Author Topic: Can someone please QUICKLY check their Betson trackball  (Read 5214 times)
paigeoliver
  • Awesome face!
« on: September 22, 2005, 03:31:31 pm »
Ok, I just ran into the problem that I have to cut a hole for a Betson Imperial PS2 trackball and I forgot which way it faces. There are two possible directions. I remember I did it wrong last time and had to redo the whole panel.
Can someone check please. Which corner does the cord point towards?
markrvp
  • NFL Expert
Re: Can someone please QUICKLY check their Betson trackball
« Reply #1 on: September 22, 2005, 03:38:42 pm »
Here you go.
paigeoliver
  • Awesome face!
« Reply #2 on: September 22, 2005, 03:40:34 pm »
THANK YOU.
I KNEW IT.
I had drawn the thing on the panel the wrong way AGAIN!!
paigeoliver
  • Awesome face!
« Reply #3 on: September 22, 2005, 05:03:53 pm »
Thanks, on a scale from 1 to TOTALLY SWEET I would have to say my trackball install came out TOTALLY SWEET.
brophog
  • Last login:January 20, 2019, 03:49:41 am
« Reply #4 on: September 22, 2005, 05:06:23 pm »
Except for that CD Rom drive........... ;D :police:
paigeoliver
  • Awesome face!
« Reply #5 on: September 22, 2005, 05:11:13 pm »
Whatever!! With the proper shot in Golden Tee I can actually eject the disc!!
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #6 on: September 23, 2005, 12:53:32 pm »
THANK YOU.
I KNEW IT.
Hmm, has betson rotated their TBs 180 degrees?  Mine has the wires on the bottom right corner.  [shrug]  If it works for you, I guess so.
FWIW, happs once rotated their TBs 90 degrees so the wires were on the upper right corner, then rotated back to the original according to Bob Roberts.  IMO, both that happs rotation and the 180 rotation of the betsons will be better for GT type games with a roller on the top, but the original is better for marble madness.  (Actually, MM had its TBs rotated 45 degrees so both the rollers were 45 degrees off from the bottom, which is perfect for MM.)
Robin
Knowledge is Power
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
« Reply #7 on: September 23, 2005, 01:07:08 pm »
Cord is to the lower-right on Betsons.  On the newer casings, the name on the top of the trackball lip will read properly when seated this way.
Stingray
« Reply #8 on: September 23, 2005, 01:45:47 pm »
So what are you building, Paige? I guess you have the day off and are wisely spending it working on a project. I wish the same were true for me.
-S
paigeoliver
  • Awesome face!
« Reply #9 on: September 23, 2005, 11:30:27 pm »
Man, you guys had me scared for a minute. Lower right is fine too, I can always turn it around.
I am doing a cabinet refit, there are a full set of pictures in the project announcements forum.
markrvp
  • NFL Expert
« Reply #10 on: September 23, 2005, 11:55:04 pm »
The mounting diagram I posted is correct for my Betson trackball.  The mouse motions are correct in Windows and in MAME.  Do you guys think I have a "bass ackwards" wired trackball?
Thenasty
  • Last login:Today at 05:34:20 pm
« Reply #11 on: September 24, 2005, 09:06:47 am »
maybe you have the RARE kind, mine also has the cord from bottom lower right (reverse from the pic).
Free VGA Breakout Cable
paigeoliver
  • Awesome face!
« Reply #12 on: September 24, 2005, 10:00:38 am »
As long as it isn't lower left or upper right then I am quite happy.
I barely have enough black vinyl left to recover my Frontline cabinet, redoing the panel on the Super Sprint would mean ordering more.
miles2912
  • Last login:October 31, 2019, 05:30:24 pm
  • My first Home Game. Fairchild System F.
« Reply #13 on: September 24, 2005, 01:56:40 pm »
I am not sure why you wouldn't just plug it and see which way the mouse moves?  That would tell you orientation real quick.  All you would need is a PC w/ a USB connect.
Miles
  Scratch built upright MAME Cab
MajorHavoc
  • Last login:December 04, 2015, 09:08:40 am
« Reply #14 on: September 24, 2005, 10:47:43 pm »
Dontcha just hate it when someone comes along with a simple solution.   ;D
paigeoliver
  • Awesome face!
« Reply #15 on: September 25, 2005, 10:27:05 am »
Miles
Mine is PS2, not USB and I don't have a computer with PS2 that is actually assembled.
pmc
  • Last login:February 07, 2026, 12:21:50 pm
    • website
« Reply #16 on: September 25, 2005, 11:21:40 am »
Mine's a PS/2 and it's got arrows embossed into the top of the casing to indicate up, down, left, and right. For what it's worth, the cabling on this one protrudes from the lower right.
-pmc
NIVO
« Reply #17 on: September 25, 2005, 03:51:01 pm »
mine is ps/2 version as well paige. The way mine works is with the wires going top left corner. And a shameless plug here, RandyT's(groovygamegear) trackball booster kit is excellent. It REALLY does reduce backspin and produces smoother gameplay!
paigeoliver
  • Awesome face!
« Reply #18 on: September 25, 2005, 11:16:37 pm »
Mine has had that kit in it for ages.
Oh, and for the record it was upside down. I had to turn it around, as my cord was lower right.
