January 21, 2026, 09:33:23 pm
Doesn't make sense to case up a PC if you are putting it in a cab. For those that have a discreet card attached to your de-cased PC in your cab, how are you securing your graphics card?Pics please.
Let me tell you how all the companies that manufacturer PC based arcade games have solved that problem.They leave the computer in the case because it doesn't make any sense to take it out.
I've used the mobo tray and backplane of an old ATX case in the past. Had to do a little cutting.
But for those of us with the testicular fortitude to do it, a custom plate and a large zip tie work just fine...
Any sway of the card in that setup?
Not once it's set up and locked down. I've moved the cab from room to room and even on it's sides and back to recut the t-molding slots, and I had no issues with it shifting or coming loose.
Thenasty, that is the cheapest solution yet! How did you get the flange to go upside down . I suppose I can drill a hole into the flange on the other end.
