Author Topic: How long is your stick? :o  (Read 1802 times)
crashwg
« on: June 08, 2004, 12:01:41 am »
I've been thinking for a little while about how I'm going to mount my t-stick plus with red balltop, and I've come to the conclusion that mounting it under the cp with t-nuts will make it a bit low...
My CP is 3/4" mdf, which I planned to route (sp) the bottom out to make 1/2" as I used in my experimentation, but it still seems too short.
As you can see in the attached pic, the top of the ball is only 2
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
NoOne=NBA=
Re:How long is your stick? :o
« Reply #1 on: June 08, 2004, 12:07:17 am »
I mounted mine straight onto the bottom of my 3/4" CP, with the long balltops.
They are a bit low, but have a good Crazy Climber feel to them.
My Wico's are definitely taller.
I routed those 3/8", and did a bottom mount on them too.
crashwg
« Reply #2 on: June 08, 2004, 12:13:04 am »
Here's the drawing I did.  Yes I did it on cad and yes I have too much time on my hands.  :P
BTW I've also considered extending the bracket top and bottom, adding 4 more bolts and having it mount more like a TB mounting plate.
Lemme say it again
danny_galaga
  • Last login:Yesterday at 08:10:56 pm
    • dans cocktail lounge
« Reply #3 on: June 08, 2004, 12:50:48 am »
i would definitely route that. mine is plenty strong enough at 6mm which in biblical terms is 1/4 ". It doesnt feel too short to me but then im used to shortish sticks anyway so i dont notice the extra 6mm. the aluminuim was just to give something nice for the vinyl contact to stick to but i guess it would strengthen it a little...
just had a thought though. you could just do a shallow route on the top side, cut a large hole for the joy to sit in and skin it in ali like mine. then the effect would be the same as if the joys were mounted to a metal panel. drawback would be the wacky shaped hole youd have to cut i guess.
you could just make it from metal...
Minwah
    • MAMEWAH
« Reply #4 on: June 08, 2004, 04:55:20 am »
crashwg: Do you have the 'long' or 'short' balltop stick?
It doesn't look too bad to me, maybe route 5mm or so if you think it will bother you.
etumor
  • Last login:July 04, 2012, 06:56:30 pm
    • Supercade: Classic Arcade System
« Reply #5 on: June 08, 2004, 11:50:46 am »
A quick off-topic question Danny,
What did you use to drill through the aluminum?  Was it just a standard hole saw or did you use a forstner bit?  I checked your website, but you don't say specifically.
-Jeff "etumor" Allen
SNAAAKE
  • -Banned-
  • Last login:July 21, 2004, 03:44:18 am
  • Banned for abusive postings.
« Reply #6 on: June 08, 2004, 03:41:29 pm »
How long is my "stick" ?
Give me a sec...*takes out rular and mesures*
About 7"  :D ;D
« Last Edit: June 08, 2004, 03:42:15 pm by SNAAAKE »
Thenasty
  • Last login:Today at 02:42:00 pm
« Reply #7 on: June 08, 2004, 03:56:29 pm »
About 7"  :D ;D
Is that 7" from the ground ?  :D
Mine is barely touching the ground. I had to tuck it DOUBLE to stay away from TROUBLE.  ;D
« Last Edit: June 08, 2004, 03:57:48 pm by Thenasty »
Free VGA Breakout Cable
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #8 on: June 08, 2004, 04:03:19 pm »
NO MORE!!
Minwah
    • MAMEWAH
« Reply #9 on: June 08, 2004, 07:01:36 pm »
Sorry, I obviously can't answer this for Danny but...
I have just been making an aluminium CP for my analog controls, and used a hole punch (or Knockout as I believe they are commonly known) for button holes.  Oscar swears by Greenlee punches, although I only bought a cheap one as a) I don't need to make many holes and b) I couldn't find any better ones in the UK anyway...  The punch worked superbly  ;D
danny_galaga
« Reply #10 on: June 08, 2004, 07:28:24 pm »
I used a good quality hole saw, which sort of made up for my bad quality hole sawing! Doing that meant I could put the ali in place and saw through both ali and MDF at once. The holes are a bit rough on the ali but cant be seen when switches are in. joystick hole was with drill bits. Drill small hole first and then progress two or three sizes to final size
« Last Edit: June 09, 2004, 06:42:14 am by danny_galaga »
crashwg
« Reply #11 on: June 09, 2004, 08:15:27 pm »
Well, my GF doesn't seem to have any problems with the height of the stick, so... I guess I'll be routing the bottom of the cp out
Lemme say it again
xoopx
  • Last login:June 09, 2004, 08:10:08 pm
« Reply #12 on: June 09, 2004, 08:23:20 pm »
this was the cheap and dirty solution i came up with.
yes, its stuck underneath with epoxy.
it hasnt really ruined the joystick. if i want to re-use it properly its not a big deal to get all that crap off again.
summary. i think it depends on the size of your hands
danny_galaga
« Reply #13 on: June 10, 2004, 12:15:01 am »
 i think id end up snapping that off!
