Author Topic: How to set up a 'not' control input definition from the tab menu?  (Read 1088 times)
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
Does anyone know how to set up a control definition from the in-game menu so that for instance, player 1 button 1 is left ctrl but it will not work if key_b is also pressed.  The definition would look like  P1 Button1    Left_Ctrl not B.  I know how to set this up in the ctrlr ini files in regular mame but I am trying to set it up in advancemame and after reading thru the docs I have been unable to find a way to do this.   Thanks
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re: How to set up a 'not' control input definition from the tab menu?
« Reply #1 on: April 23, 2005, 01:28:12 pm »
mameworld.net/easyemu
I believe they show you how there.
Popcorrin
« Reply #2 on: April 23, 2005, 02:58:05 pm »
I already checked there.  They explain how to do it via the ini file method but not from the tab menu.
Thenasty
  • Last login:Yesterday at 10:27:24 am
« Reply #3 on: April 23, 2005, 03:33:05 pm »
select the target
then push Left_CnTRL followed by 2 quick B's.
« Last Edit: April 23, 2005, 03:35:17 pm by Thenasty »
Free VGA Breakout Cable
