Author Topic: WOW New LightGUN Info !!! Woot!!! :)  (Read 608335 times)
0 Members and 10 Guests are viewing this topic.
Smog
  • Last login:April 30, 2007, 06:50:51 am
  • .357
    • How to make a cheap GunCon2 work on your PC
Re: WOW New LightGUN Info !!! Woot!!! :)
« Reply #1720 on: December 22, 2006, 08:13:09 am »
Vista is in beta, and readily available to anyone to download, so why not? People are using it ^_^
The problem is not the OS availability .. but that of the development kits :) I won't use any DK for vista before the software house I work in buys it :D
GunCon2PC Driver on http://guncon2pc.no-ip.org/
mrserv0n
  • Last login:May 25, 2021, 09:20:06 pm
« Reply #1721 on: December 24, 2006, 03:42:36 pm »
My LCD TOPGUN works perfect in windows and in mame i  set my controls to x y mouse axis and also do the hardware calibration once again. However my mouse cursor (gun) will only stick to the sides of the screen it will not go in the middle and it is all jerky and crazy.. But smooth in windows desktop
« Last Edit: December 24, 2006, 04:03:01 pm by mrserv0n »
moihut
  • Newbie
  • Last login:December 27, 2006, 06:43:17 pm
« Reply #1722 on: December 27, 2006, 06:15:20 pm »
Topgun with xbox games?   / A little Help?
I have been using the LCD Topgun with House of the dead 3 and it has been working AWESOME!  But when I try to play starsky and hutch I simply cannot get past the controller selection screen.  This is frustrating and I am wondering if this is a universal problem with the Topgun.  Has anyone else had problems?
The game detects that a lightgun is in port two, but when I try to go back to the main screen it keeps saying something like, "Make sure that the gun is plugged in and pointed at the screen."  It never allows me to calibrate the gun.  I was able to fool the game by starting the calibration routine with my old lightgun.  For some reason I can get into the calibration using the old gun on the plasma screen...but of course the calibration does not work.  Then I switch to the topgun, calibrate and play.  Is there a way around this?
« Last Edit: December 27, 2006, 06:43:17 pm by moihut »
nloding
  • Newbie
  • Last login:January 04, 2007, 06:21:25 pm
« Reply #1723 on: January 01, 2007, 05:00:59 pm »
Heh, I'm totally cheating by asking this:
Does this work with MAME ROMs not listed on the website?  Like CarnEvil, for instance?
I think I'm gonna get one of these for my Xbox, but I'm wondering if I should invest in two for my new cabinet.
This thread is 44 pages long, and I'm making my way through all the posts slowly but surely, so eventually I find the answer.  Like I said, I'm totally cheating by asking this!
aljupy
  • Last login:October 23, 2011, 07:30:06 pm
« Reply #1724 on: January 02, 2007, 06:49:19 am »
When you get this message, you must Unplug and RePlug your lightgun, after that,  Press the Start button of your LCD TOP GUN.
This "trick" will skip the controller screen and the Lightgun will be configured for port two. Now you can go to search somebody to drive the car with controller on port 1  ;)
I´m not sure if I understood the question...
Yes, Carnevil WORKS with LCD TOP GUN on Mame. A shame that my PC just runs that rom at 30 FPS or less  :banghead:
The roms listed on the "lightgun" section on mame32 are the ones that works with lightgun.
Also, You can play lightgun roms on Xbox with MAMEOX
« Last Edit: January 02, 2007, 06:52:35 am by aljupy »
LightspeedJack
  • Last login:February 23, 2007, 03:49:12 pm
« Reply #1725 on: January 06, 2007, 04:49:15 pm »
I have been having a devil of a time trying to find a power transformer that matches the spec's required for the LED stands.
I looked at Staples, Radioshack, Walmart, Target, BestBuy, basically everywhere.
People that were able to acquire AC -> DC 5V 600mA power transformers, where did you get them from?
Is there a good website online that has the right size?
