Author Topic: DemulShooter (Dual light gun on DEMUL, Model2, Dolphin, Silent Hill, etc...)  (Read 1904335 times)
0 Members and 35 Guests are viewing this topic.
drewjbx
  • Last login:June 03, 2024, 02:36:17 pm
« Reply #1840 on: October 30, 2019, 04:11:02 am »
I think I might have figured out the issues I was having.  onto a different issue,  I'm trying to test out house of the dead 4 with teknoparrot and apparently it's a well known issue, but no matter how or what keys I assign to the controller setup I can't get the p1 and p2 start buttons to work so I can't even test to see if demulshooter is working cause I can't get any signed keys to work.  anyone know a fix?  I wish you could assign keys within RH loader
I got P1 working but currently have the P2 firing the P1 gun problem. Other than that its running great so far. I am using 339 gameloader -
'Loader 1 settings' - resolution set to my monitor for FS. Then using TP 226 for button mapping with the following settings in pic below.
Also have DemulShooter and Mousefix launched before starting game. Be sure to uncheck UseMouseForGun… you lose mapped controls if you have it checked.
If you can figure out the 2P issue please share.
« Last Edit: October 30, 2019, 04:25:35 am by drewjbx »
drewjbx
« Reply #1841 on: October 30, 2019, 04:19:37 am »
Have an old problem here I never figured out that I would like to fix.... can someone tell me how to get fix the Ninja Assault reload off screen issue??
Using the newest demulshooter and all other demul games work fine. Using Demul 07a 180428 specifically for gun games. Perhaps its the rom version I am using?? (ninjaslt)
argonlefou
  • Last login:Yesterday at 12:48:33 am
« Reply #1842 on: October 30, 2019, 04:47:31 am »
Do not use MouseFix and DemulShooter at the same time
MouseFix is for 1player with mouse only
drewjbx
« Reply #1843 on: October 30, 2019, 05:06:33 am »
Ohhh ok... thanks!
Gimpy
  • Last login:May 20, 2021, 05:26:55 pm
« Reply #1844 on: October 30, 2019, 06:23:02 am »
Hi All, another n00b question here.
I have the aimtrack and can get that to work fine, but I am having trouble running it in conjunction with demulshooter. If I use the aimtrack without it, I can play games on demul fine (although of course without the benefits of DS), and I can get demulshooter to load independently, but it's like demulshooter doesn't recognise the Aimtraks inputs?
I can select it's item ID from the dropdown in DSDiag or the Config menu, but it never actually registers anything in the ds_diag test, - no clicks, etc, so if I open a game via a demulshooter command prompt, I can't actually aim/select anything. Also a weird side effect is when I exit, my regular mouse stops behaving correctly, double left click opens properties, etc - not really my priority but I figure it's related.
I feel like I have to be missing something insanely obvious, like there is some rawinput/xinput option that is set wrong, but I can't find anywhere that jumps out - I've gone through the config instructions a bunch of times, and I don't know if I am having screen blindness to something glaringly obvious or what. I also have DS installed in the root folder of Demul, don't know if that makes a difference either
Any help would be massively appreciated!
edit: ignore this, I was somehow mixing up 2 similar hardware IDs and somehow never picked up on it - genuinely idiotic!
« Last Edit: October 30, 2019, 05:14:42 pm by Gimpy »
drewjbx
« Reply #1845 on: October 30, 2019, 07:21:07 am »
Argon can you take a look at this log for hotd4... P2 controls P1 fire, grenade, and reload. The log is just a snippet as its too long to post here. If need the full log I can send to you.
- DemulShooter 8.5.7 (no mouse fix as you stated), gameloader to launch FS, and using 2 aimtraks.
04:10:53.284202 : -------------------- Program Start ----------------------
04:10:53.284202 : P1 device = \\?\HID#VID_D209&PID_1603&MI_02#8&1544c414&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd}
04:10:53.284202 : P1 Device Handle = 65597
04:10:53.284202 : P2 device = \\?\HID#VID_D209&PID_1604&MI_02#8&20c6f137&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd}
04:10:53.284202 : P2 Device Handle = 65599
04:10:53.284202 : P3 device =
04:10:53.284202 : P3 Device Handle = 0
04:10:53.284202 : P4 device =
04:10:53.284202 : P4 Device Handle = 0
04:10:53.284202 : Cmdline arg 1 : -target=lindbergh
04:10:53.284202 : Cmdline arg 2 : -rom=hotd4
04:10:53.284202 : Cmdline arg 3 : -v
04:10:53.304263 : Waiting for Lindbergh hotd4 game to hook.....
