Author Topic: p360 5v source  (Read 2237 times)
JayTea
  • Last login:July 10, 2009, 03:32:25 pm
  • Whatchu talkin 'bout, Willis?
    • Licoricepizza.com
p360 5v source
« on: February 03, 2003, 02:03:29 pm »
Hello,
     I have read in a few other posts that you can get 5v from the IPAC.  My rookie question to you vets is...uhhh...where?  Where do I solder/connect for the 5v?  The ground is obvious, but where is the 5v lead?  Do I just connect it to one of the unused button connections (7 and 8)?
     I haven't received my p360's yet, so I haven't taken a close look at them, but I do have the IPAC.  WARNING:  I am a circuit board novice, although I did do a trackball mouse hack, so that makes me an experienced novice (is there such a thing?).
 Thanks for any help you can give.
JT the Footballguy
Step in the Arena
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:p360 5v source
« Reply #1 on: February 03, 2003, 02:14:15 pm »
The led pins
JayTea
    • Licoricepizza.com
Re:p360 5v source
« Reply #2 on: February 03, 2003, 02:38:14 pm »
DOH!
thanks.
JT the Footballguy
Step in the Arena
Thenasty
  • Last login:Today at 08:47:34 am
Re:p360 5v source
« Reply #3 on: February 03, 2003, 04:46:52 pm »
goto ultimarc and see the diagram.
Free VGA Breakout Cable
DeathMonk
  • Last login:April 03, 2015, 02:01:12 pm
    • MameStation.3
Re:p360 5v source
« Reply #4 on: February 04, 2003, 09:57:49 am »
cut off a computer case LED lead (plug that goes into the motherboard) and plug it right into the I-PAC..  'Lot easier than soldering!
Now with cup beer holders!
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re:p360 5v source
« Reply #5 on: February 05, 2003, 05:56:52 pm »
Another easy way to get 5 Volts:
Get a USB cable and cut off the "B" end. the red wire inside is 5 Volts, black GND. Plug in to USB port.
Andy
NIVO
Re:p360 5v source
« Reply #6 on: February 05, 2003, 06:10:23 pm »
excellent tip andy, thanks.
SirPoonga
  • Puck'em Up
Re:p360 5v source
« Reply #7 on: February 05, 2003, 06:15:32 pm »
Andy
True, that's how I get 5v for my relay to switch my buttons from the ipac to the trackball.
StephenH
  • Last login:January 09, 2023, 06:15:45 am
Re:p360 5v source
« Reply #8 on: February 07, 2003, 02:15:36 am »
A couple of ideas:
1) You can tap a cable adapter to an unused disk drive connector.   I beleive that the red and black pins offer +5V.
2) You can use a +6v power supply, and connect a diode or resistor in series with it, to drop the voltage.
3) You can see if there are 5V transformers out there.
4) You can build a circuit using a 7805 regulator, with a +12V in.