Also I am nervous about ordering one online because I'm not sure how to make sure the adapter plug is the right size to fit into the LED stand plug.
Thanks in advance!
aljupy
« Reply #1726 on: January 07, 2007, 02:49:10 pm »
I usualy buy it in normal Hypermarkets. It is strange if you can not find any in a electronic store.
I bought one in a Chinese local store just for 2 €uros (Around 2 dollars). I use it to feed my Blaze Stand. It powers from 1,5volt to 12 volts :)
Good luck!!
Scumgriever
  • Last login:July 30, 2013, 07:27:31 am
« Reply #1727 on: January 07, 2007, 05:08:25 pm »
Have there been any reports about the new drivers from EMS? (3.2) I am waiting for my guns to arrive and am hoping to make the installation as painless as possible.
Here everyone seems to be saying to use smog's drivers but on silverfox's info it says that the 3.2 drivers work well and to try them first. I'm a little concerned that not many people have tried them though.
Should I just go for Smog's to start with? I'm using mame32 .108 on XP. I realise that this is a little preemptive but I don't like to install and uninstall a zillion drivers if I can avoid it.
ark_ader
  • I glow in the dark.
« Reply #1728 on: January 07, 2007, 06:54:40 pm »
Is there an issue with having two guns pivoted at a 45 degree angle, I have the bars set at the same angle of the monitor but the calibration gets thrown off.
What is the maximum angle I can have the monitor (TFT) in the cab.  I tried it at a steeper angle and needed a step ladder to calibrate  ;D
Is there any issues with the bars located top and botton instead of side to side?
Thanks in advance
LightspeedJack
« Reply #1729 on: January 07, 2007, 10:12:12 pm »
Good luck!!
I have found transformers that do a range that includes 5V (for example, 3V-12V transformers), but all the ones that I found had selectors for the voltage that did not include 5V (i.e. you could switch from 3V to 4.5V to 6V, but there was no way to choose 5V).
Would it damage a Blaze Stand to run it as 4.5V or 6V?
I guess 5V is not a typical American device need? I live in Pittsburgh, PA.
aljupy
« Reply #1730 on: January 08, 2007, 05:29:25 am »
in that case... good news for you. I feed my BLAZE STAND wich have bigger IRLEDS than the standard stand, With just 1,5 volt and it does not affect my gameplay at all.
With 1,5 Volt you can feed your stand without any risk to fry it :D
Also I powered it with 3 Volt and 4,5 Volts with the same results than 1,5 Volt.
Ah, I forgot to Ask you....Why don´t you feed it with a normal USB port??. You can do it.
Or else, If you sacrifice the Recoil, you can feed the stand with the same Lightgun
I feed the Stands of my PC with a PS2 port.... with a USB to PS2 adapter. It works too
« Last Edit: January 08, 2007, 05:35:10 am by aljupy »
aljupy
« Reply #1731 on: January 08, 2007, 09:56:29 am »
You MUST install smog´s GUNCON2PC driver the FIRST ONE.
If it doesn´t work for you in Windows XP. And is not any possibility that it works on your PC......then install another one like wingun www.guncon2driver.com or the EMS driver www.hkems.com
I tried the EMS driver and the Smog´s Guncon2PC, here is a tiny comparation:
1) Guncon2PC moves your cursor faster than EMS.
2) Guncon2PC supports MULTIPLE lightguns with tracking on MAME, EMS just supports one lightgun on Mame.
3) You configure your lightguns the first day, install the Guncon2PC driver and you will forget forget that you have a driver installed. Just connect your Lightgun on the same USB port everytime before play. That´s all.
Your choice, friend. And I just comment that 3 points, there are a lot of reasons to install Guncon2PC ;) GOOD LUCK!!!
Scumgriever
« Reply #1732 on: January 08, 2007, 12:48:08 pm »
Excelent, thanks aljupy. Smog's handywork it is. I'm hoping the guns arrive any day now.