04:11:05.501697 : Cannot read memory at address 0x08053C8C
04:11:05.501697 : Cannot read memory at address 0x00000010
04:11:05.501697 : Cannot read memory at address 0x00000024
04:11:06.002699 : Cannot read memory at address 0x08053C8C
04:11:06.003698 : Cannot read memory at address 0x00000010
04:11:06.003698 : Cannot read memory at address 0x00000024
04:11:06.503697 : Cannot read memory at address 0x08053C8C
04:11:06.503697 : Cannot read memory at address 0x00000010
04:11:06.503697 : Cannot read memory at address 0x00000024
04:11:06.999697 : Cannot read memory at address 0x08053C8C
04:11:06.999697 : Cannot read memory at address 0x00000010
04:11:06.999697 : Cannot read memory at address 0x00000024
04:11:07.502697 : Cannot read memory at address 0x08053C8C
04:11:07.502697 : Cannot read memory at address 0x00000010
04:11:07.502697 : Cannot read memory at address 0x00000024
04:11:08.004697 : Cannot read memory at address 0x08053C8C
04:11:08.004697 : Cannot read memory at address 0x00000010
04:11:08.004697 : Cannot read memory at address 0x00000024
04:11:08.500698 : Cannot read memory at address 0x00000024
04:11:08.999668 : Cannot read memory at address 0x00000024
04:11:09.502701 : Cannot read memory at address 0x00000024
04:11:10.000698 : Cannot read memory at address 0x00000024
04:11:10.503700 : Cannot read memory at address 0x00000024
04:11:11.004698 : Cannot read memory at address 0x00000024
04:11:11.500699 : Cannot read memory at address 0x00000024
04:11:12.001700 : Cannot read memory at address 0x00000024
04:11:12.499699 : Cannot read memory at address 0x00000024
04:11:12.999697 : Cannot read memory at address 0x00000024
04:11:13.500698 : Cannot read memory at address 0x00000024
04:11:14.001697 : Cannot read memory at address 0x00000024
04:11:14.500699 : Cannot read memory at address 0x00000024
04:11:14.999697 : Cannot read memory at address 0x00000024
04:11:15.502698 : Cannot read memory at address 0x00000024
04:11:16.002697 : Cannot read memory at address 0x00000024
04:11:16.507699 : Cannot read memory at address 0x00000024
04:11:16.999696 : Cannot read memory at address 0x00000024
04:11:17.500698 : Cannot read memory at address 0x00000024
04:11:18.000698 : Cannot read memory at address 0x00000024
04:11:18.501698 : Cannot read memory at address 0x00000024
04:11:18.999698 : Cannot read memory at address 0x00000024
04:11:19.499697 : Cannot read memory at address 0x00000024
04:11:20.006698 : Cannot read memory at address 0x00000024
04:11:20.500697 : Cannot read memory at address 0x00000024
04:11:21.001698 : Cannot read memory at address 0x00000024
04:11:21.503695 : Cannot read memory at address 0x00000024
04:11:22.002697 : Cannot read memory at address 0x00000024
04:11:22.500698 : Cannot read memory at address 0x00000024
04:11:23.001699 : Cannot read memory at address 0x00000024
04:11:23.504696 : Cannot read memory at address 0x00000024
04:11:24.003698 : Cannot read memory at address 0x00000024
04:11:24.501698 : Cannot read memory at address 0x00000024
04:11:25.002703 : Cannot read memory at address 0x00000024
04:11:25.501699 : Cannot read memory at address 0x00000024
04:11:26.003698 : PlayerData_Base_Address = 0x161D0A8C
04:11:26.003698 : Attached to Process BudgieLoader.exe, ProcessHandle = 1368
04:11:26.004701 : BudgieLoader.exe = 0x00040000
04:11:26.012699 : Memory Hack complete !
