Author Topic: Happ Perfect 360's and power supply  (Read 1950 times)
namedos
  • Last login:July 16, 2025, 07:15:23 pm
« on: January 21, 2005, 12:23:53 am »
I know you can daisy chain the grounds but does anyone know if you can daisy chain the +5V on the 360's?  I was going to get the power from a Y-splitter on my molex connection from the PC power supply.
My other option is to run a separate line for each joystick.  Thanks.
Thenasty
  • Last login:February 26, 2026, 10:04:40 pm
Re: Happ Perfect 360's and power supply
« Reply #1 on: January 21, 2005, 01:11:08 pm »
you can. Its still in parallel series so no voltage drop.
Free VGA Breakout Cable
namedos
« Reply #2 on: January 21, 2005, 01:34:27 pm »
Thanks Nasty,
I just realized that it would probably be a heck of a lot easier to pull the power from the Optipac than it would from the PC power supply.  Less running of wire and all self contained within the CP.
Taborious
  • Last login:December 29, 2011, 04:55:45 pm
  • Win or go Home!
    • The Way Back Machine
« Reply #3 on: January 21, 2005, 03:15:17 pm »
I was told that the Happ 360 could connect to a regular encoder, like the IPac4 and you didn't specifically need an optical encoder, that true? I am contemplating the 360's but still on the fence...
The Way Back Machine - http://www.taborious.com
namedos
« Reply #4 on: January 21, 2005, 04:29:01 pm »
It can be hooked up to the I-pac but it apparently is easier to hook up to the opti-pac.  Since I've got one of those already going into my CP I figured I'd take the easiest way.  Based on some other comments I'm trying to figure out what the Best way to go about this is.
Thenasty
« Reply #5 on: January 21, 2005, 04:59:18 pm »
have you seen my pooormans diagram above ?
Will
  • Last login:April 08, 2012, 03:32:27 am
  • Finished Lurking.....
« Reply #6 on: January 21, 2005, 05:55:44 pm »
I have an I-pac 4 and i see no connections for power.My plan had been to run a wire from my power supply.Can anyone confirm if the ipac-4 has 5v that can be used?
Thenasty
« Reply #7 on: January 21, 2005, 08:17:41 pm »
here
Will
« Reply #8 on: January 21, 2005, 09:03:12 pm »
in the immortal words of homer simpson "DOH" .What kind of connector should I use for those pins,just normal quick connects?Thanks nasty.
« Last Edit: January 21, 2005, 09:04:51 pm by Will »
Thenasty
« Reply #9 on: January 21, 2005, 10:06:37 pm »
you only need 2 of those pins (check the site which ones). Use an extra cable from a CASE that hooks up to the LED, RESET, SPEAKER etc.. of the motherboard.