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #1733 on: January 08, 2007, 07:36:59 pm »
Please note some of my info is out of date - the 3.2 drivers were not around at the time. I have not tested them myself.
Also mame handling of mice/lightguns has been completely re-written (for the better), but it means some the mame setup info is incorrect.
LightspeedJack
« Reply #1734 on: January 14, 2007, 11:50:56 pm »
I am unable to feed my LED stands from the USB port since my computer is about 15 feet away from where my projector screen is.
For anyone that is having the same problem I had, I found a website that sells the right power adapter. It arrived today, and seems to be working perfectly well.
The transformer is #VM 1898 at the following URL:
http://www.voltage-converter-transformers.com/switching-ac-dc-supply.html
It took 4 days from ordering to arrival at my door.
chazbeenhad
  • Last login:July 06, 2010, 02:37:28 pm
« Reply #1735 on: January 17, 2007, 02:44:21 pm »
I haven't read all 44 pages of this thread, only about half.
I have a question about this new gun vs using a guncon 2.
What would be the better solution for a mame cabinet using a PC SVGA CRT?
Making an interface (for svga) and using two guncon 2 guns or two of these new guns?
MacroX
  • Last login:October 09, 2007, 11:27:30 pm
« Reply #1736 on: January 23, 2007, 11:20:36 pm »
I'm sure this one!
Ayrk
  • Last login:January 09, 2023, 03:09:42 pm
  • I'm 99% complete, will I ever finish that 1%?
« Reply #1737 on: January 24, 2007, 09:37:41 am »
Does anyone have any suggestions on how to mount the LCD sensor bars?
I have a 17" computer monitor and I'm not quite sure what the best way to keep the bars on it is. Right now I'm leaning towards self adhesive velcro but I figured someone else might have a better idea.
Other than that, this gun rocks hard. Up and running in about 15 minutes from opening the box.
Thanks.
Silver
    • Mods'n'Mods
« Reply #1738 on: February 13, 2007, 10:02:03 am »
I've had both of these working. When you get it working, accuracy is quite similar once the guncon2's are calibrated - so long as the screen is bright.
Building the interface for VGA/SVGA in theory is straightforward (esp. if you have access to a ArcadeVGA) though fiddly in practice.
 The end of the day the Topguns - once setup - work everytime, on everything, in every game, with no-recalibration. Better to hack them into a preffered case IMHO.
fjl
  • Pixels Rule!
« Reply #1739 on: February 26, 2007, 08:00:47 pm »
Sorry, I haven't read all 44 pages so I'll just ask, is there other places in the united states I can buy these guns besides the Hong Kong site?
headkaze
  • 0x2b|~0x2b?
« Reply #1740 on: February 27, 2007, 04:26:55 pm »
Just received two Topguns, and was wondering myself (without having to go through 44 pages of reading). When you said the FIRST ONE, do you mean the first version or the first one listed? So do you mean version 0.8 or 0.9b6?
Why is the official driver from EMS so crap, not allowing you to play with two guns in Mame?
Silver
    • Mods'n'Mods
« Reply #1741 on: February 28, 2007, 06:58:15 pm »
By first one, I believe he means it was the first driver. You should the latest version of it (0.9 or whatever).
Most of the comments about the EMS driver are about a much earlier version, which was - bluntly - useless.
However, I have heard good things about version 3.2 - although I have no idea if it allows 2 players in mame. To be fair this is probably more about how mame deals with stuff rather than EMS' driver. Or rather, more about how windows deals with mice and how mame uses mice as lightguns.
mine are all packed away at the mo, but if I was setting up now I would test out the latest ems and see how it plays in mame. If it did not work 2 player, I'd go with smog's driver.
headkaze
  • 0x2b|~0x2b?
« Reply #1742 on: February 28, 2007, 07:26:38 pm »
I had no choice to use the EMS driver because it wouldn't install for me (kept coming up with an error when trying to install the driver). The Guncon2PC on the other hand works fine for me.