04:11:26.013696 : -
04:12:04.829669 : RawData event for Device #2:
04:12:04.829669 : Device rawinput data (Hex) = [ 8487, FFFF ]
04:12:04.833699 : PrimaryScreen Size (Px) = [ 1920x1080 ]
04:12:04.834699 : OnScreen Cursor Position (Px) = [ 993, 1079 ]
04:12:04.835699 : OnClient Cursor Position (Px) = [ 993, 1080 ]
04:12:04.837699 : Game client window resolution (Px) = [ 1920x1081 ]
04:12:04.837699 : Game Position (Hex) = [ 0084, 00FF ]
04:12:04.837699 : Game Position (Dec) = [ 132, 255 ]
04:12:04.837699 : MouseButton (Hex) = 0x0000
04:12:04.838699 : -
04:12:04.845701 : RawData event for Device #2:
04:12:04.845701 : Device rawinput data (Hex) = [ 8467, FFFF ]
04:12:04.846700 : PrimaryScreen Size (Px) = [ 1920x1080 ]
04:12:04.846700 : OnScreen Cursor Position (Px) = [ 993, 1079 ]
04:12:04.846700 : OnClient Cursor Position (Px) = [ 993, 1080 ]
04:12:04.846700 : Game client window resolution (Px) = [ 1920x1081 ]
04:12:04.846700 : Game Position (Hex) = [ 0084, 00FF ]
04:12:04.846700 : Game Position (Dec) = [ 132, 255 ]
04:12:04.846700 : MouseButton (Hex) = 0x0000
04:12:04.847699 : -
04:12:04.853699 : RawData event for Device #2:
04:12:04.853699 : Device rawinput data (Hex) = [ 8407, FFFF ]
04:12:04.853699 : PrimaryScreen Size (Px) = [ 1920x1080 ]
04:12:04.853699 : OnScreen Cursor Position (Px) = [ 990, 1079 ]
04:12:04.853699 : OnClient Cursor Position (Px) = [ 990, 1080 ]
04:12:04.853699 : Game client window resolution (Px) = [ 1920x1081 ]
04:12:04.854700 : Game Position (Hex) = [ 0083, 00FF ]
04:12:04.854700 : Game Position (Dec) = [ 131, 255 ]
04:12:04.854700 : MouseButton (Hex) = 0x0000
04:12:04.854700 : -
04:12:04.861669 : RawData event for Device #2:
04:12:04.861669 : Device rawinput data (Hex) = [ 8337, FFFF ]
04:12:04.861669 : PrimaryScreen Size (Px) = [ 1920x1080 ]
04:12:04.861669 : OnScreen Cursor Position (Px) = [ 984, 1079 ]
04:12:04.862698 : OnClient Cursor Position (Px) = [ 984, 1080 ]
04:12:04.862698 : Game client window resolution (Px) = [ 1920x1081 ]
04:12:04.862698 : Game Position (Hex) = [ 0083, 00FF ]
04:12:04.862698 : Game Position (Dec) = [ 131, 255 ]
04:12:04.862698 : MouseButton (Hex) = 0x0000
04:12:04.862698 : -
04:12:04.877667 : RawData event for Device #2:
04:12:04.878701 : Device rawinput data (Hex) = [ 82E7, FFFF ]
04:12:04.878701 : PrimaryScreen Size (Px) = [ 1920x1080 ]
04:12:04.878701 : OnScreen Cursor Position (Px) = [ 981, 1079 ]
04:12:04.878701 : OnClient Cursor Position (Px) = [ 981, 1080 ]
04:12:04.878701 : Game client window resolution (Px) = [ 1920x1081 ]
04:12:04.878701 : Game Position (Hex) = [ 0082, 00FF ]
04:12:04.879698 : Game Position (Dec) = [ 130, 255 ]
04:12:04.879698 : MouseButton (Hex) = 0x0000
04:12:04.879698 : -
04:12:04.885699 : RawData event for Device #2:
04:12:04.885699 : Device rawinput data (Hex) = [ 8297, FFFF ]
04:12:04.885699 : PrimaryScreen Size (Px) = [ 1920x1080 ]
04:12:04.885699 : OnScreen Cursor Position (Px) = [ 979, 1079 ]
04:12:04.885699 : OnClient Cursor Position (Px) = [ 979, 1080 ]
04:12:04.885699 : Game client window resolution (Px) = [ 1920x1081 ]
04:12:04.885699 : Game Position (Hex) = [ 0082, 00FF ]
