Author Topic: MP3 Jukebox Software (Touchscreen, With mp3+g, Video and WMA Tag Support)  (Read 197407 times)
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
Re: MP3 Jukebox Software (Touchscreen, With mp3+g, Video and WMA Tag Support)
« Reply #640 on: February 27, 2007, 06:45:37 am »
Yes it could be somebody using a download manager to repeatedly download the file and use up all the bandwidth. I have a couple of people in mind who might do this.... The same ones that i had in mind before when i had to take the site down in the first place that lead to all this.
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #641 on: February 27, 2007, 07:01:18 am »
There are still many who download v22 of arcade music box (newest version is v30, before I stopped).
This is mainly reason, can because I added my software (wich use a wrong screenshot from a config screen) that to softpedia on that time (they hotlinking to files), and then so spreads to other sites as well.
This can been a another reason, wich can't seen normally bad, and is why I have keept all versions on the server.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #642 on: February 27, 2007, 07:37:32 am »
Well this is why i  prevent hotlinking. The only sites i let hotlink the file were;
http://www.betanews.com
http://www.freeboxjukebox.com
http://forum.arcadecontrols.com
And 2 others that are private sites.
So i am at a loss where it is coming from, beta news only reports 5 downloads for this week so somewhere something is amiss.
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #643 on: February 27, 2007, 08:14:46 am »
I guess you should use 7z as compression instead of zip, since I could bring the installtion size down to around 3mb. This would help a lots of this type of traffic problem.
I use Inno Setup as my installation app (since it support 7z compression), wich is pretty easy to use, have a very good help file and have some wizard as well. It create a new installation exe with included uncompression (so the user do not need to download 7-zip).
If you want, you can so just upload the created exe (wich Im also do with Arcade Music Box).
« Last Edit: February 27, 2007, 08:44:37 am by Space Fractal / Denmark »
squirrellydw
« Reply #644 on: February 27, 2007, 09:20:26 am »
If you want you can host the forum on one of my sites.  I will give you access and you can install SMF if you want.  I am going to start working on the screen shots of the skins and uploading them this weekend if I am lucky.
I b**ch. People listen!!
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #645 on: February 27, 2007, 10:21:30 am »
I cant host the forum yet, since I only can install ONE SMF Forum for all domains I use, installed on my webserver. I could even ask Micfo for a webhotel manager/panel, since they can install that. But it was not need.
The current forum is meanstrem mode in some month, since im now dosent use it yet (and even removed the link from my AMB site. I may use it for my next App (why Im diddent remove that).
If I'm did that, the forum would look more Arcade Music Box based rather than Freebox. Im are not interesed to merge these 2 applications. Other than that I would not have a problem to run a forum.
Sorry about that, but I can still host the little mainsite with a download link of course (still of course use both mirrors). I do hope he change to 7Z as I stated before, since it can bring the traffic very much down (even it not a problem now).
i can ask Saint/sirwoogie if they can greate a forum, here on ArcadeControls.com? I guess they should use child boards for all support boards.
I have just PM saint for how it can been done with a another forum.
« Last Edit: February 27, 2007, 10:48:19 am by Space Fractal / Denmark »
kizer
    • Links4jeeps.com
« Reply #646 on: February 27, 2007, 02:18:47 pm »
Im in the process of contacting my host to add freeboxjukebox as another domain on my account. It supports MYSQL and PHP. Im currently hosting the public download for freeboxjukebox.
It has plenty of bandwith and space available to support what Barcrest needs. If somebody wants to run some bizzare download manager and hit the site hard we can stop that and will. ;) Im already looking into that solution.
However if Barcrest changes his mind between now and when it happens is fine with me. Im just trying to help and support a great app that I believe in.
Anyways just letting everybody know that Im here to help too.
squirrellydw
« Reply #647 on: February 27, 2007, 04:37:11 pm »
I am going to attempt to install SMF on my site along with tinyportal.  The only problem I might have is making sure everything is secure.  If anyone wants to help I can give the FTP access.
squirrellydw
« Reply #648 on: February 27, 2007, 09:25:54 pm »
The Freebox forum is back up!!
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
Here is a nice new feature for the next release. You can make it change the skin and a few other things on set days.... I am hoping to get this release out by friday and upgrade the public version to a newer version.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
So as not to create a load of new threds i have bumped this one...
You can now have songfacts displayed overlaid on your video and piped out to a BETABRITE if you have one. I am looking to upgrade the public version to 2.20 which was the last stable release of V2 once V3 comes out of the alpha/beta phase. Hopefully in a week or so. Obviously if you have donated you can get the latest V3 release from the usual place.
kizer
    • Links4jeeps.com
Of course Barcrest hasn't mentioned the fact that Freebox now has some web support. More or less geek fun, but hey why not. ;)
Meaning check out my sig and his.
