Author Topic: IDE cables  (Read 1139 times)
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
IDE cables
« on: June 03, 2005, 01:04:28 pm »
This question is beyond noob, but somehow I never realized this.  I never noticed before that there are 2 kinds of IDE cables.  Some have a pin blocked in the middle and some don't.  I had saved some cables to hack but when I went to hook up the gp wiz the blocked pin prevented it from fitting.  What's the deal?
Chris
    • Chris's MAME Cabinet
Re: IDE cables
« Reply #1 on: June 03, 2005, 01:06:40 pm »
Most IDE hard drives are missing a pin at that spot.  The idea is to keep you from plugging the cable in backwards.
--Chris
Thenasty
  • Last login:Yesterday at 08:07:10 pm
Re: IDE cables
« Reply #2 on: June 03, 2005, 01:08:01 pm »
this is whats called "Plu and Pray" back then....anyway, you can just pull it out.  :D
Free VGA Breakout Cable
DreamArcades
  • Last login:April 26, 2022, 05:36:40 pm
    • Dream Arcades, LLC
Re: IDE cables
« Reply #3 on: June 03, 2005, 01:08:42 pm »
The IDE cables we sell do not have any pin blocks. We use them with mini-pacs all the time.
-Mike
    • GroovyGameGear.com
Re: IDE cables
« Reply #4 on: June 03, 2005, 01:18:05 pm »
Not all of the cables are like that, but sometimes that's a "key" that can be removed.
I have used a heavy needle and managed to pick out the little "plug" before.    You can also heat the needle up and melt through it if all else fails.
