Author Topic: Installing Happs 360 Joystick Question  (Read 2234 times)
JayTea
  • Last login:July 10, 2009, 03:32:25 pm
  • Whatchu talkin 'bout, Willis?
    • Licoricepizza.com
« on: January 30, 2003, 04:00:32 pm »
Okay, I've given up on the Wico 360's and I am now planning to purchase the happs 360's.  I looked at the schematics of the joystick, and it comes with a 1/2 bushing for a wood CP and a smaller one for a metal CP.  I am using 5/8 particle board and a 1/8 sheet of plexi (3/4")  Is this bushing going to be long enough, should I use both bushings, or route out the difference for 1/2?
Anyone with experience mounting these, can you share your thoughts?  What did you do?  Thanks in advance!
JT the Footballguy
Step in the Arena
SNAAAKE
  • -Banned-
  • Last login:July 21, 2004, 03:44:18 am
  • Banned for abusive postings.
Re:Installing Happs 360 Joystick Question
« Reply #1 on: January 30, 2003, 04:02:59 pm »
i routed the bottom because i had 1/4 plexi glass over 3/4 wood but i dont think there will be any problem with height if you using 5/8 and 1/8 plexi.
good luck with p360(they are awsome).
JayTea
    • Licoricepizza.com
« Reply #2 on: January 30, 2003, 04:05:41 pm »
So no routing necessary, and use the 1/2 bushing?  Sweet.  Thanks Snaaake ;D
JT the Footballguy
Step in the Arena
DeathMonk
  • Last login:April 03, 2015, 02:01:12 pm
    • MameStation.3
« Reply #3 on: January 30, 2003, 04:27:21 pm »
I have 3/4" MDF with 1/8" Lexan over my CP..  I did no routing and I feel they are a perfect height.
look for yourself
http://www.bryanandcaron.com/mamestation
Now with cup beer holders!
JayTea
    • Licoricepizza.com
« Reply #4 on: January 30, 2003, 05:43:22 pm »
One more thing...did you guys use the 5v from the CPU for power and ground, or CPU power and IPAC ground (if you used IPAC at all)?  Thanks again all!
JT the Footballguy
Step in the Arena
Thenasty
  • Last login:Yesterday at 10:25:52 pm
« Reply #5 on: January 30, 2003, 08:17:17 pm »
I took the 5v from the IPAC itself.
Free VGA Breakout Cable
JayTea
    • Licoricepizza.com
« Reply #6 on: January 30, 2003, 09:37:08 pm »
The IPAC has a 5V lead?  (I need to take a closer look, I guess...someone pass me a beer!)
JT the Footballguy
Step in the Arena
eightbit
  • Last login:September 07, 2019, 07:38:11 pm
  • My cab is never done...
« Reply #7 on: January 31, 2003, 08:41:31 am »
Get the ground from the same source as the 5v. If you get 5v off a hard drive connector get your ground there. If you get 5v from the ipac get your ground there.
My statements are my own opinions. They have the value that the reader gives them. My opinion of my opinion varies between foolish and brilliant and these opinions often change with new information.
JayTea
    • Licoricepizza.com
« Reply #8 on: January 31, 2003, 06:33:31 pm »
Thanks fellas!
JT the Footballguy
Step in the Arena
eightbit
« Reply #9 on: February 01, 2003, 03:03:55 am »
The ipac gets 5v power from the keyboard port, its not much but it will handle the p360's.