04:12:04.885699 : Game Position (Dec) = [ 130, 255 ]
04:12:04.885699 : MouseButton (Hex) = 0x0000
04:12:04.886698 : -
04:12:04.902701 : RawData event for Device #2:
04:12:04.902701 : Device rawinput data (Hex) = [ 8227, FFFF ]
04:12:04.902701 : PrimaryScreen Size (Px) = [ 1920x1080 ]
04:12:04.902701 : OnScreen Cursor Position (Px) = [ 976, 1079 ]
04:12:04.902701 : OnClient Cursor Position (Px) = [ 976, 1080 ]
04:12:04.902701 : Game client window resolution (Px) = [ 1920x1081 ]
04:12:04.902701 : Game Position (Hex) = [ 0082, 00FF ]
04:12:04.903700 : Game Position (Dec) = [ 130, 255 ]
04:12:04.903700 : MouseButton (Hex) = 0x0000
04:12:04.903700 : -
04:12:04.909667 : RawData event for Device #2:
04:12:04.909667 : Device rawinput data (Hex) = [ 81C7, FFFF ]
04:12:04.909667 : PrimaryScreen Size (Px) = [ 1920x1080 ]
04:12:04.909667 : OnScreen Cursor Position (Px) = [ 973, 1079 ]
04:12:04.910700 : OnClient Cursor Position (Px) = [ 973, 1080 ]
04:12:04.910700 : Game client window resolution (Px) = [ 1920x1081 ]
04:12:04.910700 : Game Position (Hex) = [ 0081, 00FF ]
04:12:04.910700 : Game Position (Dec) = [ 129, 255 ]
04:12:04.910700 : MouseButton (Hex) = 0x0000
04:12:04.910700 : -
04:12:04.917665 : RawData event for Device #2:
04:12:04.917665 : Device rawinput data (Hex) = [ 8117, FFFF ]
04:12:04.917665 : PrimaryScreen Size (Px) = [ 1920x1080 ]
04:12:04.917665 : OnScreen Cursor Position (Px) = [ 968, 1079 ]
04:12:04.917665 : OnClient Cursor Position (Px) = [ 968, 1080 ]
04:12:04.917665 : Game client window resolution (Px) = [ 1920x1081 ]
04:12:04.918699 : Game Position (Hex) = [ 0081, 00FF ]
04:12:04.918699 : Game Position (Dec) = [ 129, 255 ]
04:12:04.918699 : MouseButton (Hex) = 0x0000
04:12:04.918699 : -
04:12:04.925667 : RawData event for Device #1:
04:12:04.925667 : Device rawinput data (Hex) = [ B32A, F3DE ]
04:12:04.925667 : PrimaryScreen Size (Px) = [ 1920x1080 ]
04:12:04.925667 : OnScreen Cursor Position (Px) = [ 1343, 1028 ]
04:12:04.925667 : OnClient Cursor Position (Px) = [ 1343, 1029 ]
04:12:04.925667 : Game client window resolution (Px) = [ 1920x1081 ]
04:12:04.925667 : Game Position (Hex) = [ 00B2, 00F3 ]
04:12:04.926699 : Game Position (Dec) = [ 178, 243 ]
04:12:04.926699 : MouseButton (Hex) = 0x0000
04:12:04.926699 : -
04:12:04.933698 : RawData event for Device #2:
04:12:04.933698 : Device rawinput data (Hex) = [ 9768, FFFF ]
04:12:04.933698 : PrimaryScreen Size (Px) = [ 1920x1080 ]
04:12:04.933698 : OnScreen Cursor Position (Px) = [ 1135, 1079 ]
04:12:04.933698 : OnClient Cursor Position (Px) = [ 1135, 1080 ]
04:12:04.934700 : Game client window resolution (Px) = [ 1920x1081 ]
04:12:04.934700 : Game Position (Hex) = [ 0097, 00FF ]
04:12:04.934700 : Game Position (Dec) = [ 151, 255 ]
04:12:04.934700 : MouseButton (Hex) = 0x0000
04:12:04.935699 : -
04:12:04.941699 : RawData event for Device #1:
04:12:04.942699 : Device rawinput data (Hex) = [ B03A, F21E ]
04:12:04.942699 : PrimaryScreen Size (Px) = [ 1920x1080 ]
04:12:04.942699 : OnScreen Cursor Position (Px) = [ 1321, 1021 ]
04:12:04.942699 : OnClient Cursor Position (Px) = [ 1321, 1022 ]
