Author Topic: For you MAME guys, how do you secure graphics card in de-cased PC?  (Read 3382 times)
P.H.U.
Doesn't make sense to case up a PC if you are putting it in a cab. For those that have a discreet card attached to your de-cased PC in your cab, how are you securing your graphics card?
Pics please.
jeremymtc
  • Last login:Today at 03:29:16 am
Re: For you MAME guys, how do you secure graphics card in de-cased PC?
« Reply #1 on: February 21, 2016, 10:12:10 pm »
I've used the mobo tray and backplane of an old ATX case in the past. Had to do a little cutting.
paigeoliver
  • Awesome face!
« Reply #2 on: February 21, 2016, 10:14:30 pm »
Let me tell you how all the companies that manufacturer PC based arcade games have solved that problem.
They leave the computer in the case because it doesn't make any sense to take it out.
Pics please.
« Reply #3 on: February 21, 2016, 10:25:48 pm »
But for those of us with the testicular fortitude to do it, a custom plate and a large zip tie work just fine...
P.H.U.
« Reply #4 on: February 21, 2016, 11:30:12 pm »
They also have custom cases with tamper-proofing. The topic involves MAME; we aren't talking about a big budget commercial production run here. Leaving it in the case opens other issues and considerations:  cost, securing it down, room in the cab, etc.
P.H.U.
« Reply #5 on: February 21, 2016, 11:34:18 pm »
Thanks! Hoping to avoid the cost of buying a case though. Would be a terrible sacrifice of even a $20 ATX case  :-\.
Any sway of the card in that setup?
« Reply #6 on: February 22, 2016, 12:10:23 am »
Not once it's set up and locked down. I've moved the cab from room to room and even on it's sides and back to recut the t-molding slots, and I had no issues with it shifting or coming loose.
P.H.U.
« Reply #7 on: February 22, 2016, 12:15:56 am »
Very interesting brutha. I'll have to rig something off the mobo screw holes to fasten the zips to make it work for me. Thanks for the slice of swift ingenuity.
More solution pics please!
« Reply #8 on: February 22, 2016, 12:42:00 am »
I got the long zip ties at Home Depot. Totally worth it.
« Reply #9 on: February 22, 2016, 05:45:56 am »
In bartops and other tight spaces where I decased, I've used hot glue and it works fine.
Thenasty
  • Last login:January 22, 2026, 11:19:58 pm
« Reply #10 on: February 22, 2016, 11:10:30 am »
here is what i've done long ago.
Drill a hole on the bottom of the video card
use a wooden board for installing all parts (PS, MOBO, HD etc..)
screw the video card into the wood.
Free VGA Breakout Cable
P.H.U.
« Reply #11 on: February 22, 2016, 02:07:02 pm »
Thenasty, that is the cheapest solution yet! How did you get the flange to go upside down :). I suppose I can drill a hole into the flange on the other end.
« Reply #12 on: February 22, 2016, 03:25:26 pm »
Hey! Hotglue is cheap too. :)
P.H.U.
« Reply #13 on: February 22, 2016, 04:18:12 pm »
LoLoL!
BuZz880
  • Last login:November 16, 2023, 02:16:43 pm
« Reply #14 on: February 22, 2016, 05:56:13 pm »
Yup me too. Drilled out some rivets. But I also bought a drawer one time from microcenter. Kind of a caseless case.
Sent from my Nexus 6P using Tapatalk
Thenasty
« Reply #15 on: February 22, 2016, 09:44:12 pm »
Wow ! !good eye, been so long I totally forgot that part.
I believe I change the original with some other video cards flange and I flatten out the top of it to extend it to reach the board.
Hopefully this gives you the picture of what i did.
RetroGreg
« Reply #16 on: February 22, 2016, 10:33:30 pm »
I like the zip tie and custom plate! Great idea.