Organic Jerk
  • Last login:May 09, 2013, 12:39:09 am
  • I'm per pixel lit.
    • OmeshPersaud.com
« Reply #1743 on: March 06, 2007, 03:35:15 am »
I've noticed on my Topgun that the D-Pad's up position is rather "soft"...  Every other position gives an apparent tactile "click" when pressed, except for the Up position, which you have to press really slowly and carefully to "feel" the soft click of the button...
Is this a commonailty among them or is it just mine?
Progress Rate:  Moderate      ||      Threads:  Cabinet  |  Art  |  MaLa Layout
XBL: OrganicJerk  |  PSN: OrganicJerk
Fozzy The Bear
  • Handbags at dawn in here!!!
« Reply #1744 on: March 06, 2007, 06:13:18 am »
It's quite common... My two guns do exactly the same thing.
Best Regards,
Julian (Fozzy The Bear)
jamesvi
  • Last login:March 25, 2007, 09:32:25 pm
« Reply #1745 on: March 15, 2007, 09:14:16 pm »
I've installed guncon2 0.96b and am running mame .105 and mamewah fu 1.61.  The cursor bobbles around a lot on my screen.  I've played with the sensitivity in the guncon UI but it doesn't seem to help.  I've also adjusted the sensitivity, speed, etc. settings in the mame analog options screen and also no real change.  Was wondering what could be wrong or if someone could share the specific settings they have in guncon ui and mame analog settings.  Could it also be my calibration procedure - I have the bars on top and bottom of my screen (horizontal) and shoot the bottom right followed by middle, upper left, upper right, lower right and lower left.  The cursor tracks fairly close to the laser but it is just too jittery.  Thanks for any help.
Devastator
  • Last login:April 14, 2007, 10:24:13 pm
« Reply #1746 on: April 12, 2007, 06:42:23 pm »
i just got one of these top gun lightguns and it seems to work well in windows.  however in the latest version of mame32 the cursor is all over the screen.  it doesn't track with the gun at all, it just bounces all over the place.  i've set the controls in mame so analog x is mouse x and analog y is mouse y.  i noticed that it's extremely hard to get mame to recognize the lightguns y movement when setting analog y and it takes many tries.  i have a trackball hooked up too which works fine.  any help is appreciated.
thanx
Fozzy The Bear
« Reply #1747 on: April 12, 2007, 08:20:49 pm »
Hit TAB.... Open the service menu for the game you're playing and run the internal calibration for the game. Unless the software of the original game understands where the gun is pointing you will get exactly this behavior.
Best Regards,
Devastator
« Reply #1748 on: April 12, 2007, 10:35:47 pm »
thanx for the reply.  i've looked at several games and i cannot find a service menu with a calibration.  where do you go once you hit tab?  i've setup all of the player controls and the other items on the list don't give me any options to calibrate.
Devastator
« Reply #1749 on: April 12, 2007, 10:53:43 pm »
ok, scratch that, i found the menu by flipping the service dip switch.  but how am i supposed to calibrate the gun when the reticle is bouncing all over the place.  i ran through the process for police trainer but it did absolutely nothing.  if the reticle is flashing all over the screen, how do i calibrate?
and when i say flashing, i mean rapidly flashing.  it's never in the same spot for more than a split second.
if it's any help, i've also been testing the gun in other emu's and nestopia works fine, but zsnes has the same problem with the reticle flashing all over the screen.
« Last Edit: April 13, 2007, 02:48:03 am by Devastator »
struby
  • Last login:April 23, 2007, 08:42:05 pm
« Reply #1750 on: April 13, 2007, 10:20:20 am »
I don't know alot about the guns, but I just want to make sure you calibrated them using the led bars.
also I have a question, when I use the lightguns, I get an effect where wherever i move the guns aim, the crosshairs in that game move that way farther, like it's only on aim in the center of the screen, is there any remedy for this?