04:12:04.942699 : Game client window resolution (Px) = [ 1920x1081 ]
04:12:04.942699 : Game Position (Hex) = [ 00AF, 00F1 ]
04:12:04.943670 : Game Position (Dec) = [ 175, 241 ]
04:12:04.943670 : MouseButton (Hex) = 0x0000
04:12:04.943670 : -
04:12:04.943670 : RawData event for Device #2:
04:12:04.944670 : Device rawinput data (Hex) = [ 96F8, FFFF ]
04:12:04.944670 : PrimaryScreen Size (Px) = [ 1920x1080 ]
04:12:04.944670 : OnScreen Cursor Position (Px) = [ 1132, 1079 ]
04:12:04.944670 : OnClient Cursor Position (Px) = [ 1132, 1080 ]
04:12:04.945702 : Game client window resolution (Px) = [ 1920x1081 ]
04:12:04.945702 : Game Position (Hex) = [ 0096, 00FF ]
04:12:04.945702 : Game Position (Dec) = [ 150, 255 ]
04:12:04.945702 : MouseButton (Hex) = 0x0000
04:12:04.945702 : -
04:12:04.949699 : RawData event for Device #2:
04:12:04.949699 : Device rawinput data (Hex) = [ 9618, FFFF ]
04:12:04.949699 : PrimaryScreen Size (Px) = [ 1920x1080 ]
04:12:04.950701 : OnScreen Cursor Position (Px) = [ 1125, 1079 ]
04:12:04.950701 : OnClient Cursor Position (Px) = [ 1125, 1080 ]
04:12:04.950701 : Game client window resolution (Px) = [ 1920x1081 ]
04:12:04.950701 : Game Position (Hex) = [ 0095, 00FF ]
04:12:04.950701 : Game Position (Dec) = [ 149, 255 ]
04:12:04.951701 : MouseButton (Hex) = 0x0000
04:12:04.951701 : -
04:12:04.951701 : RawData event for Device #1:
04:12:04.952699 : Device rawinput data (Hex) = [ AD8A, F05E ]
04:12:04.952699 : PrimaryScreen Size (Px) = [ 1920x1080 ]
04:12:04.952699 : OnScreen Cursor Position (Px) = [ 1301, 1014 ]
04:12:04.952699 : OnClient Cursor Position (Px) = [ 1301, 1015 ]
04:12:04.952699 : Game client window resolution (Px) = [ 1920x1081 ]
04:12:04.952699 : Game Position (Hex) = [ 00AD, 00EF ]
04:12:04.952699 : Game Position (Dec) = [ 173, 239 ]
04:12:04.952699 : MouseButton (Hex) = 0x0000
« Last Edit: October 30, 2019, 07:22:42 am by drewjbx »
argonlefou
« Reply #1846 on: October 30, 2019, 11:35:02 am »
Full log is not needed, usefull information are mostly at the beginning
Everything is OK in your Log, I can just assume that DemulShooter is not correctly hooking the game. But I don't know why.
Try without Gameloader in windowed mode, and make sure you didn't check " use mouse for gun" in Teknoparrot
« Last Edit: October 30, 2019, 11:36:51 am by argonlefou »
drewjbx
« Reply #1847 on: October 30, 2019, 11:15:29 pm »
Ok it works that way, both guns fire independently.... forgot to mention I am using a hex edited exe for 1920x1080 resolution if that has any effect. Getting close thanks for suggestions.
tommiegunz
  • Last login:December 30, 2022, 12:11:29 pm
« Reply #1848 on: October 31, 2019, 05:21:54 pm »
i can't get my wiimote to shoot but gernades work fine what is causing this
punkdark2000
  • Last login:June 20, 2025, 07:47:45 pm
« Reply #1849 on: October 31, 2019, 07:25:26 pm »
Argon came out a new version of TP, with the new game Luigis Mansion Arcade, I know he will only change when he is no longer patreon, but 2 games are not working with the demulshooter, would be HOTD4 and Lets Go Jungle, all others including Transformers are operating normally.
