this thread through a search, and the hole cutting information is not available in the chart below, when you DO find the information, please reply to the thread and include the dimensions for others.  If everyone plays along, this thread will be a resource for those wondering how to cut a hole for any control panel component.
This thread has been moved to the wiki.  Please add/modify entries there.  However, feel free to reply to this thread with additions as well.
Component    Hole Size Required    Recommended Tool    Additional Notes
Push Button Holes
Happs Standard Pushbutton    1 1/8"    Fostner Bit, Hole Saw
GGG Electric Ice Pushbutton    1 1/8"    Fostner Bit, Hole Saw
Happs Mini Pushbutton    1/2"    Drill Bit    fits styles A, B, and C
Leaf Buttons    1 5/32    Fostner Bit, Hole Saw    1 5/32 is perfect but 1 3/16 will work
Atari Volcano Pushbutton    29/64"    standard drill bit
Standard Sanwa/Seimitsu buttons    30mm
Small Sanwa buttons    24mm
Trackball Center Holes
Betson 2.25" Trackball (lip exposed)    2 1/4"    Hole Saw    hole needed for lexan overlay
Betson 2.25" Trackball (ball exposed only)    1 15/16""    Hole Saw    hole needed for lexan overlay
3" Happs Trackball Standard (expose lip)    3"    Hole Saw    Hole needed for lexan overlay
3" Happs Trackball Highball (expose lip)    3 1/4"    Hole Saw    hole needed for lexan overlay
3" Happs Trackball Standard (expose only ball)    2 7/8"    Hole Saw    hole needed for lexan overlay
3" Betson Imperial Trackball (expose lip)    2 7/8"    Hole Saw    hole needed for lexan overlay
Joysticks
UltraStick360 Joystick    1 1/8"    Fostner Bit, Hole Saw    Hole needed for stick to poke up through bottom mount
Suzo (STC) 500 Joystick    1 3/4" & 1 1/8" holes    Fostner Bit, Hole Saw    Holes needed for stick to poke up through bottom mount.  Installation Details
Spinners
SlickStick Tornado Spinner    3/8"    Drill Bit    only shaft pokes out
GGG TurboTwist 2 Spinner    1 1/8"    Fostner Bit, Hole Saw    fits in a standard button hole
-csa
« Last Edit: July 16, 2008, 10:49:37 pm by csa3d »
csa3d
Re: Control Panel Hole Sizes
« Reply #1 on: September 11, 2007, 10:36:39 am »
Can someone with trackball knowledge help fill this out with me?  I find this topic in particular to be quite confusing, as there are a billion ways to mount this stuff.  I'm particularly interested in describing the hole sizes using various trackballs, different STYLE balls, and differences using a plate vs. flush mounting in wood or plexi.
miles2912
  • Last login:October 31, 2019, 05:30:24 pm
  • My first Home Game. Fairchild System F.
« Reply #2 on: September 11, 2007, 06:10:19 pm »
For the trackballs you will need a router (if you want the plate mounted flush) and a jigsaw to cut out hole.  The hole is usually a funky shape.  Not a hole saw.   See pic
  Scratch built upright MAME Cab
csa3d
« Reply #3 on: September 12, 2007, 03:10:37 am »
I suppose I was thinking that you'd put Plexi over the plate, and need to cut a hole in the plexi to cover it.
I suppose this could be another entry for this type of mounting.. how would you reword the above info?  Also, got any measurement specifics to go along with that?
I will be the first to admit, this thread chart is gonna be a team effort.  I'm not hole cutting master ;)
-csa
scotthh
  • Last login:June 06, 2012, 10:03:42 pm
« Reply #4 on: September 12, 2007, 02:02:11 pm »
Happ 3" trackball holes:
If you plan on exposing the lip, it's 2.99" for a high-lip or regular trackball. It's 3.24" for a high ball. See the exploded diagrams I linked to.
If you plan on only exposing the ball, it depends on the thickness of the material between the trackball and the top of the CP.
csa3d
« Reply #5 on: September 14, 2007, 08:49:53 am »
Updates:
- Added dimensions for leaf button according to Whammoed
- Changed trackball entries for clarification
Comments and additions welcome
-csa
« Last Edit: September 14, 2007, 08:51:37 am by csa3d »
csa3d
« Reply #6 on: September 15, 2007, 08:52:07 am »
Updated Happs miniature pushbutton as verified by psychotec
csa3d
« Reply #7 on: September 15, 2007, 02:23:09 pm »
Updated Betson 2.25" trackball as measured off mine.