Devastator
« Reply #1751 on: April 14, 2007, 08:07:29 pm »
struby, you'll wanna use the games internal calibration.  for most games you can do this by hitting 'tab' after starting the game and going into the dip switches menu.  from there enable service mode and  back out of the menus.  from my brief experience with this, some games will automatically go into service mode and some games you will have to restart.  when you get into service mode there should be an option for gun calibration.  for most of the games i've messed with you navigate the menus with the 1p start and 2p start buttons.  follow the games calibration steps and this should solve the problem.  hope this helps.
D.
mwinter77
  • Last login:April 20, 2007, 10:53:19 pm
  • I have my own arcade controls!
« Reply #1752 on: April 20, 2007, 01:15:35 pm »
I just got my gun and can't get the dam thing to work.  It 'sees' the screen correctly ie. laser lights when in screen area and goes off when out of screen area.  I have tried the EMS 3.2 drivers first then the latest Smog guncon drivers.  Same thing with both - they show button activity and where the mouse cursor is in windows it will register a left or right click correctly - but never actually moves the pointer anywhere.  I am running XP pro sp2.  Any ideas ?
« Last Edit: April 20, 2007, 01:30:01 pm by mwinter77 »
horseboy
  • Only Saint has those powers.
  • Last login:March 07, 2021, 02:19:14 pm
  • With my last breath, I curse Zoidberg!
« Reply #1753 on: April 20, 2007, 01:35:05 pm »
Most things I have read said installing the EMS drivers first would mess up Smog's drivers. Almost all recomondations say to go with Smog's first.
Quote from: saint
saint is all powerful.
Apparently he is.
mwinter77
« Reply #1754 on: April 20, 2007, 01:56:39 pm »
I uninstalled them and manually uninstalled from device manger.  Then when connecting the gun it did ask for the driver and pointed it to the smog stuff.  If I check in device manager it shows the correct driver.  So I think that is all OK.  When installing smog's it asked for a HID compliant driver after the guncon driver installed.  Which makes sense although the connection between the gun driver and the mouse driver seems to be what is the problem - although the button click register as correct mouse clicks so its kinda wierd only mouse movement is not working.
horseboy
« Reply #1755 on: April 20, 2007, 02:02:18 pm »
I am not exactly sure what the problem was, but it had something to do with some files in the registry after the EMS install.
Quote from: saint
Apparently he is.
mwinter77
« Reply #1756 on: April 20, 2007, 02:33:57 pm »
So if I installed EMS first I am forever screwed unless I reinstall XP ?  Silverfox recommened EMS in his setup guide.  Funny thing is both drivers do the same thing for me - mouse buttons, but no pointer movement.
horseboy
« Reply #1757 on: April 20, 2007, 02:44:25 pm »
I do know some people reformatted and reinstalled to fix it. I think, IIRC, you can delete some specific files in the registry to fix it. Sorry I don't remember much more than that. Just read all the way through this short little thread, and I am sure you will find what I am talking about.  ;D
Quote from: saint
Apparently he is.
Silver
    • Mods'n'Mods
« Reply #1758 on: April 20, 2007, 03:26:23 pm »
My guides out of date now....
Anyway, I have swapped between all the drivers at various times without re-installing. You can always go to device manager and force certain drivers to install.
If the driver is installed, and it registers the button presses of the gun, then the driver must be working.
You must then do the hardware calibration of the Topgun itself. THEN it should start controlling the mouse pointer in windows.
If you can not control the mouse pointer in windows with the gun, do not waste any time trying to get mame to work.
Is the Red light appearing when you point at the screen, and dissapearing when you do not?
Are you far away enough from the screen?
moriartyds
  • Last login:November 05, 2007, 09:09:39 pm
« Reply #1759 on: April 20, 2007, 03:46:32 pm »
Since this thread has been bumped ...
I downloaded Smog's latest drivers but the control panel that comes with it no longer has the calibration button.  There doesn't seem to be a way to manually calibrate anymore via the driver.  Does anyone know if that's by design?