« Last Edit: November 02, 2019, 08:32:35 am by punkdark2000 »
argonlefou
« Reply #1850 on: November 01, 2019, 05:11:55 am »
Yes, as usual and as I explained many times: Lindbergh compatibility is broken with every new build because of the way the game is loased in memory (like all other emulators)
Ring games are always working because they are Windows executable, and I can target them directly
Zenmaster224
  • Last login:August 25, 2020, 09:08:44 am
« Reply #1851 on: November 03, 2019, 10:56:17 am »
Could anyone maybe provide some help for model 2 ,I tried with newest version and now trying with 7.6 as github suggests.  it recognizes both aimtrak guns as player 1 cause I see two red cursors in hotd and I think the issue much like with other emulators is the demulshooter isn't hooking with M2 emulator but I have both demulshooter and M2 emulator set to run as administrator, i don't think it's my settings in the ini cause both guns are recognized just both as player 1
Zenmaster224
« Reply #1852 on: November 03, 2019, 03:28:57 pm »
found out I needed to open the emulator_multicpu.exe not the normal EMULATOR.exe , on to a different emulator if anyone else knows there issue,  but I'm trying to use demulshooter with demul but everytime I open hotd 2 demul closes including demulshooter so I don't think it's a hooking issue, any help?  opening demul without demulshooter loads the game fine but like expected both guns are p1
ginzu
  • Last login:November 20, 2025, 03:58:31 am
« Reply #1853 on: November 04, 2019, 01:43:37 pm »
hi @argonlefou, hope you will find a workaround to avoid this behaviour in the futur..
 it must be really boring for you, if you must re-adapt the code each time a new version  of TP is released......
SuperMagoAlex
  • Last login:June 30, 2025, 05:19:01 pm
« Reply #1854 on: November 04, 2019, 05:10:17 pm »
I confirm that HOTD4 and Lets go Jungle dont work with last Teknoparrot 1.0.0.230/18 and Demulshooter 8.5.7  :'(
« Last Edit: November 04, 2019, 06:43:48 pm by SuperMagoAlex »
kona0511
  • Last login:November 04, 2019, 07:22:20 pm
« Reply #1855 on: November 04, 2019, 06:37:57 pm »
hi~
operation ghost
I'm using 2 aimtrak guns
demulshooter 8.5.7 in use
1p reload is fine but 2p reload is not used
What is the problem?
vargas14617
  • Last login:February 14, 2024, 02:56:54 pm
  • Don't push the Red button! I pushed the Red button
« Reply #1856 on: November 04, 2019, 09:06:12 pm »
I am using usb2gun pcb should I be seeing the guns in Dx_Diag?  because I don't.  Is it because they are seen as joysticks?  How do I make them visible?
argonlefou
« Reply #1857 on: November 05, 2019, 06:47:53 pm »
You can't, usb2gun maps hardware to simple joystick
You have to plug RawInput device or Xinput device to use DemulShooter
vargas14617
« Reply #1858 on: November 05, 2019, 08:53:46 pm »
Guess troubleshooter2 it is thanks for the reply
phasermaniac
« Reply #1859 on: November 06, 2019, 06:10:17 pm »
Hi!
I know this is offtopic, but does anybody know how to play the gunandfrenzy mod for quake on windows 10? It uses an HTML+JavaScript launcher that seems to need a very old explorer version, as I understand
I suppose it can be done in a virtual machine, but as it replug the inputs on the host, it messes my guns Ids
« Last Edit: November 06, 2019, 06:18:11 pm by phasermaniac »
Zenmaster224
« Reply #1860 on: November 06, 2019, 09:07:17 pm »
can I get some help with silent Hill arcade,  I've set the p2 start inside if demulshooter which works,  I am trying using the nocursor.exe but when I get into the game I actually do see two cursors but the trigger in my second aimtrak doesn't shoot the second gun in game.  only player 1 works as it should.  demulshooter has been working with other games and is already set to run as admin and I set but the regular and no cursor exe to run as admin as well but nothing makes the second gun shoot. incidentally running the exe as expected makes both aimtrak gun triggers just shoot the p1 gun in game as expected
Zenmaster224
« Reply #1861 on: November 08, 2019, 01:02:26 pm »
Does the PC version of house of the dead overkill (included with typing of the dead)  not support 2 shooters on one screen like the wii version does?
fjser
  • Last login:March 07, 2024, 01:42:51 pm
« Reply #1862 on: November 08, 2019, 04:19:27 pm »
correct - 1p only. shame sincve wii version is missing the extra levels :(
fjser
« Reply #1863 on: November 08, 2019, 04:21:46 pm »
isnt the solution here to just have multiple versions of tp and ds installed?  get a game working one place and the don't touch it?
argonlefou
« Reply #1864 on: November 08, 2019, 07:13:34 pm »
Of course.