Space Fractal
  • Space Fractal
    • Space Fractal
I would still been happy to host your new public version. I hope you still have the ftp account I created for you. it would been good to upload a week before the end of the month (even the traffic from your file is pretty stable). Otherwice contact me.
rayt13
  • Last login:January 26, 2014, 06:36:10 pm
Kizer
I was looking at your sig and  I noticed your file naming setup  (E:\MP3s\F\Foo Fighters\Skin And Bones\15 - Everlong.mp3) is this the best file structure for freebox?
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
Kizer
I go with a simular structure but i just have the folder Atrist - Album\track.mp3 either way os good as long as you have a seperate folder for each album.
kizer
    • Links4jeeps.com
Kizer
Im sure you could go other routes, but I'll break it down so you can see what or why I have it that way.
E:\ - Drive its on
MP3 - The folder its in becuase I have other things on that drive.
F -  Dealing with hundreds of albums its easiet to find things by the bands first letter
Foo Fighters - because thats the band name again easier to find what your looking for
Skin And Bones - is well name of the album
Im sure you could store things differently, but I like to make things easy to navigate on the drive. If I recall you could dump all the albums in one folder and the Tags from the mp3's would be sorted and found in Freebox, but ask me to find something in that setup and it would take forever. ;)
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
For Artists:
J:\MP3s\Artists\F\Foo Fighters - Skin And Bones\15 - Everlong.mp3
J:\ - Drive its on
Artists - These albums are non compilation albums
"Foo Fighters - Skin And Bones" - is the name of the artist and name of the album
For Compilations:
J:\MP3s\Compilations - Various\Various - Now 1 CD 1\Track01.mp3
J:\ - Drive its on
Compilations - These albums are compilation albums
"Various - Now 1 CD 1" - is the name of the artist and name of the album
I don't sort the compilations by letter as there tend to be fewer and i have them all listed as Various so no point really.
DigitalFusion
  • Last login:November 01, 2007, 03:03:26 am
confused... how do I get the newest version of this?
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
Site is down until next month... So check back on wednesday. Too much bandwidth not enough donations LOL
DigitalFusion
are there any mirrors?  I am in a slight rush here.  My ma is getting remarried, and she just asked me to handle the music end of it.  I wanted to slap out a jukebox with a 12" touchscreen and other parts I gave laying around.  My MP3s are a mess, with them organized into folders by genre, then just files with artist and track.  Need to see how much organizing I need to do as well as build the cab and come as close to finishing it as I can within 2.5 weeks.  I still have to rip a couple hundred CD's as well so I am kinda crunched for time!
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
Well to get the latest version you also need to have donated, the public version is mirrored however.
kizer
    • Links4jeeps.com
I dont know exactly what version is the latest for Freebox, since I use the Donation version, but heres a link to 2.1.13 which is a public verison.
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
NEW Public version...
http://www.iamkizer.net/freeboxjukebox/public/setup2220-bankrupt.zip
This was the last stable 2.x build V3.x is not going through private beta's
kizer
    • Links4jeeps.com
Haha, I dig the file name.  :laugh2:
Space Fractal
  • Space Fractal
    • Space Fractal
the old public version used about 3gb bandwidth each month (much lower than I can use on my webhotel). So just upload the new public version to (I have not changed your ftp account, even I have my own jukebox software).
Was these private downloads due to the bandwitch limits (not the forum)?
But fun name for that version  ;D. Hehe
« Last Edit: July 30, 2007, 03:04:44 pm by Space Fractal »
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
Thanks i will upload it tonight. The site is down because of the bandwidth limits yes, it was the private version downloads and also the fact i had that forum signature on the site. Hopefully it will now all be resolved.
kizer
    • Links4jeeps.com
« Reply #666 on: August 01, 2007, 10:43:18 am »
Site is backup.  :applaud:
On the main page it still shows 2.1.13, however its a bit hard to update to the newest release when the site was well down temporarily.
Latest public release
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #667 on: August 01, 2007, 08:28:59 pm »
I seem to have lost the settings to upload to your site, can you either mail them to me or copy the version off kizers site and upload it to your and share the link. Thanks in advance BB
For everyone else the new site is taking shape :D
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #668 on: August 01, 2007, 08:44:33 pm »
Done: http://freebox.spacefractal.com/setup2220-bankrupt.zip (just downloaded and uploaded without touching the file)
I resend ftp account you later....
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #669 on: September 10, 2007, 02:45:06 pm »
Changed the album view, look under the covers....
mccoy178
  • Go Bucks!
« Reply #670 on: September 11, 2007, 01:17:26 am »
That looks awesome! :cheers:
ptpeter
  • Last login:December 14, 2009, 10:39:57 pm
« Reply #671 on: October 04, 2007, 11:26:36 pm »
is it possible to do karaoke with this software? either adding software or what not?
Also, do you need a second screen? or will it work over the screen with freebox 3.0?
« Last Edit: October 04, 2007, 11:28:57 pm by ptpeter »
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #672 on: October 05, 2007, 12:45:19 am »
It will play MP3+G karaoke files, you can have them on the main screen or a second screen.