-csa
WCBoudreaux
  • Last login:February 15, 2022, 07:20:41 pm
« Reply #8 on: October 08, 2007, 03:45:27 pm »
Hey, great idea!
Atari Cone Switches are going to be 29/64"... That's  what size drill bit fits tightly in my Original Space Ace control panel holes... Hope that helps...
Kajoq
  • Last login:June 14, 2024, 11:28:46 pm
« Reply #9 on: October 08, 2007, 08:32:08 pm »
For completion sake - Standard sanwa/seimitsu buttons have a 30mm hole and the small sanwas are 24mm
csa3d
« Reply #10 on: October 11, 2007, 01:59:53 pm »
Updated Chart:
- Sanwa standard pushbutton sizes
- Sanwa small pushbutton sizes
- Atari Volcano pushbutton sizes
Thanks all for additional input, feel free to add more info
Kangum
  • Last login:February 25, 2018, 07:46:20 am
« Reply #11 on: October 12, 2007, 03:39:24 am »
tag for later
stace
« Reply #12 on: November 08, 2007, 10:11:09 am »
Guys,
What size hole do I need for a Happ Competition (Assuming I mount it under the cp) ? 1 1/8 ?
Stace  :)
csa3d
« Reply #13 on: November 08, 2007, 12:51:30 pm »
I did some searching, and didn't see anything specifically going against the 1 1/8" hole rule for bottom mounting a Happs Super.  Maybe someone who's mounted one this way could confirm however.
btw - I have updated the above chart to include Suzo 500's during my search efforts to help you out.
*Edit*
Check this thread and this thread out.  I think it sounds like 1 1/8" is what you're after, assuming you're not putting lexan over top of the CP.  Can someone again, confirm?
-csa
« Last Edit: November 08, 2007, 01:02:50 pm by csa3d »
stace
« Reply #14 on: November 08, 2007, 01:36:06 pm »
Thanks,
No plexi over the top.  CP will be covered in a layout from mame marquees and my understanding is they're 'man' enough to not need covering ?!?
gatordad
  • Trade Count: (+11)
  • Last login:February 21, 2026, 11:26:49 am
« Reply #15 on: November 08, 2007, 03:20:11 pm »
Great Idea  :cheers:
Should be stickyfied for reference.
ArtsNFartsNCrafts
  • Last login:October 12, 2020, 09:22:50 pm
« Reply #16 on: November 08, 2007, 08:17:07 pm »
If anyone has info on drilling the hole for the magstik, it'd be much appreciated!
TeamTEOR
  • Last login:December 14, 2018, 09:43:43 pm
  • Off to the Edge of Reality
    • My Website
« Reply #17 on: November 13, 2007, 04:49:59 am »
Great info here guys. Thanks!
Tom
ArtsNFartsNCrafts
« Reply #18 on: November 21, 2007, 05:34:47 pm »
Thanks guys!  I used the info I found in this thread to drill my control panel last night.  Worked like a charm!  I loaded up a 1 1/8" spade bit and it drilled through effortlessly.
I also made the hole for my joystick 1 1/8".  I sort of just went with my gut on what size to drill, given the very short throw of the magstik plus.  It's being undermounted on 3/4" plywood..
jpenguin
  • Last login:January 29, 2008, 12:13:17 am
« Reply #19 on: December 30, 2007, 03:13:48 pm »
Great lisst, I'l post it on my website.  I have one more tp add:
Happ Sub-Miniature Pushbuttons                  5/16''
jpenguin
« Reply #20 on: December 30, 2007, 03:22:13 pm »
3/4''!  Man,, I hope you routed soome of that wood out.
i DID AN UNDER PANEL MOUNTING FOR MY mAGsTIK+, BUT THE WOOD IS ONLY 1/4''
SpRRy fOr The ToGgLe CaSE
I HATE CAPS-L0OCK
FhM
  • Last login:February 26, 2018, 03:33:01 pm
« Reply #21 on: January 28, 2008, 05:52:43 pm »
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« Reply #22 on: January 28, 2008, 06:33:46 pm »
nicely done... :applaud:
csa3d
« Reply #23 on: January 29, 2008, 09:17:20 am »
awesome!  I was hoping it would end up there.  That way, anyone can edit it and I don't have to watch over it so closely.  Thanks again!
-csa
ArtsNFartsNCrafts
« Reply #24 on: March 04, 2008, 04:50:26 pm »
I HATE CAPS-L0OCK
Nope.  it's really the perfect height, given that it's dedicated to playing vertical games on one end of a cocktail machine.