And It's not like TP isn't breaking anything with each update ;D
I never update a working set-up unless it comes with something I need
Zenmaster224
« Reply #1865 on: November 10, 2019, 10:54:46 am »
Can I get some help with CXBX reloaded,  trying to finally get virtua cop 3 working with both aimtrak guns, on the demulshooter github step 1 says set both xbox port 0 to direct input port 0, but there's only 4 ports from 0 to 3, there isn't two port 0's
darkdragon83
  • Last login:December 12, 2022, 06:06:53 pm
« Reply #1866 on: November 11, 2019, 05:59:20 pm »
I can't find a cxbx compatible version with demulshooter.
all builds here:
https://www.emucr.com/search/label/Cxbx-Reloaded?&max-results=16
but Cxbx-Reloaded 9c483f6 (Feb 26 2019) seems to be non-existent. anyboby can post a compatible version or link please?. thanks a lot
Zenmaster224
« Reply #1867 on: November 11, 2019, 08:54:36 pm »
all builds here:
https://www.emucr.com/2019/02/cxbx-reloaded-git-20190215.html?m=1
that's the one I use and got perfectly working with virtua cop 3, just remember per the instructions for demulshooter to have it windowed
darkdragon83
« Reply #1868 on: November 12, 2019, 02:16:25 am »
 :applaud: :applaud: thanks it works
millansoft
  • Last login:October 23, 2025, 08:10:49 pm
« Reply #1869 on: November 14, 2019, 08:20:20 pm »
Hello, I use demulshooter with a wiimote and it works great, I bought a gun accesory for it with a nunchuk integrated but it inverts for some reason the trigger button with the second button. Could you add an option to invert the left/right mouse click?
Thanks a lot!
Smraedis
  • Last login:October 05, 2020, 02:58:43 pm
  • Yeah it's me, hi!
« Reply #1870 on: November 15, 2019, 05:35:52 am »
Thanks a lot!
This happens with the DolpinBar when you connect a nunchuck. It's a silly feature imo and there isn't anything online about how to reverse it.
millansoft
« Reply #1871 on: November 15, 2019, 08:46:52 am »
Yes, I´m using it with Dolphin Bar, in MAME for example I just invert the buttons and it works fine, I just asked for an option in DemulShooter (if it is possible) to invert the mouse buttons, so it can be used normally in the rest of the emulators, as I do now in MAME.
argonlefou
« Reply #1872 on: November 15, 2019, 10:31:53 am »
I don't understand....for Wiimotes ans others XInput devices you have to choose which button is left/right/midle click
Why not just invert here?
millansoft
« Reply #1873 on: November 17, 2019, 03:04:18 pm »
You´re right I already invert them in MAME for example. But in Demul for example, I can´t invert the mouse buttons.
Zenmaster224
« Reply #1874 on: November 19, 2019, 02:24:20 pm »
Can someone please help or point me in the right direction.  Now that I have most of the shooters minus silent Hill working with 2 players with demulshooter,  I want a nice clean front end where all the games area organized.  I have launchbox/big box and I'm wondering if there's a way to assign each game an executable command for command prompt to run for each said game when selecting it so that demulshooter can be executed right away when I go from game to game. I can't find much of an answer online.
Zenmaster224
« Reply #1875 on: November 21, 2019, 11:50:45 am »
Is demulshooter getting support any time soon for far cry paradise lost so we can play 2 players?
argonlefou
« Reply #1876 on: November 21, 2019, 01:20:29 pm »
No because far cry paradise dump is not working.
You have to use some hack to keep playing after a Game Over, this j=hack is closing and reloading the process, thus closing demulshooter
lowgunn
  • Last login:February 08, 2025, 02:33:10 pm
« Reply #1877 on: November 27, 2019, 11:45:34 am »
Thanks Argon for this awesome software.  I'm currently using the  alien dehasped.exe and noticed the flame thrower and gun trigger shares the same button, also the gernade button does not work.  Is this normal?  If they do work, ill revisit my setup.  thanks again.
argonlefou
« Reply #1878 on: November 27, 2019, 02:03:18 pm »
It's not normal, the normal behavior is shoot/grenade on 2 different buttons (left and missle click) and flamethrower not mapped
lowgunn
« Reply #1879 on: December 01, 2019, 02:29:01 pm »
Thanks,  I think I got it working now.  Will you plan to support the flamethrower or its something not possible?  thanks again.
