Author Topic: How to coin wire a 60 in 1 Board in a Ms Pacman cabinet  (Read 3736 times)
hypergaming
  • Last login:May 04, 2022, 09:51:07 pm
« on: September 27, 2016, 10:56:51 pm »
Hi everyone,
can someone tell me  ( if possible send me a picture ) of where and how exactly do I connect the " coin " wires from a 60 in 1 icade board to a Ms Pacman Cabinet? I want to set it up so is coin operated. is this possible? here is a picture of the coin door of my Ms pac Man cabinet.
thank you!!    :notworthy:
behrmr
Re: How to coin wire a 60 in 1 Board in a Ms Pacman cabinet
« Reply #1 on: September 27, 2016, 11:16:30 pm »
To the coin switches that are right there under the coin mechs.
JDFan
« Reply #2 on: September 27, 2016, 11:30:31 pm »
Not positive but seems like the blue and green wires - so trace them back to the plug and see which connections they use -- looks like the green is ground and blue is coin connection ( from the pic looks like both coin mechs are interconnected so on the Jamma harness you'd only use coin1 connection and ground.
hypergaming
« Reply #3 on: September 27, 2016, 11:40:31 pm »
THANKS people, I'll give that a try. I appreciate your time.
A.
hypergaming
« Reply #4 on: September 28, 2016, 09:15:38 pm »
so I wired the coin wires from thr 60 in 1 jamma, to the middle leg on the coin door switches ( between the green and the blue wires ), I then turned off free play on the 60 in 1 jamma settings, and tried a coin in the coin mech but it did not work, could it be  that the coin mech is broken or the wiri g is bad?
Thenasty
  • Last login:Yesterday at 12:04:48 am
« Reply #5 on: September 28, 2016, 10:50:11 pm »
you need to wire the green to gnd and the blue to coin, not  the middle leg as you described.
you ca test the switch with a multimeter in continuity mode.
Free VGA Breakout Cable
hypergaming
« Reply #6 on: September 28, 2016, 11:03:18 pm »
well in the picture as you see, these wires ( blue and green )are already on the coin mech switch ( soldered )
the coin wire coming from the 60 in 1 Jamma harness is a green wire, there is no blue wire, do I wire this green to the green in the coin mech?
( just curious, what is the middle metal leg for then? )
JDFan
« Reply #7 on: September 28, 2016, 11:22:04 pm »
THe middle leg appears to be a NC (Normally Closed) connector like on regular microswitches -- SO is just left with no wire as it currently is.
THe green and blue are the NO(normally Open) and Ground -- SO you want to run one of them to the COIN on the jamma connector and one of them to a ground on the jamma connector. ( doesn't really matter which goes to which as the switch merely completes the connection when the coin drops and moves the switch to closed rather than open so either wire could be run to either connection as long as one goes to ground and the other goes to the coin connection. - So if you prefer doing green to green and blue to ground that will work also.
So what happens is when the coin drops it activates the switch which makes a connection between the Green and Blue wire which sends a pulse to the board letting it know that a coin has been put in.
« Last Edit: September 28, 2016, 11:24:37 pm by JDFan »
hypergaming
« Reply #8 on: September 28, 2016, 11:26:36 pm »
Thanks for the information, I'm trying this now as I type, I'll be back soon  and let you know how it went, thanks again!!
hypergaming
« Reply #9 on: September 29, 2016, 07:31:07 am »
thanks JDFan, you were correct, I gave it a try and it worked! I was able to do both coins, thanks again!
thanks everyone for your help on this :)
