Author Topic: Problems w/ my IPAC2, UNWORKING STICKS, ECT.  (Read 2227 times)
mamerocks87
  • Last login:March 17, 2007, 12:21:33 pm
« on: January 22, 2005, 05:31:29 pm »
I just got done wireing up my control panel to the ipac2. Here is a picture of my control panel:
www.debutvm.com/pic1.jpg
The left joystick and buttons are wired to the 1 player inputs. The red 4way stick and buttons are also wired to the 1 player inputs. The right joystick and buttons are wired to the 2player inputs. Everything is wired correctly. When i try to scroll down the list in mamewah, i will push up on the red jostick and the thing will start scrolling to the list repeatedly till it gets to the bottom it doesnt stop, as if it were sticking. The left stick wont even work. My buttons on my left stick wont work either. Whats wrong?>? Everything works when i use my keyboard....
Here are some more pics:
www.debutvm.com/pic2
www.debutvm.com/pic3
thanks,
-Kyle
Reaper
  • Last login:June 24, 2006, 09:11:10 am
  • I want to finish my arcade cabinet!
Re: Problems w/ my IPAC2, UNWORKING STICKS, ECT.
« Reply #1 on: January 22, 2005, 06:42:48 pm »
Well I cant see the pics, but are all the switches wired up the same way? - also check for loose connections. I had a similar problem then I wired up my panel, it turned out that the joysticks were not made very well :( - got it sorted though :)
mamerocks87
« Reply #2 on: January 22, 2005, 06:47:26 pm »
what do you mean are they all wired up the same way? Does it matter ? I know there are the ground, then the other two prongs. Do i have to pick a prong and stick with it for all the controls? The pics should work now.
-Kyle
mamerocks87
« Reply #3 on: January 22, 2005, 06:48:55 pm »
SORRY!
Here are the correct files:
www.debutvm.com/pic2.jpg
www.debutvm.com/pic3.jpg
Thenasty
  • Last login:Yesterday at 04:30:09 pm
« Reply #4 on: January 22, 2005, 06:52:09 pm »
you need to get your pictures straighten out first  ;)
your showing us picture of your tube.
Free VGA Breakout Cable
Paul Olson
    • Paul's Arcade
« Reply #5 on: January 22, 2005, 06:58:52 pm »
The positive wire goes on the NO (Normally Open) prong.  It is the one closest to the ground prong.  Also double check to make sure all the ground wires are connected to each other, it should be a continuous chain.
If you have changed the button configuration from the MAME default on your IPAC, make sure you change the inputs in MAME and MAMEWAH.
Paul
Thenasty
« Reply #6 on: January 22, 2005, 07:04:53 pm »
I already see something wrong here...
mamerocks87
« Reply #7 on: January 22, 2005, 11:47:22 pm »
Thanks guys, your right , i had it wired wrong. I appreciate it.
-Kyle
sasuke_kun12
  • Last login:March 10, 2009, 09:05:13 pm
  • Its been to long... I'm never leaving this place!
« Reply #8 on: January 22, 2005, 11:53:28 pm »
i did that too! i'm soo stupid
Why are all the good, cheap lowboys in brisbane?
Reaper
« Reply #9 on: January 23, 2005, 04:13:06 am »
Got it all working now?
sasuke_kun12
« Reply #10 on: January 23, 2005, 05:25:38 am »
just gotta get the grounds soldered right.....
