Author Topic: Different Types of Coin Apparatus  (Read 878 times)
Ler6557
  • Last login:May 07, 2006, 08:47:22 pm
« on: October 21, 2004, 11:28:31 am »
Fellow MAMERS,
I am brand new to the whole bulid your own arcade thing and I had a question about the different types of coin apparatus. What is the difference/function of the coin door, coin compariotr, OVER/Under, and Coin Mech? And what is that black plate underneath the coin door with a lock on it? What I want is a regular two token slot coin door that accepts both tokens and quarters. If anybody could explain the differences and functions of the above and help me out a little bit I'd be very thankful. Thanks.
Thenasty
  • Trade Count: (+17)
  • Last login:November 28, 2025, 10:23:55 pm
Re:Different Types of Coin Apparatus
« Reply #1 on: October 21, 2004, 01:07:35 pm »
All of them do one thing, Accept the Tokens/Coins.
Coin Door -  a door that opens and consist of a COIN MECH
               when has a coin entry to slide down to the MECH.
                and trigger a coin switch for credit. or just to
                 cover that nasty hole you have.
Coin Mech - is what make TOKENS/COINS to be accepted or
                    rejected.
The bottom plate of a over/under door consist a bucket that hold TOKENS/COINS and has a lock on it so no one stills your TOKENS/COINS.
Comparitor - accepts different type of COINS and COMPARE which one is put in and route it for the right credit assigned.
If you need a COIN MECH that will just accept ANTYHING without comparing it, take a look here.
http://www.arcadecontrols.org/yabbse/index.php?board=2;action=display;threadid=19200
or maybe you can make one yourself.
Here is a good place to really look at what a coin door is.
http://www.happcontrols.com/coindoors/doors.htm
« Last Edit: October 21, 2004, 01:17:35 pm by Thenasty »
Free VGA Breakout Cable
